    MM on Pi Zero fails after being off for a few days
    27 Posts 2 Posters 10.5k Views 2 Watching
    • K
      kellogg76
      I’ve had my MM running well for months, but I had to shut it down recently to move it and when I plugged everything in again afterwards it doesn’t load on the Pi’s screen. It does however load fine if i remotely connect to the url for my MM on another computer.
      i assumed it might be a problem with Chromium so I removed and re-installed that, but it made no difference.
      Next I tried re-installing again on top of my current installation (from here http://emmanuelcontreras.com/how-to/how-to-create-a-magic-mirror-2-with-pi-zero-w/) but have had no luck.
      The description of the problem is that the Pi boots to terminal then screen goes black and I see a mouse cursor, then it drops back to the terminal and just loops between the two every 30s or so.
      Is there a way to diagnose what’s going on as I really don’t want to start from scratch again.
      Cheers
      S 2 Replies Last reply
        sdetweil @kellogg76
        @kellogg76 we can debug it. Later as I am not near my machine
        K 1 Reply Last reply
        • K
          kellogg76 @sdetweil
          @sdetweil Thanks, i’ll check back later, I’m in Eastern Canada so if the time difference is a problem leave some instructions and I’ll reply with the outcomes.
            sdetweil @kellogg76
            @kellogg76
            sounds like its trying to start a second time, and failing… (cause the 1st time is running , maybe in serveronly mode?_
            use ssh into the pi, and use whatever mechanism to stop mirror app…
            pm2, whatever autostart process…
            IF you reinstall, I suggest you use my install script…
            see here
            does all the work.
            what starts this? pm2? pm2 logs --lines=100 will show the logs
            • K
              kellogg76 @sdetweil
              @sdetweil said in MM on Pi Zero fails after being off for a few days:
              Here’s the last 100 lines of the pm2 log, with a few of the first PM2 lines removed as they were identical :-
              PM2        | 2020-03-29T09:27:24: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:27:58: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:27:58: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:27:58: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:28:32: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:28:32: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:28:32: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:29:05: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:29:05: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:29:05: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:29:42: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:29:42: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:29:42: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:30:16: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:30:16: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:30:16: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:30:49: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:30:49: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:30:49: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:31:23: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:31:23: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:31:23: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:31:57: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:31:57: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:31:57: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:32:31: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:32:31: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:32:31: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:33:04: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:33:04: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:33:04: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:33:38: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:33:38: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:33:38: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:34:12: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:34:12: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:34:12: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:34:48: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:34:48: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:34:48: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:35:24: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:35:24: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:35:24: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:35:58: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:35:58: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:35:58: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:36:32: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:36:32: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:36:32: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:37:06: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:37:06: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:37:06: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:44:58: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:44:58: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:44:58: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:45:35: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:45:35: PM2 log: App [mmstart:0] starting in -fork mode-
              PM2        | 2020-03-29T09:45:35: PM2 log: App [mmstart:0] online
              PM2        | 2020-03-29T09:46:01: PM2 log: Stopping app:mmstart id:0
              PM2        | 2020-03-29T09:46:02: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-03-29T09:46:02: PM2 log: pid=27183 msg=process killed
              /home/pi/.pm2/logs/mmstart-error.log last 100 lines:
              0|mmstart  |     at Function.Module.runMain (internal/modules/cjs/loader.js:832:11)
              0|mmstart  |     at startup (internal/bootstrap/node.js:283:19)
              0|mmstart  |     at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
              0|mmstart  |   code: 'EADDRINUSE',
              0|mmstart  |   errno: 'EADDRINUSE',
              0|mmstart  |   syscall: 'listen',
              0|mmstart  |   address: '0.0.0.0',
              0|mmstart  |   port: 8080 }
              0|mmstart  |
              0|mmstart  |
              0|mmstart  | X.Org X Server 1.20.4
              0|mmstart  | X Protocol Version 11, Revision 0
              0|mmstart  | Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
              0|mmstart  | Current Operating System: Linux KitchenPi 4.19.75+ #1270 Tue Sep 24 18:38:54 BST 2019 armv6l
              0|mmstart  | Kernel command line: coherent_pool=1M bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:FF:A6:3B vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 conso$
              0|mmstart  | Build Date: 05 June 2019  12:49:54PM
              0|mmstart  | xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
              0|mmstart  | Current version of pixman: 0.36.0
              0|mmstart  |    Before reporting problems, check http://wiki.x.org
              0|mmstart  |    to make sure that you have the latest version.
              0|mmstart  | Markers: (--) probed, (**) from config file, (==) default setting,
              0|mmstart  |    (++) from command line, (!!) notice, (II) informational,
              0|mmstart  |    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
              0|mmstart  | (==) Log file: "/var/log/Xorg.0.log", Time: Sun Mar 29 09:44:21 2020
              0|mmstart  | (==) Using system config directory "/usr/share/X11/xorg.conf.d"
              0|mmstart  | /home/pi/chromium_start.sh: 7: /home/pi/chromium_start.sh: chromium-browser: not found
              0|mmstart  | xinit: connection to X server lost
              0|mmstart  |
              0|mmstart  | waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
              0|mmstart  |
              0|mmstart  | [09:44:38.366] [ERROR]  { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
              0|mmstart  |     at Server.setupListenHandle [as _listen2] (net.js:1279:14)
              0|mmstart  |     at listenInCluster (net.js:1327:12)
              0|mmstart  |     at doListen (net.js:1460:7)
              0|mmstart  |     at process._tickCallback (internal/process/next_tick.js:63:19)
              0|mmstart  |
              0|mmstart  |
              0|mmstart  | Kernel command line: coherent_pool=1M bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:FF:A6:3B v$
              0|mmstart  | (==) Log file: "/var/log/Xorg.0.log", Time: Sun Mar 29 09:44:55 2020
              0|mmstart  |
              0|mmstart  |
              0|mmstart  | [09:45:20.571] [ERROR]  { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
              0|mmstart  |
              0|mmstart  |
              0|mmstart  | (==) Log file: "/var/log/Xorg.0.log", Time: Sun Mar 29 09:45:29 2020
              0|mmstart  |
              0|mmstart  |
              /home/pi/.pm2/logs/mmstart-out.log last 100 lines:
              0|mmstart  | [09:44:04.467] [LOG]    Initializing new module helper ...
              0|mmstart  | [09:44:04.475] [LOG]    Module helper loaded: calendar
              0|mmstart  | [09:44:04.956] [LOG]    Initializing new module helper ...
              0|mmstart  | [09:44:04.964] [LOG]    Module helper loaded: newsfeed
              0|mmstart  | [09:44:04.970] [LOG]    All module helpers loaded.
              0|mmstart  | [09:44:04.975] [LOG]    Starting server on port 8080 ...
              0|mmstart  | [09:44:05.117] [INFO]   ^[[33mYou're using a full whitelist configuration to allow for all IPs^[[39m
              0|mmstart  | [09:44:05.181] [LOG]    Server started ...
              0|mmstart  | [09:44:05.191] [LOG]    Connecting socket for: updatenotification
              0|mmstart  | [09:44:05.199] [LOG]    Connecting socket for: MMM-DarkSkyForecast
              0|mmstart  | [09:44:05.207] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]
              0|mmstart  | [09:44:05.213] [LOG]    Connecting socket for: mmm-suncalc
              0|mmstart  | [09:44:05.219] [LOG]    Starting node_helper for mmm-suncalc:
              0|mmstart  | [09:44:05.228] [LOG]    Connecting socket for: calendar
              0|mmstart  | [09:44:05.234] [LOG]    Starting node helper for: calendar
              0|mmstart  | [09:44:05.243] [LOG]    Connecting socket for: newsfeed
              0|mmstart  | [09:44:05.249] [LOG]    Starting module: newsfeed
              0|mmstart  | [09:44:05.251] [LOG]    Sockets connected & modules started ...
              0|mmstart  | [09:44:05.254] [LOG]
              0|mmstart  | Ready to go! Please point your browser to: http://0.0.0.0:8080
              0|mmstart  | [09:44:05.328] [LOG]    Whoops! There was an uncaught exception...
              0|mmstart  | [09:44:05.388] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              0|mmstart  | [09:44:05.393] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              0|mmstart  | [09:44:31.284] [LOG]    Starting MagicMirror: v2.10.1
              0|mmstart  | [09:44:31.360] [LOG]    Loading config ...
              0|mmstart  | [09:44:31.398] [LOG]    Loading module helpers ...
              0|mmstart  | [09:44:31.413] [LOG]    No helper found for module: alert.
              0|mmstart  | [09:44:31.758] [LOG]    Initializing new module helper ...
              0|mmstart  | [09:44:31.768] [LOG]    Module helper loaded: updatenotification
              0|mmstart  | [09:44:31.777] [LOG]    No helper found for module: clock.
              0|mmstart  | [09:44:34.609] [LOG]    Initializing new module helper ...
              0|mmstart  | [09:44:34.618] [LOG]    Module helper loaded: MMM-DarkSkyForecast
              0|mmstart  | [09:44:34.649] [LOG]    Initializing new module helper ...
              0|mmstart  | [09:44:34.657] [LOG]    Module helper loaded: mmm-suncalc
              0|mmstart  | [09:44:34.663] [LOG]    No helper found for module: calendar_monthly.
              0|mmstart  | [09:44:37.531] [LOG]    Initializing new module helper ...
              0|mmstart  | [09:44:37.541] [LOG]    Module helper loaded: calendar
              0|mmstart  | [09:44:37.947] [LOG]    Initializing new module helper ...
              0|mmstart  | [09:44:37.955] [LOG]    Module helper loaded: newsfeed
              0|mmstart  | [09:44:37.960] [LOG]    All module helpers loaded.
              0|mmstart  | [09:44:37.965] [LOG]    Starting server on port 8080 ...
              0|mmstart  | [09:44:38.049] [INFO]   ^[[33mYou're using a full whitelist configuration to allow for all IPs^[[39m
              0|mmstart  | [09:44:38.114] [LOG]    Server started ...
              0|mmstart  | [09:44:38.124] [LOG]    Connecting socket for: updatenotification
              0|mmstart  | [09:44:38.134] [LOG]    Connecting socket for: MMM-DarkSkyForecast
              0|mmstart  | [09:44:38.143] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]
              0|mmstart  | [09:44:38.149] [LOG]    Connecting socket for: mmm-suncalc
              0|mmstart  | [09:44:38.153] [LOG]    Starting node_helper for mmm-suncalc:
              0|mmstart  | [09:44:38.159] [LOG]    Connecting socket for: calendar
              0|mmstart  | [09:44:38.167] [LOG]    Starting node helper for: calendar
              0|mmstart  | [09:44:38.176] [LOG]    Connecting socket for: newsfeed
              0|mmstart  | [09:44:38.184] [LOG]    Starting module: newsfeed
              0|mmstart  | [09:44:38.198] [LOG]    Sockets connected & modules started ...
              0|mmstart  | [09:44:38.252] [LOG]
              0|mmstart  | [09:44:38.356] [LOG]    Whoops! There was an uncaught exception...
              0|mmstart  | [09:44:38.418] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              0|mmstart  | [09:44:38.423] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              0|mmstart  | [09:45:06.640] [LOG]    Starting MagicMirror: v2.10.1
              0|mmstart  | [09:45:06.856] [LOG]    Loading config ...
              0|mmstart  | [09:45:06.930] [LOG]    Loading module helpers ...
              0|mmstart  | [09:45:06.945] [LOG]    No helper found for module: alert.
              0|mmstart  | [09:45:07.656] [LOG]    Initializing new module helper ...
              0|mmstart  | [09:45:07.674] [LOG]    Module helper loaded: updatenotification
              0|mmstart  | [09:45:07.689] [LOG]    No helper found for module: clock.
              0|mmstart  | [09:45:13.291] [LOG]    Initializing new module helper ...
              0|mmstart  | [09:45:13.310] [LOG]    Module helper loaded: MMM-DarkSkyForecast
              0|mmstart  | [09:45:13.362] [LOG]    Initializing new module helper ...
              0|mmstart  | [09:45:13.380] [LOG]    Module helper loaded: mmm-suncalc
              0|mmstart  | [09:45:13.389] [LOG]    No helper found for module: calendar_monthly.
              0|mmstart  | [09:45:19.079] [LOG]    Initializing new module helper ...
              0|mmstart  | [09:45:19.087] [LOG]    Module helper loaded: calendar
              0|mmstart  | [09:45:19.960] [LOG]    Initializing new module helper ...
              0|mmstart  | [09:45:19.987] [LOG]    Module helper loaded: newsfeed
              0|mmstart  | [09:45:20.007] [LOG]    All module helpers loaded.
              0|mmstart  | [09:45:20.031] [LOG]    Starting server on port 8080 ...
              0|mmstart  | [09:45:20.159] [INFO]   ^[[33mYou're using a full whitelist configuration to allow for all IPs^[[39m
              0|mmstart  | [09:45:20.292] [LOG]    Server started ...
              0|mmstart  | [09:45:20.303] [LOG]    Connecting socket for: updatenotification
              0|mmstart  | [09:45:20.321] [LOG]    Connecting socket for: MMM-DarkSkyForecast
              0|mmstart  | [09:45:20.331] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]
              0|mmstart  | [09:45:20.339] [LOG]    Connecting socket for: mmm-suncalc
              0|mmstart  | [09:45:20.343] [LOG]    Starting node_helper for mmm-suncalc:
              0|mmstart  | [09:45:20.359] [LOG]    Connecting socket for: calendar
              0|mmstart  | [09:45:20.369] [LOG]    Starting node helper for: calendar
              0|mmstart  | [09:45:20.378] [LOG]    Connecting socket for: newsfeed
              0|mmstart  | [09:45:20.394] [LOG]    Starting module: newsfeed
              0|mmstart  | [09:45:20.397] [LOG]    Sockets connected & modules started ...
              0|mmstart  | [09:45:20.410] [LOG]
              0|mmstart  | [09:45:20.554] [LOG]    Whoops! There was an uncaught exception...
              0|mmstart  | [09:45:20.680] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              0|mmstart  | [09:45:20.687] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              0|mmstart  | [09:45:53.656] [LOG]    Starting MagicMirror: v2.10.1
              0|mmstart  | [09:45:53.864] [LOG]    Loading config ...
              0|mmstart  | [09:45:53.987] [LOG]    Loading module helpers ...
              0|mmstart  | [09:45:54.028] [LOG]    No helper found for module: alert.
              0|mmstart  | [09:45:55.278] [LOG]    Initializing new module helper ...
              0|mmstart  | [09:45:55.292] [LOG]    Module helper loaded: updatenotification
              0|mmstart  | [09:45:55.321] [LOG]    No helper found for module: clock.
                sdetweil @kellogg76
                @kellogg76 ok, do
                pm2 status
                it seems there is something already running
                • K
                  kellogg76
                  Everything was stopped.
                  $ pm2 status
                  │ id │ name               │ mode     │ ↺    │ status   │ cpu      │ memory   │
                  │ 0  │ mmstart            │ fork     │ 1780 │ stopped  │ 0%       │ 0b       │
                    sdetweil @kellogg76
                    @kellogg76 pm2 info 0
                    • K
                      kellogg76 @sdetweil
                      Describing process with id 0 - name mmstart
                      │ status            │ stopped                              │
                      │ name              │ mmstart                              │
                      │ version           │ N/A                                  │
                      │ restarts          │ 1780                                 │
                      │ uptime            │ 0                                    │
                      │ script path       │ /home/pi/mmstart.sh                  │
                      │ script args       │ N/A                                  │
                      │ error log path    │ /home/pi/.pm2/logs/mmstart-error.log │
                      │ out log path      │ /home/pi/.pm2/logs/mmstart-out.log   │
                      │ pid path          │ /home/pi/.pm2/pids/mmstart-0.pid     │
                      │ interpreter       │ bash                                 │
                      │ interpreter args  │ N/A                                  │
                      │ script id         │ 0                                    │
                      │ exec cwd          │ /home/pi                             │
                      │ exec mode         │ fork_mode                            │
                      │ node.js version   │ N/A                                  │
                      │ node env          │ N/A                                  │
                      │ watch & reload    │ ✘                                    │
                      │ unstable restarts │ 0                                    │
                      │ created at        │ 2020-03-28T19:51:14.338Z             │
                      Divergent env variables from local env
                      │ SSH_CONNECTION │ 192.168.1.148 54823 192.168.1.166 22 │
                      │ XDG_SESSION_ID │ c2                                   │
                      │ SSH_CLIENT     │ 192.168.1.148 54823 22               │
                      │ SSH_TTY        │ /dev/pts/1                           │
                      Add your own code metrics: http://bit.ly/code-metrics
                      Use `pm2 logs mmstart [--lines 1000]` to display logs
                      Use `pm2 env 0` to display environment variables
                      Use `pm2 monit` to monitor CPU and Memory usage mmstart
                        sdetweil @kellogg76
                        @kellogg76 said in MM on Pi Zero fails after being off for a few days:
                        /home/pi/mmstart.sh
                        can u show that file
                        • K
                          kellogg76 @sdetweil
                          #!/bin/bash
                          node serveronly &
                          sleep 30
                          xinit /home/pi/chromium_start.sh
                            sdetweil @kellogg76
                            and that one?
                            • K
                              kellogg76 @sdetweil
                              #!/bin/sh
                              unclutter &
                              xset -dpms # disable DPMS (Energy Star) features.
                              xset s off # disable screen saver
                              xset s noblank # don’t blank the video device
                              matchbox-window-manager &
                              chromium-browser -–incognito --start-fullscreen -–kiosk http://localhost:8080/
                                sdetweil @kellogg76
                                @kellogg76 weird…
                                and if you do pm2 start 0 it works ok?
                                • K
                                  kellogg76 @sdetweil
                                  @sdetweil it works in as much as I can see the magic mirror on another computer when I point to the correct IP, but the pi itself does not display anything at all, it sits at a terminal prompt or if I reboot and let it try to start on its own it’ll switch from prompt to black screen with mouse pointer as if it’s trying to start, then it loops back to a prompt and cycles between the two states.
                                    weird… seems like chrome is having trouble.
                                    if you type
                                    chromium-browser  --app=https://cnn.com
                                    does it come up?
                                    in 2.10, i created a similar script for
                                    pi0w(armv6l) as electron doesn’t exist anymore
                                    try this script
                                    curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >~/MagicMirror/run-start.sh
                                    chmod +x ~/MagicMirror/run-start.sh
                                    then
                                    ./run-start.sh
                                    • K
                                      kellogg76 @sdetweil
                                      ./run-start.sh
                                      When I run
                                      I get command not found, so I tried
                                      chromium  --app=https://cnn.com
                                      and I get Illegal Instruction.
                                      i tried your script, and I get the text on screen about no helper found etc, then it gets stuck when trying to fetch the calendar data. I can access it from another computer but the pi is still blank on screen
                                      Edit: It does seem to go through the calendar step but just very slowly, still progressing to each successive calendar now. I’ll leave it running and see if it eventually successfully starts.
                                        sdetweil @kellogg76
                                        @kellogg76 no… its stuck with the chromium-browser not loading…
                                        I think u need to reinstall the chromium browser…
                                        this means there was an update , or there is an sd card problem…
                                        • K
                                          kellogg76 @sdetweil
                                          @sdetweil looks like the quickest fix is to re-install again. It’s a pain as I probably have to do this about once or twice a year. It can be working great then either the power will unexpectedly go out or I’ll shut it down for some reason and then it takes a full wipe and re-install to get it working again.
                                            sdetweil @kellogg76
                                            @kellogg76 use my install script
                                            see here
                                            rename existing MM folder out of the way
                                            run the install script… it does everything…
                                            (well, not install chromium browser)
                                            sudo apt-get install chromium-browser
