Solved MM on Ubuntu
@sdetweil My config file says config.js.sample
Is that suppose or? -
@goncalovsc no…
config.js
there should be two files in the folder… config.js.sample (original as shipped )
config.js (copied from sample at install time), used from then on as live config -
@sdetweil It only came with this one at install. Should I copy this one and rename it to config.js?
@goncalovsc how did u do install?
it should not run without config.js
@sdetweil I installed with the command you gave on the beggining of this thread
@sdetweil said in MM on Ubuntu:
cd ~/MagicMirror/config
Here you have - https://gyazo.com/18000e7546ea27b9c3682acd33c1d27a
@goncalovsc config.js is present… which file did u edit?
@sdetweil now its present because i copied it from config.js.sample and renamed it
@goncalovsc show me
~/install.log
