    Blank Black screen after the last - 2.11 - update
    20 Posts 5 Posters 7.2k Views 4 Watching
    • K
      kondef @sdetweil
      @sdetweil No i start manually npm start
        sdetweil @kondef
        @kondef so, you should open the dev window
        K 1 Reply Last reply
        • K
          kondef @sdetweil
          @sdetweil You mean npm run start dev ? I am sorry i told you i am not expert. By pressing Control - Shift - i the only thing happens is a small window opens.
            sdetweil @kondef
            @kondef should be the right side of screen
            npm start dev can do the same on startup
            • K
              kondef
              I am getting “DevTools was disconnected from the page. Once page is reloaded, DevTools will automatically reconnect” and the page now is white blank and thre is nothing on the dev console.
              But i managed to take a photo while magic mirror was loading and i got the following: "MODULE NOT FOUND. Require Stack /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js
              /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
              /home/pi/MagicMirror/js/app.js
              /home/pi/MagicMirror/js/electron.js
              /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.
              S M 2 Replies Last reply
                sdetweil @kondef
                @kondef images don’t post…
                • K
                  kondef @sdetweil
                  Please note that i already did npm install on Hotword module
                    sdetweil @kondef
                    @kondef yeh, hotword needs an electron-rebuild I think
                    • K
                      kondef @sdetweil
                      @sdetweil How? I tried to update snowboy but i am getting an error.
                      S 2 Replies Last reply
                        sdetweil @kondef
                        @kondef I don’t know right now. Be a few hours til I have time to test myself
                          sdetweil @kondef
                          @kondef the doc for hotword install says
                          if troubles do
                          git clone https://github.com/Kitt-AI/snowboy.git
                          cd snowboy
                          rm -rf .git
                          cp -r resources/models ..
                          npm install -y nan node-pre-gyp
                          ./node_modules/node-pre-gyp/bin/node-pre-gyp clean configure build
                          npm install -y
                          npm install -y electron-rebuild
                          ./node_modules/.bin/electron-rebuild
                            mattx38 @kondef
                            @kondef you can see my topic where @sdetweil helped me to solve issues.
                            At this time, my mirror works again, excepted the Remote-Control module.
                            Don’t worry, your mirror will come back well soon also for you ;-)
                            • K
                              kondef @mattx38
                              @mattx38 @sdetweil thank you so much guys for your immediate response. I actually deleted the hotword folder and reinstall again and now works fine. Now i am searching for a calendar that i can add multiple ones and to have a fancy -but not taking much space- look. Any ideas?
                                rcikahskd
                                Did anyone solve the issue?
                                  sdetweil @rcikahskd
                                  @rcikahskd which issue?
