    {HowTo} turn on/off your monitor (Time based, PIR/Button, App)
    171 Posts 39 Posters 355.8k Views 54 Watching
      chandra @cruunnerr
      @cruunnerr said in {HowTo} turn on/off your monitor (Time based, PIR/Button, App):
      @chandra said in {HowTo} turn on/off your monitor (Time based, PIR/Button, App):
      Screen goes off after 120sec, But when it sense the motion, the screen is black.
      Hint from the main post:
      To check if it works just go into terminal via ssh and type:
      sudo tvservice -o to turn off
      sudo tvservice -p to turn on
      edit: for some monitors the following commands work better. Please use them if your monitor needs it:
      vcgencmd display_power 0 to turn off
      vcgencmd display_power 1 to turn on
      edit:
      also check this:
      https://forum.magicmirror.builders/topic/6291/howto-turn-on-off-your-monitor-time-based-pir-button-app/11
      A Big Thanks to all. Gone through all the posts.
      I split up the things.
      First, checked the screen on and off (by editing the script). Tried the steps. screen on was the problem. so skipped that.
      second, checked the led lights on and off alone. It worked like a charm.
      Then gone back to screen on to work together. The problem was with monitor,old one,connected by hdmi-vga adapter.
      Found a solution:
      Added
      sudo tvservice -p
      sudo chvt 9 && sudo chvt 7
      This worked :smiling_face_with_heart-eyes: .
      Now , both working together. I used your lights_on.sh and lights_off.sh and modified as per my liking.
      • T
        teitlebot
        • T
          thoeng
          @cruunnerr
          I have the strangest problem i have not been able to solve for days now.
          I am using 2.2 external pir.py script and it works flawlessly to display blank screen.
          However, if screen orientation set to vertical via /boot/config.txt with either display_rotate=1 or 3, the monitor wont blank out !! :dizzy_face:
          Its just blink for 1 second and nothing happen.
          What I have tried:
          1. check monitor status via xset -q (dpms) - it says monitor off but the TV stays on
          2. run xset dpms force off - again the TV only blink for 1 second nothing else happen
          3. Changed GL driver from raspi-config and reboot
          4. Tried with other TV (both are LG brand 42" and 65")
          Both tvservice -p and vcgencmd display_power 0 will work with any screen orientation but unfortunately it will display “no signal” on the TV.
          Can anybody please help me out? This is really frustrating :dizzy_face: :dizzy_face:
          • T
            tinsebayacc
            Hi, i have followed the steps in 2.2, it works fine. The issue i have is i don’t want the screen turning off because of my silly lg tv screen saver which i cant disable. So i followed the steps for this in section 6. I created two new screen.sh files, made them executable and changed the relevant bits in the pir.py script. Now nothing happens. i have tried and checked again and again but nothing happens. I am fairly new to all of this and have probably missed something i just dont know what. Please could someone help me with this. Thank you very much
            • A
              Asphyth
              Hi, ! thanks for this GREEATTTTT TUTORIAL !
              Working great with python,
              About that, when my screen is turning down he shows “No signal” before turning black, any solution to hide this ?
              P S 2 Replies Last reply
                pugsly @Asphyth
                @Asphyth That is your monitor, its not coming from the Pi.
                  sdetweil @Asphyth
                  @Asphyth that is the energy star power down requirement. it warns you of no signal, and then is required to turn the display off electrically to save power
                    pascal006
                    hi!!
                    for this point the … always running i dont have LED to make a test . So my question is do i did a mistake someware ?
                    You can check if your button works by simply typing python pir.py. Every time u move through the PIR or press the button it will show you several …
                    End the test with “ctrl+c”
                      Peter Leemon
                      Hi all have followed step 2.1 got my tv to turn off and back on ok but doesn’t stay on for long at all (only a few seconds)?
                      • F
                        FREIGHTTRAIN
                        FoziF 1 Reply Last reply
                        • FoziF
                          Fozi Project Sponsor @FREIGHTTRAIN
                          @FREIGHTTRAIN Can you elaborate more precisely, what is not working? What have you done? What is the expected behaviour? How does it behave? How to reproduce? That might help in helping you.
                            drk-geek @cruunnerr
                            hi @cruunnerr
                            I just installed it, everything looks good but not working at all. I tried via 2.1 Using PIR-Module and 2.2 Using PIR-Script both not working, any suggestion how to check where the issue is?
                              deebee999 @cruunnerr
                              @cruunnerr
                              I have had success with your help and my PIR sensor but only after running pir.py from .bashrc
                              The script is working however I read the following warning when accessing my Magic Mirror with SSH:
                              RuntimeWarning. This channel is already in use, continuing anyway. io.setup(LED_PIN, io.OUT)
                              My end result is not affected. The PIR works fine.
                              Thank you
                                maptecnet
                                Just a little feedback that was a huge help for me.
                                @cruunnerr don’t know if you want to add this information on your first message.
                                I have a samsung d6000 series tv that wouldn’t work anyway with modules for PIR sensor. A BIG aplause for all developers but i coudn’t get the tv out of “No Signal” message. The MagicMirror would turn image off but tv only in “No Signal”.
                                I’m not a programmer and just went on test and try.
                                I figured out that the https://github.com/bugsounet/MMM-NewPIR from @Bugsounet (BIG thanks to you also!) managed the problem!!
                                With this module set to mode: 4 - use HDMI CEC the TV shuts down when the MagicMirror tells her to shut down!
                                It’s straight through ON and OFF as expected!
                                I’me very thankful to you all managing to help us out!
                                Thanks!
                                • U
                                  ulster
                                  @cruunnerr
                                  its possible to kill 2.2 Using PIR-Script in rasp pi?
                                  Can you tell me how I cans do it please?
                                  thanks
                                    sdetweil @ulster
                                    @ulster kill 2.2 what?
                                    U 1 Reply Last reply
                                    • U
                                      ulster @sdetweil
                                      This one. Mentioned in the first page.
                                      how to remove it?
                                      #!/usr/bin/env python
                                      import sys
                                      import time
                                      import RPi.GPIO as io
                                      import subprocess
                                      io.setmode(io.BCM)
                                      SHUTOFF_DELAY = 120 # in seconds, how long the monitor will be on until next button press or PIR detection
                                      PIR_PIN = 22 # 15 on the board (this needn’t to be a PIR. Can be a button also)
                                      LED_PIN = 16 # optional, don’t use as Relay-PIN. It just shows detection time of the PIR without delay time
                                      def main():
                                      io.setup(PIR_PIN, io.IN)
                                      turned_off = False
                                      last_motion_time = time.time()
                                      while True:
                                          if io.input(PIR_PIN):
                                              io.output(LED_PIN, io.LOW)
                                              print ".",
                                              sys.stdout.flush()
                                              if turned_off:
                                                  turned_off = False
                                                  turn_on()
                                          else:
                                              if not turned_off and time.time() > (last_motion_time +
        SHUTOFF_DELAY):
                                                  turned_off = True
                                                  turn_off()
                                              if not turned_off and time.time() > (last_motion_time + 1):
                                                  io.output(LED_PIN, io.HIGH)
                                          time.sleep(.1)
                                      def turn_on():
                                      subprocess.call(“sh /home/pi/monitor_on.sh”, shell=True)
                                      def turn_off():
                                      subprocess.call(“sh /home/pi/monitor_off.sh”, shell=True)
                                      if name == ‘main’:
                                      try:
                                      main()
                                      except KeyboardInterrupt:
                                      io.cleanup()
                                        sdetweil @ulster
                                        @ulster sorry, i dont know anything about the module and dont read ( or re-read) every page of posts
                                        • A
                                          andi.aw.weiss
                                          Hello everyone, I’m getting desperate. I’ve now read the entire tutorial but I can’t find my mistake.
                                          I am using my MM with a PIR sensor and would like to switch the backlight of the display with a relay. so i use this script pir.py:
                                          import sys
                                          import time
                                          import subprocess
                                          io.setmode(io.BCM)
                                          PIR_PIN = 22       # 15 on the board (this needn't to be a PIR. Can be a button also)
                                          def main():
                                              turned_off = False
                                              while True:
                                                      print ".",
                                                      sys.stdout.flush()
                                                      if turned_off:
                                                          turned_off = False
                                                          turn_on()
                                                  else:
        SHUTOFF_DELAY):
                                                          turned_off = True
                                                          turn_off()
                                                  time.sleep(.1)
                                          def turn_on():
                                          	subprocess.call("sh /home/pi/monitor_on.sh", shell=True)
                                          def turn_off():
                                          	subprocess.call("sh /home/pi/monitor_off.sh", shell=True)
                                          if __name__ == '__main__':
                                              try:
                                                  main()
                                                  io.cleanup()
                                          Unfortunately, when I run this script in the terminal, I only get the feedback from the PIR sensor (…) but the relay is not switched. But if I run the monitor_on.sh or monitor_off.sh script it works:
                                          monitor_on.sh
                                          gpio -g mode 27 out
                                          sleep 0.2
                                          gpio -g write 27 1
                                          monitor_off.sh
                                          gpio -g mode 27 out
                                          sleep 0.2
                                          gpio -g write 27 0
                                          But the PIR.py doesn’t work. Where could the mistake lie?
                                          Many greetings Andreas
                                          M 1 Reply Last reply
                                            MadScientist @andi.aw.weiss
                                            @andi-aw-weiss I think you are using the wrong script. With just a quick look it seems you’re running the script from point 2.2 (Using PIR script) of the first post. What you want is point 5.2 (Use relay with a PIR). That script used in 5.2 is different than that of 2.2, which does not have code to control the relay.
                                            Have a look at it again.
                                            A 2 Replies Last reply
                                            • 8 / 9
