    MMM-MyCommute
    286 Posts 80 Posters 720.4k Views 77 Watching
      robiv8
      Au das wäre sehr nett :kissing_face:
      • L Offline
        lolobyte @Aries1984
        @aries1984
        Bitte mir dann auch wenn moglich.
        • K Offline
          keyun21
          Newbie here I guess i have to pay for Google API service right? without that this module not going to work correct?
          • BKeyportB Offline
            BKeyport Module Developer @keyun21
            @keyun21 You have to set up a pay account, including a credit card, but they give you a specific number of free accesses, and if you keep the module to a timeframe that you’d normally look at it, you’d have a hard time exceeding those uses.
            • K Offline
              keyun21 @BKeyport
              @bkeyport said in MMM-MyCommute:
              Thanks a lot I will look into to see how many I can get free and how to set up module to run specific times?
                Aries1984 Module Developer
                Hi everybody,
                sorry for the late reply. Haven’t been here much in the last couple of weeks. Here’s my config:
                        module: 'MMM-MyCommute',
                        position: 'bottom_right',
                        header: 'Traffic',
                        classes: 'default everyone',
                            apikey: 'your API Key',
                            origin: 'Marienplatz 1, 80331 München',
                            startTime: '05:00',
                            endTime: '10:00',
                            hideDays: [0, 6],
                            destinations: [
                                    destination: 'Belgradstraße 13, 80796 München',
                                    label: 'Good Food',
                                    mode: 'driving',
                                    color: '#82E5AA'
                  seanluse41
                  Can this module support Japanese addresses?
                  The default config and values work for me, but putting in Japanese addresses returns loading… forever.
                  • T Offline
                    thoeng
                    This is great and very practical module! Everything is working on me but i would like to remain below USD200 (40K calls)/mo API call request. This means staying below 1.3K calls/day
                    However, after installed I can see 570+ request call in 2 hours on Google API dashboard. This is despite setting pollFrequency: 1200000 (20mins interval) on MM config.
                    Any help please?
                    I 1 Reply Last reply Reply Quote 1
                      charp07
                      MM is only loading the “loading…” text for this module. All my other modules are showing right. I am getting request on the Google API Console under the Directions API. So I believe that I must have the module installed correctly. Does anyone know why this would be happening?
                        charp07
                        			apikey: 'my api key from google',
                        			origin: '65 Front St W, Toronto, ON M5J 1E6',
                        			startTime: '00:00',
                        			endTime: '23:59',
                        			hideDays: [0,6],
                        			destinations: [
                        				destination: '14 Duncan St Toronto, ON M5H 3G8',
                        				label: 'Air Canada Centre',
                        				mode: 'walking',
                        				color: '#82E5AA'
                          in the MagicMirror folder do
                          npm check:config
                          fix 1st error, repeat
                          I think it is the comma after the only destination
                          				color: '#82E5AA'
                          loading …
                          is the default message many modules put up while getting their data
                          but it failed to get the data
                          so, this means there was an internal error in the module code
                          open the developers window
                          (either npm start dev, or use ctrl-shift-i when mirror is running)
                          select the console tab, and scroll up to locate any errors, usually red text
                          C 3 Replies Last reply Reply Quote 1
                            charp07 @sdetweil
                              charp07 @sdetweil
                              @sdetweil okay, I’m new but the check:config command is not valid. So tried npm config and it brought up 10 errors.
                              Usage:
                              Npm config set
                              Npm config get …
                              Etc
                              Etc…
                              What does this mean?
                                charp07 @sdetweil
                                @sdetweil also added comma to that location with no success. Then moved to behind bracket and nothing there either.
                                  sdetweil @charp07
                                  @charp07 sorry, I get that command backwards
                                  npm config:check
                                  • I Offline
                                    interman @thoeng
                                    @thoeng I ran into the same problem. there a few things you can do.
                                    1. Set the time that the module comes on and goes off. For example, I set my mine from 5:00 am to 8:00 am.
                                      startTime and endTime
                                    2. Hide the module on weekends. Mine does not come up on the weekends. hideDays
                                    3. Change how many times it goes to google with a request. pollFrequency
                                    4. add a cheap motion sensor to turn the display on and off (getting one now).
                                    Hope that helps.
                                    Dn
                                      charp07
                                      I swapped to a newer branch of “MMM-MyCommute”. After install, it booted up on the first try. Happy that it is now working. Thanks to all the authors of this module.
                                        JRB1988
                                        Will this module still be updating in the background during the hidden times? With the Google API, I wouldn’t want it updating when I am not needing it. Thanks!
                                        • T Offline
                                          trawson
                                          Is anyone else having issues with the MyCommute module hiding itself but then not re-appearing.
                                          I have EndTime setup for 8pm and also HideDays on certain days, however, once it hides, it stays hidden. Until I force it to show using the Remote module.
                                          Otherwise, this Module works great, showing all the traffic times as it should.
                                          • T Offline
                                            trawson @JRB1988
                                            @JRB1988 From my experiences, I don’t believe it does.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 11 / 15
