    Blank Black screen after the last - 2.11 - update
    20 Posts 5 Posters 7.2k Views 4 Watching
      sdetweil @kondef
      @kondef so, you should open the dev window
      K 1 Reply Last reply
      • K
        kondef @sdetweil
        @sdetweil You mean npm run start dev ? I am sorry i told you i am not expert. By pressing Control - Shift - i the only thing happens is a small window opens.
          sdetweil @kondef
          @kondef should be the right side of screen
          npm start dev can do the same on startup
          • K
            kondef
            I am getting “DevTools was disconnected from the page. Once page is reloaded, DevTools will automatically reconnect” and the page now is white blank and thre is nothing on the dev console.
            But i managed to take a photo while magic mirror was loading and i got the following: "MODULE NOT FOUND. Require Stack /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js
            /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
            /home/pi/MagicMirror/js/app.js
            /home/pi/MagicMirror/js/electron.js
            /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.
            S M 2 Replies Last reply
              sdetweil @kondef
              @kondef images don’t post…
              • K
                kondef @sdetweil
                Please note that i already did npm install on Hotword module
                  sdetweil @kondef
                  @kondef yeh, hotword needs an electron-rebuild I think
                  • K
                    kondef @sdetweil
                    @sdetweil How? I tried to update snowboy but i am getting an error.
                    S 2 Replies Last reply
                      sdetweil @kondef
                      @kondef I don’t know right now. Be a few hours til I have time to test myself
                        sdetweil @kondef
                        @kondef the doc for hotword install says
                        if troubles do
                        git clone https://github.com/Kitt-AI/snowboy.git
                        cd snowboy
                        rm -rf .git
                        cp -r resources/models ..
                        npm install -y nan node-pre-gyp
                        ./node_modules/node-pre-gyp/bin/node-pre-gyp clean configure build
                        npm install -y
                        npm install -y electron-rebuild
                        ./node_modules/.bin/electron-rebuild
                          mattx38 @kondef
                          @kondef you can see my topic where @sdetweil helped me to solve issues.
                          At this time, my mirror works again, excepted the Remote-Control module.
                          Don’t worry, your mirror will come back well soon also for you ;-)
                          • K
                            kondef @mattx38
                            @mattx38 @sdetweil thank you so much guys for your immediate response. I actually deleted the hotword folder and reinstall again and now works fine. Now i am searching for a calendar that i can add multiple ones and to have a fancy -but not taking much space- look. Any ideas?
                              rcikahskd
                              Did anyone solve the issue?
                                sdetweil @rcikahskd
                                @rcikahskd which issue?
