    Can't clone from GitHub
    107 Posts 3 Posters 88.5k Views 3 Watching
      MMRPi1 @sdetweil
      @sdetweil Raspbian. I tried updating and it still doesn’t work and now I can’t ssh in either for some reason.
        sdetweil @MMRPi1
        @MMRPi1 weird… is ssh running? is there a firewall installed on raspian? (not on any of mine)
        did the pi IP address change?
        M 1 Reply Last reply
          MMRPi1 @sdetweil
          @sdetweil SSH is enabled, there shouldn’t be a firewall on the pi (haven’t changed anything at least) and the pi IP address hasn’t changed.
            sdetweil @MMRPi1
            @MMRPi1 did u reboot windows and it turned the firewall back on…
            M 2 Replies Last reply
              MMRPi1 @sdetweil
              @sdetweil yes
                MMRPi1 @sdetweil
                @sdetweil yes I rebooted windows
                  sdetweil @MMRPi1
                  @MMRPi1 and it turned on the firewall? did u get your ssh connection back?
                    MMRPi1 @sdetweil
                    @sdetweil the firewall is off but the issue persists
                      sdetweil @MMRPi1
                      @MMRPi1 and ping of the pi address works from where the ssh fails?
                        MMRPi1
                        I can’t ping the pi but I’ve checked and the IP hasn’t changed
                          sdetweil @MMRPi1
                          @MMRPi1 then the firewall or antivirus firewall is not off.
                          if ping fails, ssh will never work
                          is the pi behind some network wifi extender?
                            MMRPi1 @sdetweil
                            @sdetweil No.
                              bhepler Module Developer
                              Can you ping from the Pi to your Windows box?
                                sdetweil @MMRPi1
                                @MMRPi1 what is the PC ip address? what is the PI ip address?
                                (no one can get to them as they are behind your router)
                                my desktop is 192.168.2.106
                                my pi is 192.168.2.44
                                nano is 192.168.2.37
                                odroid is 192.168.2.119
                                  sdetweil @bhepler
                                  @bhepler good idea!
                                    MMRPi1 @sdetweil
                                    @sdetweil my desktop is 192.168.0.12, pi is 192.168.0.24. Hold on I’ll try to ping from the pi
                                      MMRPi1 @MMRPi1
                                      @MMRPi1 Also unreachable from the pi it seems
                                        sdetweil @MMRPi1
                                        @MMRPi1 so I would say firewall still on on pc…
                                        can u access mirror app from phone? at pi ip address?
                                          MMRPi1
                                          I’ve also tried from Terminus on iOS and that didn’t work either
                                            sdetweil @MMRPi1
                                            @MMRPi1 on the pi, if you have a keyboard can u ssh to itself?
                                            ssh pi@localhost
                                            works on mine
                                            still doesn’t fix the ping problem
                                            • 2 / 6
