    Doorbird IP camera integration
    15 Posts 4 Posters 4.4k Views 4 Watching
      MilkShake
      Hi mmourica and thanks for replying!
      I guess Sonnette is a schedule? So I made sure that the schedule for the notication is all active. I will test it later.
      Can I ask where you found the documentation for the HTTP call for a specific sound file in MMM-Sounds?
        mmourcia @MilkShake
        @MilkShake
        Yes for schedule
        For the doc I don’t really remember anymore. I had to deduce it from this page and from the native docs of modules
          MilkShake @mmourcia
          @mmourcia Hey man, just tested, it works! Why would the schedule for a HTTP call not be allowed in the scheduler by default is beyond me! :)
            MilkShake @mmourcia
            @mmourcia And I need to find out how to run a script on the same event :)
              mmourcia @MilkShake
              @MilkShake
              Then you should probably do that outside MM.
              Maybe with a http listener like https://github.com/msoap/shell2http/blob/master/README.md ?
                MilkShake @mmourcia
                @mmourcia would be an option, thanks. I will check it out! My initial thought was that the code executing the wavfile, would also be able to execute a shell script on the PI, but a HTTP listener would also do the job.
                Evidently, I can only set the Doorbird to do ONE http call pr event, otherwise a tweaked version of the monitor on http call (MMM-Remote-Control) could be used together with the call for playing a sound.
                  MilkShake
                  I used the MMM-Notification-Trigger to wake up the screen and display an alert when it receives the PLAY_SOUND event.
                  Best
                  MilkShake
                    mmourcia @MilkShake
                    @MilkShake
                    Could you post your conf ?
                      MilkShake @mmourcia
                      You have to have AMk2 and the screen Addon by Bugsounet.
                      But basicly, I used the https string you gave me for the HTTP call to MMM-Sounds. That triggers the event PLAY_SOUND which can be picked up by MMM-Notification-Trigger:
                            module: "MMM-NotificationTrigger",
                              triggers:[
                                  trigger: "PLAY_SOUND",
                                  fires: [
                      //wakes up the screen using the screen addon
                                      fire:"USER_PRESENCE",
                                      payload: function(payload) {
                                        return false
                                      fire:"SHOW_ALERT",
                                        return {
                                          type: "notification",
                                          title: "Porten",
                                          message: "Der er nogen ved porten!",
                                          timer: 1000
                      I’m struggling a bit with the multiple fires within one trigger, but I had it working at a certain point :)
                        Jagsi
                        If have an Doorbord as well - and I want to integrate it to the Magicmirror. Can you maybe give me some help to get this running? I am quite new to all this things.
                        Which module are you using?
                        Does your mirror wake up when somebody is ringing? (Is your screen shutting off?)
                        And if nobody is ringing you cant see it right?
                        Thanks for your help.
