    MMM-ModuleScheduler - Module Schedules and Notifications
    moduleschedulecronnotifications
    82 Posts 20 Posters 169.1k Views 20 Watching
    • cowboysdudeC
      Awesome module!! The only thing I found it doesn’t work on is the clock…
      The clock doesn’t have a config section and if you add it the config won’t load…
      I 1 Reply Last reply
      • I
        ianperrin @cowboysdude
        @cowboysdude said in MMM-ModuleScheduler:
        Can you post an example of your config for the clock with the scheduler options?
        The following works for me to show the clock at 5 past each hour and hide in again at quarter past the hour…
        	module: 'clock',
        	position: 'top_left',
        	classes: 'scheduler',
        		module_schedule: {from: '5 * * * *', to: '15 * * * *'},
        “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
        • cowboysdudeC
          Well as it turns out… had an issue and had to use my img backup to reinstall the mirror… little did I know I had this already set up and working on the img so it does!!! :)
          • I
            @cowboysdude Glad to hear it works!
            • cowboysdudeC
              I must have had it setup wrong so that was my fault… like I said it’s working! Thank you!
              • cowboysdudeC
                Just curious would it be possible not to hide but to dim specific modules?
                strawberry 3.141S I 2 Replies Last reply
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @cowboysdude
                  @cowboysdude adding a css filter to the specific module could set the brightness down
                  • I
                    ianperrin @strawberry 3.141
                    @strawberry-3.141 said in MMM-ModuleScheduler:
                    Great idea - will give it a go ;)
                    • I
                      I’ve pushed an update which includes the ability to dim a module. Please feel free to update the module and use the example configuration to test it out.
                      Reply Quote 2
                      • cowboysdudeC
                        cowboysdude Module Developer @ianperrin
                        @ianperrin That sir is AWESOME! Thank you!
                          dr4ke616
                          Hey @ianperrin
                          Great module by the way. Im messing about with it, and works really well.
                          Do you think it would be possible to broadcast a notification to the module(s) that are being shown / hidden so they could react to it?
                          So for example if any given module were able to check for SHOW_MODULE, HIDE_MODULE or DIM_MODULE in the notificationReceived function so that the module could react to it and handle some specific behaviour?
                          What do you think?
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @dr4ke616
                            @dr4ke616 hide module will call the hide method of the module
                            quote from the readme When a module is hidden (using the module.hide() method), the suspend() method will be called. By subclassing this method you can perform tasks like halting the update timers. so you can do the specific behaviour you want in there
                            for show module it’s the resume method
                            D 1 Reply Last reply
                              dr4ke616 @strawberry 3.141
                              @strawberry-3.141 I didnt notice this - thanks for pointing it out. Thats exactly what i need!
                                plumcraft
                                Great idea, i’ve tried your module but i does not work for me. I might have missed a step or something.
                                I did put in the config file your module (after download and setup with npm install))) :
                                   module: 'MMM-ModuleScheduler'
                                And then :
                                  module: 'MMM-WunderGround',
                                  position: 'top_right',
                                    module_schedule: {from: '0 14 * * *', to: '0 18 * * *' },
                                    apikey: 'xxxxxxxxx', // private; don't share!
                                				pws: 'pws:IBOULOGN39', //culemborg
                                				hourly: '1',
                                				fctext: '1',
                                				fcdaycount: "5",
                                				fcdaystart: "0",
                                				hourlyinterval: "3",
                                				hourlycount: "2",
                                				alerttime: 10000,
                                				alerttruncatestring: "french:"
                                			classes: 'for_all default'
                                It’s 13:30 and the weather is still showing on the mirror.
                                Thanks for your help
                                • cowboysdudeC
                                  You’re missing the trigger ;)
                                  Here do this:
                                  module: ‘MMM-WunderGround’,
                                  position: ‘top_right’,
                                  module_schedule: {from: ‘0 14 * * *’, to: ‘0 18 * * *’ },
                                  apikey: ‘ad100f1e35ae51d2’, // **private; don’t share!**
                                  pws: ‘pws:IBOULOGN39’, //culemborg
                                  hourly: ‘1’,
                                  fctext: ‘1’,
                                  fcdaycount: “5”,
                                  fcdaystart: “0”,
                                  hourlyinterval: “3”,
                                  hourlycount: “2”,
                                  alerttime: 10000,
                                  alerttruncatestring: “french:”'
                                  Reply Quote 2
                                  • I
                                    ianperrin @plumcraft
                                    @plumcraft
                                    As @cowboysdude said, you need to configure the classes option to trigger the scheduler.
                                    As you already have the classes option set up for what looks like @paviro 's MMM-FacialRecognition module I would suggest trying the following config.
                                        apikey: 'ad100f1e35ae51d2', // private; don’t share!
                                        pws: 'pas:IBOULOGN39', //culemborg
                                        hourly: '1',
                                        fctext: '1',
                                        fcdaycount: '5',
                                        fcdaystart: '0',
                                        hourlyinterval: '3',
                                        hourlycount: '2',
                                        alerttime: 10000,
                                        alerttruncatestring: 'french:'
                                      classes: 'for_all default scheduler'
                                    Please do report back if you are successful because I haven’t tested the compatibility of the two modules :)
                                    Reply Quote 2
                                    • cowboysdudeC
                                      Opps didn’t realize you were using Facial Recognition… LOL
                                      Thanks @ianperrin !!
                                        plumcraft
                                        @ianperrin @cowboysdude
                                        Thank you both, it works with paviro’s MMM-FacialRecognition module.
                                        • cowboysdudeC
                                          Okay I have another curve ball for you… how about … the ability to turn the mirror off and back on with this? :)
                                            plumcraft
                                            +1, would be great to add this feature :)
                                            • 1 / 5
