Solved Has anyone got MMM-Remote-Control working on MM 2.11 ?
I have updated my MM with git pull & npm install …than I had the same problem.
Today I tried Sam‘s Upgrade Script and now everything is working perfect. -
I had a copy of the old file socketclient.js located in MagicMirror/js folder. once I replaced the new new file with the backup it is working.
Here is the Key line that needs fixed.replace
// Private Methods self.socket = io("/" + self.moduleName, { path: window.location.pathname + "socket.io" });
with
// Private Methods self.socket = io("/" + self.moduleName);
so your are running MM v2.11.0 with MMM-RemoteControl and all your Menu Items work?
E.g. if I open
192.168.xxx.yyy:8080/remote.html#main-menu
in the browser and click onEdit config.js
the popup opening only contains 3 lines withundefined
@karsten13 yes mine appears to be working, but I don’t edit my config there, I edit via SSH.
I can’t seem to get the upload screenshot to work, but yes I see all my modules.
@karsten13 for me it works after upgrade with sams script
@RoadRunnr1469 said in Has anyone got MMM-Remote-Control working on MM 2.11 ?:
posting images is broken
may you can post the content of your
./js/socketclient.js
So please go into the magicmirror folder and executecat ./js/socketclient.js
and post the output here. Thanks. -
var MMSocket = function(moduleName) { var self = this; if (typeof moduleName !== "string") { throw new Error("Please set the module name for the MMSocket."); } self.moduleName = moduleName; // Private Methods self.socket = io("/" + self.moduleName); var notificationCallback = function() {}; var onevent = self.socket.onevent; self.socket.onevent = function(packet) { var args = packet.data || []; onevent.call(this, packet); // original call packet.data = ["*"].concat(args); onevent.call(this, packet); // additional call to catch-all }; // register catch all. self.socket.on("*", function(notification, payload) { if (notification !== "*") { notificationCallback(notification, payload); } }); // Public Methods this.setNotificationCallback = function(callback) { notificationCallback = callback; }; this.sendNotification = function(notification, payload) { if (typeof payload === "undefined") { payload = {}; } self.socket.emit(notification, payload); }; };
didn’t ask you, because I know your socketclient.js, you applied my patch …
