    Has anyone got MMM-Remote-Control working on MM 2.11 ?
    31 Posts 8 Posters 16.3k Views 9 Watching
    • karsten13K Offline
      karsten13 @Stoffbeuteluwe
      @Stoffbeuteluwe
      so your are running MM v2.11.0 with MMM-RemoteControl and all your Menu Items work?
      E.g. if I open 192.168.xxx.yyy:8080/remote.html#main-menu in the browser and click on Edit config.js the popup opening only contains 3 lines with undefined.
      R StoffbeuteluweS 2 Replies Last reply Reply Quote 0
        RoadRunnr1469 @karsten13
        @karsten13 yes mine appears to be working, but I don’t edit my config there, I edit via SSH.
        I can’t seem to get the upload screenshot to work, but yes I see all my modules.
        • StoffbeuteluweS Offline
          Stoffbeuteluwe Project Sponsor @karsten13
          @karsten13 for me it works after upgrade with sams script
            sdetweil @RoadRunnr1469
            @RoadRunnr1469 said in Has anyone got MMM-Remote-Control working on MM 2.11 ?:
            posting images is broken
            https://github.com/MichMich/MagicMirror/issues/1969
              @Stoffbeuteluwe
              may you can post the content of your ./js/socketclient.js?
              So please go into the magicmirror folder and execute cat ./js/socketclient.js and post the output here. Thanks.
                @karsten13
                var MMSocket = function(moduleName) {
                	var self = this;
                	if (typeof moduleName !== "string") {
                		throw new Error("Please set the module name for the MMSocket.");
                	self.moduleName = moduleName;
                	// Private Methods
                	self.socket = io("/" + self.moduleName);
                	var notificationCallback = function() {};
                	var onevent = self.socket.onevent;
                	self.socket.onevent = function(packet) {
                		var args = packet.data || [];
                		onevent.call(this, packet);    // original call
                		packet.data = ["*"].concat(args);
                		onevent.call(this, packet);      // additional call to catch-all
                	// register catch all.
                	self.socket.on("*", function(notification, payload) {
                		if (notification !== "*") {
                			notificationCallback(notification, payload);
                	// Public Methods
                	this.setNotificationCallback = function(callback) {
                		notificationCallback = callback;
                	this.sendNotification = function(notification, payload) {
                		if (typeof payload === "undefined") {
                			payload = {};
                		self.socket.emit(notification, payload);
                  karsten13 @RoadRunnr1469
                  @RoadRunnr1469
                  didn’t ask you, because I know your socketclient.js, you applied my patch …
                    @karsten13 actually no I didn’t. I had backed up my entire MagicMirror folder and all sub folders before upgrading. I saw another post where they said they changed the socketclient back to before upgrade. so I did the same thing. after making a backup of the new socketclient.js file.
                      Stoffbeuteluwe Project Sponsor @RoadRunnr1469
                      @RoadRunnr1469 so…After restart MM …Remote Control is not working anymore :worried_face:
                        sdetweil @Stoffbeuteluwe
                        @Stoffbeuteluwe put his fix on the js/socketclient.js
                        • 1 / 4
