    MMM-Hotword
    60 Posts 20 Posters 36.1k Views 17 Watching
      sdetweil @cjdzombie
      @cjdzombie i just installed MMM-Hotword, and had the errors documented in the install.
      I followed the steps exactly, cutting and pasting, and those issues were resolved… MMM-Hotword works perfectly now
      • A
        Artech
        @Sean at first thank you for your module however I have some difficulties in installing the snowboy library if you or someone else has a procedure I will follow it
          berne
          mmm i notis i have a update, how do i get it?
          ? 1 Reply Last reply
            A Former User @berne
            @berne If you have no issue on your usage, you don’t need to update. Nothing important is not updated.
              berne
              @Sean
              running MM v2.8.0
              dont running 2.0 on this
              ? B 2 Replies Last reply
                @berne The easiest way is, reinstall freshly.
                  berne @berne
                  @berne i iam happy using the old one, know how hard it was to get i all set up. a qick questien… how do i change the screen size on the MM? i just geting it in the middel and not full scale
                  • T
                    t.architecture99
                      A Former User @t.architecture99
                      @t-architecture99
                      icons: { //https://iconify.design/icon-sets/
                            waiting: "uil-comment-message",
                            detected: "uil-comment-exclamation",
                            finished: "uil-comment-dots",
                        Mrtrol2013
                        Does this module support Russian?
                          A Former User
                          i think yes, MMM-Hotword should be supported
                          C 1 Reply Last reply
                            cheun @Guest
                            Hello everybody,
                            Today I tried to install MMM-Hotword from https://github.com/eouia/MMM-Hotword.git but I get à 404 error.
                            It seems the page has been moved or disabled.
                            If so, could someone send me the contents of the git?
                            Thank you in advance for your help!
                              A Former User
                              hummm, yes I have disabled it.
                              but why do you want to use it ?
                                cheun @Guest
                                @Bugsounet Hello,
                                I just wanted to use this module to custom my magic mirror hotword détection.
                                Sorry for my numb question but why disable this fantastic module? Or is there a new one updated?
                                Thank you so much
                                • H
                                  hayman
                                  @berne said in MMM-Hotword:
                                  hello ,im trying to update the MMM-Hotword but keep asking the user&pw of the site after entering them i get wrong psww …?
                                  is there any other wat to update it …?
                                  thanks
                                    A Former User
                                    @cheun: give me a good example of use ? (If you don’t use an assistant)
                                    @hayman : It seems you are using an assistant so … It’s not needed. You can use ONLY one detector at once
                                      sdetweil @hayman
                                      @hayman those are YOUR user Id and password on GitHub, right?
                                        cheun @Guest
                                        @Bugsounet
                                        Thank you for your answer.
                                        I only want to make a smart mirror with a Google assistant (MMM-AssistantMk2) with a custom hotword.
                                        I followed this tutorial :
                                        https://github.com/makepluscode/rpi-tutorial-advanced/tree/master/008-raspbian-magicmirror-google-assistant-latest
                                        I followed it except I’m running on Buster (vs Stretch in the tuto).
                                        I guess things have changed since the year of publication of this tutorial.
                                        Hope I answerd your question.
                                          A Former User
                                          humm yes but … outdated installation sources and will never work
                                          I have deprecied MMM-AssistantMk2 too (and it use embed detector)
                                          so MMM-Hotword not needed
                                            cheun @Guest
                                            @Bugsounet
                                            Ok,thank you.
                                            So which module(s) do you suggest to make work a Google assistant ?
                                            • 3 / 3
