    MMM-ModuleScheduler - Module Schedules and Notifications
    moduleschedulecronnotifications
    82 Posts 20 Posters 156.1k Views 20 Watching
    • I Offline
      ianperrin
      Description:
      A helper module for creating schedules which
      • Hide, show or dim individual modules, groups of modules or all modules
      • Send notifications to other modules (e.g. to restart/turn off your MagicMirror, turn on/off your screen, and turn off your Pi via MMM-Remote-Control
      As ever this is work in progress, so check out the ReadMe file for installation and configuration notes, keep your module updated and do report any issues.
      Screenshots:
      Add as many screenshots as you like.
      Example Scheduling
      Download:
      [card:ianperrin/MMM-ModuleScheduler]
      Change Log
      Version 1.4
      • Added global schedules which allow a single schedule to show/hide/dim all modules
      • Added group schedules which allow a single schedule to show/hide/dim a subset of modules
      • Added support for visibility locking introduced in Magic Mirror 2.1.0
      • Added debug config option to control output to logs
      Version 1.3
      • Added ability to schedule sending notifications to other modules
      Version 1.2
      • Added ability dim modules (instead of hiding them)
      Version 1.1.0
      • Added support for multiple schedules per module
      Version 1.0.1
      • Fixed issue with scheduled jobs when browser is refreshed
      Version 1.0.0
      • Initial version
      "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
      • cowboysdudeC Offline
        Awesome module!! The only thing I found it doesn’t work on is the clock…
        The clock doesn’t have a config section and if you add it the config won’t load…
        • I Offline
          ianperrin @cowboysdude
          @cowboysdude said in MMM-ModuleScheduler:
          Can you post an example of your config for the clock with the scheduler options?
          The following works for me to show the clock at 5 past each hour and hide in again at quarter past the hour…
          	module: 'clock',
          	position: 'top_left',
          	classes: 'scheduler',
          		module_schedule: {from: '5 * * * *', to: '15 * * * *'},
            Well as it turns out… had an issue and had to use my img backup to reinstall the mirror… little did I know I had this already set up and working on the img so it does!!! :)
            • I Offline
              @cowboysdude Glad to hear it works!
                I must have had it setup wrong so that was my fault… like I said it’s working! Thank you!
                  Just curious would it be possible not to hide but to dim specific modules?
                  strawberry 3.141S I 2 Replies Last reply Reply Quote 0
                  • strawberry 3.141S Offline
                    strawberry 3.141 Project Sponsor Module Developer @cowboysdude
                    @cowboysdude adding a css filter to the specific module could set the brightness down
                    I 1 Reply Last reply Reply Quote 1
                    • I Offline
                      ianperrin @strawberry 3.141
                      @strawberry-3.141 said in MMM-ModuleScheduler:
                      Great idea - will give it a go ;)
                      • I Offline
                        I’ve pushed an update which includes the ability to dim a module. Please feel free to update the module and use the example configuration to test it out.
                          cowboysdude Module Developer @ianperrin
                          @ianperrin That sir is AWESOME! Thank you!
                            dr4ke616
                            Hey @ianperrin
                            Great module by the way. Im messing about with it, and works really well.
                            Do you think it would be possible to broadcast a notification to the module(s) that are being shown / hidden so they could react to it?
                            So for example if any given module were able to check for SHOW_MODULE, HIDE_MODULE or DIM_MODULE in the notificationReceived function so that the module could react to it and handle some specific behaviour?
                            What do you think?
                              strawberry 3.141 Project Sponsor Module Developer @dr4ke616
                              @dr4ke616 hide module will call the hide method of the module
                              quote from the readme When a module is hidden (using the module.hide() method), the suspend() method will be called. By subclassing this method you can perform tasks like halting the update timers. so you can do the specific behaviour you want in there
                              for show module it’s the resume method
                                dr4ke616 @strawberry 3.141
                                @strawberry-3.141 I didnt notice this - thanks for pointing it out. Thats exactly what i need!
                                  plumcraft
                                  Great idea, i’ve tried your module but i does not work for me. I might have missed a step or something.
                                  I did put in the config file your module (after download and setup with npm install))) :
                                     module: 'MMM-ModuleScheduler'
                                  And then :
                                    module: 'MMM-WunderGround',
                                    position: 'top_right',
                                      module_schedule: {from: '0 14 * * *', to: '0 18 * * *' },
                                      apikey: 'xxxxxxxxx', // private; don't share!
                                  				pws: 'pws:IBOULOGN39', //culemborg
                                  				hourly: '1',
                                  				fctext: '1',
                                  				fcdaycount: "5",
                                  				fcdaystart: "0",
                                  				hourlyinterval: "3",
                                  				hourlycount: "2",
                                  				alerttime: 10000,
                                  				alerttruncatestring: "french:"
                                  			classes: 'for_all default'
                                  It’s 13:30 and the weather is still showing on the mirror.
                                  Thanks for your help
                                    You’re missing the trigger ;)
                                    Here do this:
                                    module: ‘MMM-WunderGround’,
                                    position: ‘top_right’,
                                    module_schedule: {from: ‘0 14 * * *’, to: ‘0 18 * * *’ },
                                    apikey: ‘ad100f1e35ae51d2’, // **private; don’t share!**
                                    pws: ‘pws:IBOULOGN39’, //culemborg
                                    hourly: ‘1’,
                                    fctext: ‘1’,
                                    fcdaycount: “5”,
                                    fcdaystart: “0”,
                                    hourlyinterval: “3”,
                                    hourlycount: “2”,
                                    alerttime: 10000,
                                    alerttruncatestring: “french:”'
                                    • I Offline
                                      ianperrin @plumcraft
                                      @plumcraft
                                      As @cowboysdude said, you need to configure the classes option to trigger the scheduler.
                                      As you already have the classes option set up for what looks like @paviro 's MMM-FacialRecognition module I would suggest trying the following config.
                                          apikey: 'ad100f1e35ae51d2', // private; don’t share!
                                          pws: 'pas:IBOULOGN39', //culemborg
                                          hourly: '1',
                                          fctext: '1',
                                          fcdaycount: '5',
                                          fcdaystart: '0',
                                          hourlyinterval: '3',
                                          hourlycount: '2',
                                          alerttime: 10000,
                                          alerttruncatestring: 'french:'
                                        classes: 'for_all default scheduler'
                                      Please do report back if you are successful because I haven’t tested the compatibility of the two modules :)
                                        Opps didn’t realize you were using Facial Recognition… LOL
                                        Thanks @ianperrin !!
                                          plumcraft
                                          @ianperrin @cowboysdude
                                          Thank you both, it works with paviro’s MMM-FacialRecognition module.
                                            Okay I have another curve ball for you… how about … the ability to turn the mirror off and back on with this? :)
                                            • 1 / 5
