    MMM-ModuleScheduler - Module Schedules and Notifications
    moduleschedulecronnotifications
    82 Posts 20 Posters 167.6k Views 20 Watching
      dr4ke616
      Hey @ianperrin
      Great module by the way. Im messing about with it, and works really well.
      Do you think it would be possible to broadcast a notification to the module(s) that are being shown / hidden so they could react to it?
      So for example if any given module were able to check for SHOW_MODULE, HIDE_MODULE or DIM_MODULE in the notificationReceived function so that the module could react to it and handle some specific behaviour?
      What do you think?
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @dr4ke616
        @dr4ke616 hide module will call the hide method of the module
        quote from the readme When a module is hidden (using the module.hide() method), the suspend() method will be called. By subclassing this method you can perform tasks like halting the update timers. so you can do the specific behaviour you want in there
        for show module it’s the resume method
          dr4ke616 @strawberry 3.141
          @strawberry-3.141 I didnt notice this - thanks for pointing it out. Thats exactly what i need!
            plumcraft
            Great idea, i’ve tried your module but i does not work for me. I might have missed a step or something.
            I did put in the config file your module (after download and setup with npm install))) :
               module: 'MMM-ModuleScheduler'
            And then :
              module: 'MMM-WunderGround',
              position: 'top_right',
                module_schedule: {from: '0 14 * * *', to: '0 18 * * *' },
                apikey: 'xxxxxxxxx', // private; don't share!
            				pws: 'pws:IBOULOGN39', //culemborg
            				hourly: '1',
            				fctext: '1',
            				fcdaycount: "5",
            				fcdaystart: "0",
            				hourlyinterval: "3",
            				hourlycount: "2",
            				alerttime: 10000,
            				alerttruncatestring: "french:"
            			classes: 'for_all default'
            It’s 13:30 and the weather is still showing on the mirror.
            Thanks for your help
            • cowboysdudeC
              You’re missing the trigger ;)
              Here do this:
              module: ‘MMM-WunderGround’,
              position: ‘top_right’,
              classes: 'scheduler',
              module_schedule: {from: ‘0 14 * * *’, to: ‘0 18 * * *’ },
              apikey: ‘ad100f1e35ae51d2’, // **private; don’t share!**
              pws: ‘pws:IBOULOGN39’, //culemborg
              hourly: ‘1’,
              fctext: ‘1’,
              fcdaycount: “5”,
              fcdaystart: “0”,
              hourlyinterval: “3”,
              hourlycount: “2”,
              alerttime: 10000,
              alerttruncatestring: “french:”'
              • I
                ianperrin @plumcraft
                @plumcraft
                As @cowboysdude said, you need to configure the classes option to trigger the scheduler.
                As you already have the classes option set up for what looks like @paviro 's MMM-FacialRecognition module I would suggest trying the following config.
                    apikey: 'ad100f1e35ae51d2', // private; don’t share!
                    pws: 'pas:IBOULOGN39', //culemborg
                    hourly: '1',
                    fctext: '1',
                    fcdaycount: '5',
                    fcdaystart: '0',
                    hourlyinterval: '3',
                    hourlycount: '2',
                    alerttime: 10000,
                    alerttruncatestring: 'french:'
                  classes: 'for_all default scheduler'
                Please do report back if you are successful because I haven’t tested the compatibility of the two modules :)
                “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
                • cowboysdudeC
                  Opps didn’t realize you were using Facial Recognition… LOL
                  Thanks @ianperrin !!
                    plumcraft
                    @ianperrin @cowboysdude
                    Thank you both, it works with paviro’s MMM-FacialRecognition module.
                    • cowboysdudeC
                      Okay I have another curve ball for you… how about … the ability to turn the mirror off and back on with this? :)
                        plumcraft
                        +1, would be great to add this feature :)
                          dr4ke616
                          +1, be really nice if it not only just dimmed the running modules, but actually shut off the monitor.
                          • cowboysdudeC
                            cowboysdude Module Developer @dr4ke616
                            @dr4ke616 Well you could actually do it with a straight cronjob … something like this…
                            55 6 * * * /home/pi/monitor_on.sh
                            And off the same way :) It’s like making your own schedule…
                              dr4ke616 @cowboysdude
                              @cowboysdude thanks for pointing that out. Thats a better idea I didn’t think of :)
                              • I
                                @cowboysdude said in MMM-ModuleScheduler:
                                So I’m thinking there are a number of approaches here.
                                One approach might be to add a mechanism to schedule the sending of notifications e.g
                                notification_schedule: [{cronTime: '0 22 * * *', notification: 'MONITOR_OFF'}, {cronTime: '0 9 * * *', notification: 'MONITOR_ON'}]
                                Another module could then be built (or may already exist) to listen to the notifications and react accordingly, e.g. control the monitor.
                                What do you think?
                                • cowboysdudeC
                                  Right now I’m doing it with crontab… my schedule is complex hahahah
                                  BUT you have a great idea there, That sir would work perfectly!!!
                                  Yes that would work… currently people are doing it with either the camera or PIR sensor but for those who have neither this would be a great replacement!
                                  My schedule works like this:
                                  On at 7 am
                                  Off at 9 am
                                  On at 5 pm
                                  Off at 11 pm
                                  However, this will change because I only want that to happen M-F on Sat and Sun I want it differently…
                                  On top of using the scheduler to show different things throughout those times… I gotta tell you how much I really like this module! :)
                                  • A
                                    Alvinger
                                    I can’t get the dimLevel to work on the clock. I have the following config:
                                     module: "clock",
                                     classes: "scheduler",
                                      module_schedule: [
                                       {from: "00 06 * * *", to: "30 09 * * *", dimLevel: "50"},
                                       {from: "00 16 * * *", to: "30 22 * * *", dimLevel: "50"}
                                    When the time reaches “to” the clock just disappears rather than being dimmed.
                                    What am I doing wrong? (I am running the latest version of the module)
                                    cowboysdudeC I 2 Replies Last reply Reply Quote 0
                                    • cowboysdudeC
                                      cowboysdude Module Developer @Alvinger
                                      @Alvinger
                                      Try this instead:
                                      {from: '0 06 * * * ', to: '30 09 * * * ', dimLevel: ‘50’},
                                      {from: '0 16 * * * ', to: '30 22 * * * ', dimLevel: ‘50’}
                                      • I
                                        ianperrin @Alvinger
                                        @Alvinger:
                                        A few quick observations,
                                        Firstly I’d suggest removing the leading zeros from each field in the cron expression, i.e. changing 00 06 * * * to 0 6 * * * - some parsers may support this but I believe the cron tab specification states the valid values for the minute field is 0-59 and hour field is 0-23. If in doubt, try using http://crontab.guru/ to test your expressions.
                                        Next up, make sure you updated to the latest version (git pull from the module directory and restart the mirror) to ensure the dim functionality is available to your mirror.
                                        If after ensuring the cron expressions are correct and you have the latest version, you are still experiencing this problem, can you check the output of the log (pm2 logs mm). You should have something like this
                                        MM-ModuleScheduler received CREATE_MODULE_SCHEDULE
                                        MMM-ModuleScheduler is scheduling clock using '0 6 * * *' and '30 9 * * *'
                                        MMM-ModuleScheduler is dimming clock
                                        MMM-ModuleScheduler has scheduled clock
                                        MMM-ModuleScheduler will next show clock at Wed Oct 15 2016 06:00:00 GMT+0000 (UTC)
                                        MMM-ModuleScheduler will next dim clock at Wed Oct 15 2016 09:30:00 GMT+0000 (UTC)
                                        Can you share the output of your log here so I can take a look?
                                        • I
                                          ianperrin
                                          @Alvinger, @cowboysdude
                                          Having looked at the code, there may be certain circumstances where the module is initially hidden, even when the dimLevel option is defined. I believe this only relates to schedules are defined using arrays with a particular show > dim > show > dim sequence.
                                          I’ve pushed an update to try an fix this, so feel free to update the module and give it a go.
                                          Alternatively, (and also highly recommended) would be to minimise the number of cron jobs create by simplifying your schedule as follows
                                           module: "clock",
                                            // Show at 06:00 and 16:00, then dim to 50% at 09:30 and 22:30 every day
                                            module_schedule: {from: '0 6,16 * * *', to: '30 9,22 * * *', dimLevel: '50'},
                                          • A
                                            Alvinger
                                            @ianperrin
                                            It works! It was probably the code update that fixed even though I also simplified the cron expression.
                                            All my other schedules (which hides, not dims, modules) worked before even with arrays having double quotes and leading zeroes. And they still work.
                                            Great work @ianperrin, and thank you for a must-have module!
                                            • 2 / 5
