    MMM-ModuleScheduler - Module Schedules and Notifications
    moduleschedulecronnotifications
    82 Posts 20 Posters 163.3k Views 20 Watching
    • cowboysdudeC Offline
      I must have had it setup wrong so that was my fault… like I said it’s working! Thank you!
        Just curious would it be possible not to hide but to dim specific modules?
        strawberry 3.141S I 2 Replies Last reply Reply Quote 0
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @cowboysdude
          @cowboysdude adding a css filter to the specific module could set the brightness down
          I 1 Reply Last reply Reply Quote 1
          • I Offline
            ianperrin @strawberry 3.141
            @strawberry-3.141 said in MMM-ModuleScheduler:
            Great idea - will give it a go ;)
            “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
            • I Offline
              ianperrin @cowboysdude
              @cowboysdude said in MMM-ModuleScheduler:
              I’ve pushed an update which includes the ability to dim a module. Please feel free to update the module and use the example configuration to test it out.
                cowboysdude Module Developer @ianperrin
                @ianperrin That sir is AWESOME! Thank you!
                  dr4ke616
                  Hey @ianperrin
                  Great module by the way. Im messing about with it, and works really well.
                  Do you think it would be possible to broadcast a notification to the module(s) that are being shown / hidden so they could react to it?
                  So for example if any given module were able to check for SHOW_MODULE, HIDE_MODULE or DIM_MODULE in the notificationReceived function so that the module could react to it and handle some specific behaviour?
                  What do you think?
                    strawberry 3.141 Project Sponsor Module Developer @dr4ke616
                    @dr4ke616 hide module will call the hide method of the module
                    quote from the readme When a module is hidden (using the module.hide() method), the suspend() method will be called. By subclassing this method you can perform tasks like halting the update timers. so you can do the specific behaviour you want in there
                    for show module it’s the resume method
                      dr4ke616 @strawberry 3.141
                      @strawberry-3.141 I didnt notice this - thanks for pointing it out. Thats exactly what i need!
                        plumcraft
                        Great idea, i’ve tried your module but i does not work for me. I might have missed a step or something.
                        I did put in the config file your module (after download and setup with npm install))) :
                           module: 'MMM-ModuleScheduler'
                        And then :
                          module: 'MMM-WunderGround',
                          position: 'top_right',
                            module_schedule: {from: '0 14 * * *', to: '0 18 * * *' },
                            apikey: 'xxxxxxxxx', // private; don't share!
                        				pws: 'pws:IBOULOGN39', //culemborg
                        				hourly: '1',
                        				fctext: '1',
                        				fcdaycount: "5",
                        				fcdaystart: "0",
                        				hourlyinterval: "3",
                        				hourlycount: "2",
                        				alerttime: 10000,
                        				alerttruncatestring: "french:"
                        			classes: 'for_all default'
                        It’s 13:30 and the weather is still showing on the mirror.
                        Thanks for your help
                          You’re missing the trigger ;)
                          Here do this:
                          module: ‘MMM-WunderGround’,
                          position: ‘top_right’,
                          classes: 'scheduler',
                          module_schedule: {from: ‘0 14 * * *’, to: ‘0 18 * * *’ },
                          apikey: ‘ad100f1e35ae51d2’, // **private; don’t share!**
                          pws: ‘pws:IBOULOGN39’, //culemborg
                          hourly: ‘1’,
                          fctext: ‘1’,
                          fcdaycount: “5”,
                          fcdaystart: “0”,
                          hourlyinterval: “3”,
                          hourlycount: “2”,
                          alerttime: 10000,
                          alerttruncatestring: “french:”'
                          • I Offline
                            ianperrin @plumcraft
                            @plumcraft
                            As @cowboysdude said, you need to configure the classes option to trigger the scheduler.
                            As you already have the classes option set up for what looks like @paviro 's MMM-FacialRecognition module I would suggest trying the following config.
                                apikey: 'ad100f1e35ae51d2', // private; don’t share!
                                pws: 'pas:IBOULOGN39', //culemborg
                                hourly: '1',
                                fctext: '1',
                                fcdaycount: '5',
                                fcdaystart: '0',
                                hourlyinterval: '3',
                                hourlycount: '2',
                                alerttime: 10000,
                                alerttruncatestring: 'french:'
                              classes: 'for_all default scheduler'
                            Please do report back if you are successful because I haven’t tested the compatibility of the two modules :)
                              Opps didn’t realize you were using Facial Recognition… LOL
                              Thanks @ianperrin !!
                                plumcraft
                                @ianperrin @cowboysdude
                                Thank you both, it works with paviro’s MMM-FacialRecognition module.
                                  Okay I have another curve ball for you… how about … the ability to turn the mirror off and back on with this? :)
                                    plumcraft
                                    +1, would be great to add this feature :)
                                      dr4ke616
                                      +1, be really nice if it not only just dimmed the running modules, but actually shut off the monitor.
                                        cowboysdude Module Developer @dr4ke616
                                        @dr4ke616 Well you could actually do it with a straight cronjob … something like this…
                                        55 6 * * * /home/pi/monitor_on.sh
                                        And off the same way :) It’s like making your own schedule…
                                          dr4ke616 @cowboysdude
                                          @cowboysdude thanks for pointing that out. Thats a better idea I didn’t think of :)
                                          • I Offline
                                            So I’m thinking there are a number of approaches here.
                                            One approach might be to add a mechanism to schedule the sending of notifications e.g
                                            notification_schedule: [{cronTime: '0 22 * * *', notification: 'MONITOR_OFF'}, {cronTime: '0 9 * * *', notification: 'MONITOR_ON'}]
                                            Another module could then be built (or may already exist) to listen to the notifications and react accordingly, e.g. control the monitor.
                                            What do you think?
                                            • 1 / 5
