MMM-ModuleScheduler - Module Schedules and Notifications
Description:
A helper module for creating schedules which
- Hide, show or dim individual modules, groups of modules or all modules
- Send notifications to other modules (e.g. to restart/turn off your MagicMirror, turn on/off your screen, and turn off your Pi via MMM-Remote-Control
As ever this is work in progress, so check out the ReadMe file for installation and configuration notes, keep your module updated and do report any issues.
Screenshots:
Add as many screenshots as you like.
Download:
[card:ianperrin/MMM-ModuleScheduler]
Change Log
Version 1.4
- Added global schedules which allow a single schedule to show/hide/dim all modules
- Added group schedules which allow a single schedule to show/hide/dim a subset of modules
- Added support for visibility locking introduced in Magic Mirror 2.1.0
- Added
debug
config option to control output to logs
Version 1.3
- Added ability to schedule sending notifications to other modules
Version 1.2
- Added ability dim modules (instead of hiding them)
Version 1.1.0
- Added support for multiple schedules per module
Version 1.0.1
- Fixed issue with scheduled jobs when browser is refreshed
Version 1.0.0
- Initial version
Awesome module!! The only thing I found it doesn’t work on is the clock…
The clock doesn’t have a config section and if you add it the config won’t load…
@cowboysdude said in MMM-ModuleScheduler:
Can you post an example of your config for the clock with the scheduler options?
The following works for me to show the clock at 5 past each hour and hide in again at quarter past the hour…
{ module: 'clock', position: 'top_left', classes: 'scheduler', config: { module_schedule: {from: '5 * * * *', to: '15 * * * *'}, } },
Well as it turns out… had an issue and had to use my img backup to reinstall the mirror… little did I know I had this already set up and working on the img so it does!!! :)
@cowboysdude Glad to hear it works!
I must have had it setup wrong so that was my fault… like I said it’s working! Thank you!
Just curious would it be possible not to hide but to dim specific modules?
@cowboysdude adding a css filter to the specific module could set the brightness down
@strawberry-3.141 said in MMM-ModuleScheduler:
Great idea - will give it a go ;)
I’ve pushed an update which includes the ability to dim a module. Please feel free to update the module and use the example configuration to test it out.
