    Installing modules on windows
    16 Posts 2 Posters 7.0k Views 2 Watching
    • V
      vintage89 @sdetweil
      @sdetweil Tried installing this module https://github.com/Thlb/MMM-synology-ds
        sdetweil @vintage89
        @vintage89 said in Installing modules on windows:
        ok, that installed, fine, but has an embedded component that is electron version sensitive
        so
        npm install electron-rebuild
        cd modules/MMM-synology-ds
        ../../node_modules/.bin/electron-rebuild
        npm start
        • V
          vintage89
          I´ve run the script, but when I tried to start it gave me this:
          > magicmirror@2.11.0 start /home/pi/MagicMirror
          > electron js/electron.js
          (electron:8589): Gtk-WARNING **: 14:59:29.032: cannot open display:
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! magicmirror@2.11.0 start: `electron js/electron.js`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.11.0 start script.
          npm ERR!     /home/pi/.npm/_logs/2020-04-11T12_59_29_059Z-debug.log
          I changed the package.json to this - like you said in my other post:
            sdetweil @vintage89
            @vintage89 do
            export DISPLAY=:0
            then
            npm start
            these two steps are what the original code did, would have worked on linux… just not on Windows…
            windows doesn’t have ‘xwindows display’
            V 2 Replies Last reply
            • V
              vintage89 @sdetweil
              Gave me this, did I do something wrong? :)
              pi@raspberrypi:~ $ export DISPLAY=:0
              pi@raspberrypi:~ $ cd MagicMirror/
              (electron:813): Gtk-WARNING **: 15:08:03.027: cannot open display: :0
              npm ERR! errno 1
              npm ERR!
              npm ERR!     /home/pi/.npm/_logs/2020-04-11T13_08_03_102Z-debug.log
              • V
                vintage89 @sdetweil
                @sdetweil ahh, sorry - forgot to mention that I got my rassberry today, so I’m on a raspberry now. My bad!!
                  sdetweil @vintage89
                  @vintage89 how are u connected to the pi? ssh, vnc, on the monitor?
                  and you are using the graphical desktop version of Raspian, right?? u must to display on the pi…
                  V 1 Reply Last reply
                  • V
                    vintage89 @sdetweil
                    I’m connected via ssh and vnc. I managed to start it with the original config.json. It’s after I put in the synology-module that everything went out the window.
                      sdetweil @vintage89
                      @vintage89 eh… I cut/pasted the sample config for that module into config.js at the end of the module list and it came up just fine
                      • V
                        vintage89 @sdetweil
                        I´ll try and start from scratch again :)
                        So If I understand you correctly - I don’t have to change the package.json when I’m on the raspberry? :)
                        S 2 Replies Last reply
                          sdetweil @vintage89
                          @vintage89 correct… (long as its a pi3 or 4)
                            sdetweil @vintage89
                            @vintage89 u don’t need to start from scratch… just copy the config/config.js.sample to config/config.js
                            • V
                              vintage89
                              @sdetweil Hehe, allready did - and now things are playing along well :D Thanks alot!
