    Installing modules on windows
    16 Posts 2 Posters 7.0k Views 2 Watching
      sdetweil @vintage89
      @vintage89 said in Installing modules on windows:
      https://github.com/Thlb/MMM-synology-ds
      ok, that installed, fine, but has an embedded component that is electron version sensitive
      so
      npm install electron-rebuild
      cd modules/MMM-synology-ds
      ../../node_modules/.bin/electron-rebuild
      npm start
      • V
        vintage89
        I´ve run the script, but when I tried to start it gave me this:
        > magicmirror@2.11.0 start /home/pi/MagicMirror
        > electron js/electron.js
        (electron:8589): Gtk-WARNING **: 14:59:29.032: cannot open display:
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! magicmirror@2.11.0 start: `electron js/electron.js`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the magicmirror@2.11.0 start script.
        npm ERR!     /home/pi/.npm/_logs/2020-04-11T12_59_29_059Z-debug.log
        I changed the package.json to this - like you said in my other post:
          sdetweil @vintage89
          @vintage89 do
          export DISPLAY=:0
          then
          npm start
          these two steps are what the original code did, would have worked on linux… just not on Windows…
          windows doesn’t have ‘xwindows display’
          V 2 Replies Last reply
          • V
            vintage89 @sdetweil
            Gave me this, did I do something wrong? :)
            pi@raspberrypi:~ $ export DISPLAY=:0
            pi@raspberrypi:~ $ cd MagicMirror/
            (electron:813): Gtk-WARNING **: 15:08:03.027: cannot open display: :0
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /home/pi/.npm/_logs/2020-04-11T13_08_03_102Z-debug.log
            • V
              vintage89 @sdetweil
              @sdetweil ahh, sorry - forgot to mention that I got my rassberry today, so I’m on a raspberry now. My bad!!
                sdetweil @vintage89
                @vintage89 how are u connected to the pi? ssh, vnc, on the monitor?
                and you are using the graphical desktop version of Raspian, right?? u must to display on the pi…
                V 1 Reply Last reply
                • V
                  vintage89 @sdetweil
                  I’m connected via ssh and vnc. I managed to start it with the original config.json. It’s after I put in the synology-module that everything went out the window.
                    sdetweil @vintage89
                    @vintage89 eh… I cut/pasted the sample config for that module into config.js at the end of the module list and it came up just fine
                    • V
                      vintage89 @sdetweil
                      I´ll try and start from scratch again :)
                      So If I understand you correctly - I don’t have to change the package.json when I’m on the raspberry? :)
                      S 2 Replies Last reply
                        sdetweil @vintage89
                        @vintage89 correct… (long as its a pi3 or 4)
                          sdetweil @vintage89
                          @vintage89 u don’t need to start from scratch… just copy the config/config.js.sample to config/config.js
                          • V
                            vintage89
                            @sdetweil Hehe, allready did - and now things are playing along well :D Thanks alot!
