    Blank Black screen after the last - 2.11 - update
    20 Posts 5 Posters 6.9k Views 4 Watching
      sdetweil @kondef
      @kondef should be the right side of screen
      npm start dev can do the same on startup
      • K Offline
        kondef
        I am getting “DevTools was disconnected from the page. Once page is reloaded, DevTools will automatically reconnect” and the page now is white blank and thre is nothing on the dev console.
        But i managed to take a photo while magic mirror was loading and i got the following: "MODULE NOT FOUND. Require Stack /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js
        /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
        /home/pi/MagicMirror/js/app.js
        /home/pi/MagicMirror/js/electron.js
        /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.
          sdetweil @kondef
          @kondef images don’t post…
          • K Offline
            kondef @sdetweil
            Please note that i already did npm install on Hotword module
              sdetweil @kondef
              @kondef yeh, hotword needs an electron-rebuild I think
              • K Offline
                kondef @sdetweil
                @sdetweil How? I tried to update snowboy but i am getting an error.
                  sdetweil @kondef
                  @kondef I don’t know right now. Be a few hours til I have time to test myself
                    sdetweil @kondef
                    @kondef the doc for hotword install says
                    if troubles do
                    git clone https://github.com/Kitt-AI/snowboy.git
                    cd snowboy
                    rm -rf .git
                    cp -r resources/models ..
                    npm install -y nan node-pre-gyp
                    ./node_modules/node-pre-gyp/bin/node-pre-gyp clean configure build
                    npm install -y
                    npm install -y electron-rebuild
                    ./node_modules/.bin/electron-rebuild
                      mattx38 @kondef
                      @kondef you can see my topic where @sdetweil helped me to solve issues.
                      At this time, my mirror works again, excepted the Remote-Control module.
                      Don’t worry, your mirror will come back well soon also for you ;-)
                      • K Offline
                        kondef @mattx38
                        @mattx38 @sdetweil thank you so much guys for your immediate response. I actually deleted the hotword folder and reinstall again and now works fine. Now i am searching for a calendar that i can add multiple ones and to have a fancy -but not taking much space- look. Any ideas?
                          rcikahskd
                          Did anyone solve the issue?
                            sdetweil @rcikahskd
                            @rcikahskd which issue?
