    MM on Pi Zero fails after being off for a few days
    27 Posts 2 Posters 8.1k Views 2 Watching
      sdetweil @kellogg76
      @kellogg76 ok, do
      pm2 status
      it seems there is something already running
      • K Offline
        kellogg76
        Everything was stopped.
        $ pm2 status
        │ id │ name               │ mode     │ ↺    │ status   │ cpu      │ memory   │
        │ 0  │ mmstart            │ fork     │ 1780 │ stopped  │ 0%       │ 0b       │
          sdetweil @kellogg76
          @kellogg76 pm2 info 0
          • K Offline
            kellogg76 @sdetweil
            Describing process with id 0 - name mmstart
            │ status            │ stopped                              │
            │ name              │ mmstart                              │
            │ version           │ N/A                                  │
            │ restarts          │ 1780                                 │
            │ uptime            │ 0                                    │
            │ script path       │ /home/pi/mmstart.sh                  │
            │ script args       │ N/A                                  │
            │ error log path    │ /home/pi/.pm2/logs/mmstart-error.log │
            │ out log path      │ /home/pi/.pm2/logs/mmstart-out.log   │
            │ pid path          │ /home/pi/.pm2/pids/mmstart-0.pid     │
            │ interpreter       │ bash                                 │
            │ interpreter args  │ N/A                                  │
            │ script id         │ 0                                    │
            │ exec cwd          │ /home/pi                             │
            │ exec mode         │ fork_mode                            │
            │ node.js version   │ N/A                                  │
            │ node env          │ N/A                                  │
            │ watch & reload    │ ✘                                    │
            │ unstable restarts │ 0                                    │
            │ created at        │ 2020-03-28T19:51:14.338Z             │
            Divergent env variables from local env
            │ SSH_CONNECTION │ 192.168.1.148 54823 192.168.1.166 22 │
            │ XDG_SESSION_ID │ c2                                   │
            │ SSH_CLIENT     │ 192.168.1.148 54823 22               │
            │ SSH_TTY        │ /dev/pts/1                           │
            Add your own code metrics: http://bit.ly/code-metrics
            Use `pm2 logs mmstart [--lines 1000]` to display logs
            Use `pm2 env 0` to display environment variables
            Use `pm2 monit` to monitor CPU and Memory usage mmstart
              sdetweil @kellogg76
              @kellogg76 said in MM on Pi Zero fails after being off for a few days:
              /home/pi/mmstart.sh
              can u show that file
              • K Offline
                kellogg76 @sdetweil
                #!/bin/bash
                node serveronly &
                sleep 30
                xinit /home/pi/chromium_start.sh
                  sdetweil @kellogg76
                  and that one?
                  • K Offline
                    kellogg76 @sdetweil
                    #!/bin/sh
                    unclutter &
                    xset -dpms # disable DPMS (Energy Star) features.
                    xset s off # disable screen saver
                    xset s noblank # don’t blank the video device
                    matchbox-window-manager &
                    chromium-browser -–incognito --start-fullscreen -–kiosk http://localhost:8080/
                      sdetweil @kellogg76
                      @kellogg76 weird…
                      and if you do pm2 start 0 it works ok?
                      • K Offline
                        kellogg76 @sdetweil
                        @sdetweil it works in as much as I can see the magic mirror on another computer when I point to the correct IP, but the pi itself does not display anything at all, it sits at a terminal prompt or if I reboot and let it try to start on its own it’ll switch from prompt to black screen with mouse pointer as if it’s trying to start, then it loops back to a prompt and cycles between the two states.
