    MMM-Hotword
    60 Posts 20 Posters 36.1k Views 17 Watching
      berne
      mmm i notis i have a update, how do i get it?
      ? 1 Reply Last reply
        A Former User @berne
        @berne If you have no issue on your usage, you don’t need to update. Nothing important is not updated.
          berne
          @Sean
          running MM v2.8.0
          dont running 2.0 on this
          ? B 2 Replies Last reply
            @berne The easiest way is, reinstall freshly.
              berne @berne
              @berne i iam happy using the old one, know how hard it was to get i all set up. a qick questien… how do i change the screen size on the MM? i just geting it in the middel and not full scale
              • T
                t.architecture99
                  A Former User @t.architecture99
                  @t-architecture99
                  icons: { //https://iconify.design/icon-sets/
                        waiting: "uil-comment-message",
                        detected: "uil-comment-exclamation",
                        finished: "uil-comment-dots",
                    Mrtrol2013
                    Does this module support Russian?
                      A Former User
                      i think yes, MMM-Hotword should be supported
                      C 1 Reply Last reply
                        cheun @Guest
                        Hello everybody,
                        Today I tried to install MMM-Hotword from https://github.com/eouia/MMM-Hotword.git but I get à 404 error.
                        It seems the page has been moved or disabled.
                        If so, could someone send me the contents of the git?
                        Thank you in advance for your help!
                          A Former User
                          hummm, yes I have disabled it.
                          but why do you want to use it ?
                            cheun @Guest
                            @Bugsounet Hello,
                            I just wanted to use this module to custom my magic mirror hotword détection.
                            Sorry for my numb question but why disable this fantastic module? Or is there a new one updated?
                            Thank you so much
                            • H
                              hayman
                              @berne said in MMM-Hotword:
                              hello ,im trying to update the MMM-Hotword but keep asking the user&pw of the site after entering them i get wrong psww …?
                              is there any other wat to update it …?
                              thanks
                                A Former User
                                @cheun: give me a good example of use ? (If you don’t use an assistant)
                                @hayman : It seems you are using an assistant so … It’s not needed. You can use ONLY one detector at once
                                  sdetweil @hayman
                                  @hayman those are YOUR user Id and password on GitHub, right?
                                    cheun @Guest
                                    @Bugsounet
                                    Thank you for your answer.
                                    I only want to make a smart mirror with a Google assistant (MMM-AssistantMk2) with a custom hotword.
                                    I followed this tutorial :
                                    https://github.com/makepluscode/rpi-tutorial-advanced/tree/master/008-raspbian-magicmirror-google-assistant-latest
                                    I followed it except I’m running on Buster (vs Stretch in the tuto).
                                    I guess things have changed since the year of publication of this tutorial.
                                    Hope I answerd your question.
                                      A Former User
                                      humm yes but … outdated installation sources and will never work
                                      I have deprecied MMM-AssistantMk2 too (and it use embed detector)
                                      so MMM-Hotword not needed
                                        cheun @Guest
                                        @Bugsounet
                                        Ok,thank you.
                                        So which module(s) do you suggest to make work a Google assistant ?
                                          A Former User
                                          i code this : MMM-GoogleAssistant and MMM-Assistant2Display (extension and addons) there
                                            cheun @Guest
                                            @Bugsounet
                                            thank you very much for putting me on the right way!
                                            last question: is it possible to change language of the assistant to an other (french for exemple)
                                            • 3 / 3
