    MMM-MarineWeather
    25 Posts 9 Posters 8.4k Views 10 Watching
      minomit @grena
      @grena loading …
      G B 2 Replies Last reply Reply Quote 0
      • G Offline
        grena Module Developer @minomit
        @minomit said in MMM-MarineWeather:
        loading …
        Okay, on my side it works fine!
        Can you specify your MMM-MarineWeather configuration in the config/config.js file with a copy/paste into a code block (“</>” button) to try to find the problem?
          minomit @grena
          @grena
          latitude: 40.10 , // Latitude
          longitude: 18.52, // Longitude
          appid: “xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx” // StormGlass API key (docs.stormglass.io)
          • G Offline
            @minomit
            With your MMM-MarineWeather configuration, it works fine !
            	module: "MMM-MarineWeather",
            		appid: "414492aa-c717-11e9-a3da-0242ac130004-4144953e-c717-11e9-a3da-0242ac130004" // API Key for your tests
            Since I can’t reproduce your bug, you have to see if there are any error messages in the console! To start MagicMirror with DevTools open, run npm start dev from the MagicMirror folder like this in a terminal cd ~/MagicMirror/ && npm start dev.
              minomit @grena
              @grena I0m copy/past some problem:
                          "pages": {
                                          "tempo reale": "top_right"
                          //position: "top_right",
              edited, PLEASE use the markup around code and config blocks (three backtics on a separate line before and after)
              • G Offline
                @minomit, do you use MMM-Page-Selector ?
                I wanted to do a final test to reproduce your bug by installing MMM-Page-Selector, it works ! So, I added some error messages in the module to get more information but you will have to look at the console when starting MagicMirror with DevTools.
                  ryanbeljan
                  @grena this is a super cool module! I noticed that there are quite a few other weather parameters that the StormGlass API offers (i.e. gust, cloudCover, seaLevel, visibility, etc.) that aren’t yet built into your module. Do you have any tips/guide for how I would go about adding them in?
                  https://docs.stormglass.io/#/weather
                    boivinmi @minomit
                    @grena I also have the same behavior. Here is my config :
                       header: "Marine Weather",
                          latitude: 46.829853,  // Latitude
                          longitude: -71.254028, // Longitude
                          appid: "414492aa-c717-11e9-a3da-0242ac130004-4144953e-c717-11e9-a3da-0242ac130004",
                          dataSource: "sg",
                          params: "airTemperature,windSpeed,windDirection"
                    And result is :
                      Deckard99
                      I’m having the same issue where it just displays “Loading”…….
                      module: “MMM-MarineWeather”,
                      position: “top_right”,
                      latitude: 32.7157,
                      longitude: 117.16,
                      appid: “XXXXXXXX-9a15-11ea-b3e2-0242ac130002-9be8a7f6-9a15-11ea-b3e2-0242ac130002” //StormGlass API Key (docs.stormglass.io)
                      • G Offline
                        grena Module Developer @ryanbeljan
                        @ryanbeljan : Thank you for your positive feedback. I will work on a new version of the module to use the new information of API v2 (currently the module uses API v1) ;)
                        @boivinmi : Currently, it’s not possible to choose the information displayed with params. By removing this line from your configuration, it works fine!
                        @Deckard99 : Indeed, there is a problem with waveHeight at your location (probably because it is a lake and not the sea). In the next version, I will integrate a better detection of this type of error to avoid the total blocking of the module!
                        B D 2 Replies Last reply Reply Quote 0
