    MMM-ModuleScheduler - Module Schedules and Notifications
    moduleschedulecronnotifications
    82 Posts 20 Posters 168.6k Views 20 Watching
      dr4ke616
      +1, be really nice if it not only just dimmed the running modules, but actually shut off the monitor.
      • cowboysdudeC
        cowboysdude Module Developer @dr4ke616
        @dr4ke616 Well you could actually do it with a straight cronjob … something like this…
        55 6 * * * /home/pi/monitor_on.sh
        And off the same way :) It’s like making your own schedule…
        D 1 Reply Last reply
          dr4ke616 @cowboysdude
          @cowboysdude thanks for pointing that out. Thats a better idea I didn’t think of :)
          • I
            ianperrin @cowboysdude
            @cowboysdude said in MMM-ModuleScheduler:
            Okay I have another curve ball for you… how about … the ability to turn the mirror off and back on with this? :)
            So I’m thinking there are a number of approaches here.
            One approach might be to add a mechanism to schedule the sending of notifications e.g
            notification_schedule: [{cronTime: '0 22 * * *', notification: 'MONITOR_OFF'}, {cronTime: '0 9 * * *', notification: 'MONITOR_ON'}]
            Another module could then be built (or may already exist) to listen to the notifications and react accordingly, e.g. control the monitor.
            What do you think?
            “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
            • cowboysdudeC
              Right now I’m doing it with crontab… my schedule is complex hahahah
              BUT you have a great idea there, That sir would work perfectly!!!
              Yes that would work… currently people are doing it with either the camera or PIR sensor but for those who have neither this would be a great replacement!
              My schedule works like this:
              On at 7 am
              Off at 9 am
              On at 5 pm
              Off at 11 pm
              However, this will change because I only want that to happen M-F on Sat and Sun I want it differently…
              On top of using the scheduler to show different things throughout those times… I gotta tell you how much I really like this module! :)
              • AlvingerA
                Alvinger
                I can’t get the dimLevel to work on the clock. I have the following config:
                 module: "clock",
                 classes: "scheduler",
                  module_schedule: [
                   {from: "00 06 * * *", to: "30 09 * * *", dimLevel: "50"},
                   {from: "00 16 * * *", to: "30 22 * * *", dimLevel: "50"}
                When the time reaches “to” the clock just disappears rather than being dimmed.
                What am I doing wrong? (I am running the latest version of the module)
                cowboysdudeC I 2 Replies Last reply
                • cowboysdudeC
                  cowboysdude Module Developer @Alvinger
                  @Alvinger
                  Try this instead:
                  {from: '0 06 * * * ', to: '30 09 * * * ', dimLevel: ‘50’},
                  {from: '0 16 * * * ', to: '30 22 * * * ', dimLevel: ‘50’}
                  • I
                    ianperrin @Alvinger
                    @Alvinger:
                    A few quick observations,
                    Firstly I’d suggest removing the leading zeros from each field in the cron expression, i.e. changing 00 06 * * * to 0 6 * * * - some parsers may support this but I believe the cron tab specification states the valid values for the minute field is 0-59 and hour field is 0-23. If in doubt, try using http://crontab.guru/ to test your expressions.
                    Next up, make sure you updated to the latest version (git pull from the module directory and restart the mirror) to ensure the dim functionality is available to your mirror.
                    If after ensuring the cron expressions are correct and you have the latest version, you are still experiencing this problem, can you check the output of the log (pm2 logs mm). You should have something like this
                    MM-ModuleScheduler received CREATE_MODULE_SCHEDULE
                    MMM-ModuleScheduler is scheduling clock using '0 6 * * *' and '30 9 * * *'
                    MMM-ModuleScheduler is dimming clock
                    MMM-ModuleScheduler has scheduled clock
                    MMM-ModuleScheduler will next show clock at Wed Oct 15 2016 06:00:00 GMT+0000 (UTC)
                    MMM-ModuleScheduler will next dim clock at Wed Oct 15 2016 09:30:00 GMT+0000 (UTC)
                    Can you share the output of your log here so I can take a look?
                    • I
                      ianperrin
                      @Alvinger, @cowboysdude
                      Having looked at the code, there may be certain circumstances where the module is initially hidden, even when the dimLevel option is defined. I believe this only relates to schedules are defined using arrays with a particular show > dim > show > dim sequence.
                      I’ve pushed an update to try an fix this, so feel free to update the module and give it a go.
                      Alternatively, (and also highly recommended) would be to minimise the number of cron jobs create by simplifying your schedule as follows
                       module: "clock",
                        // Show at 06:00 and 16:00, then dim to 50% at 09:30 and 22:30 every day
                        module_schedule: {from: '0 6,16 * * *', to: '30 9,22 * * *', dimLevel: '50'},
                      • AlvingerA
                        Alvinger
                        @ianperrin
                        It works! It was probably the code update that fixed even though I also simplified the cron expression.
                        All my other schedules (which hides, not dims, modules) worked before even with arrays having double quotes and leading zeroes. And they still work.
                        Great work @ianperrin, and thank you for a must-have module!
                        • I
                          ianperrin
                          An update to MMM-ModuleScheduler is now available which includes the ability to
                          • Send notifications using a schedule - thanks for the idea @cowboysdude
                          • Control how quickly modules are shown/hidden (animationSpeed option)
                          • Override the name of the class used to identify the modules which have a schedule (schedulerClass option)
                          Check out the updated documentation for more information.
                          • cowboysdudeC
                            That is awesome!! You just keep making this better and better!!! Thank you!
                            • AlvingerA
                              Alvinger
                              @ianperrin @cowboysdude
                              Check out my new module MMM-tvservice in the System section of the forum. I took the idea from @ianperrin when he suggested a module to act on notifications.
                              • I
                                ianperrin
                                @Alvinger interesting, I’ll check it out.
                                You may also be interested in taking a look at MMM-Remote-Control. It contains a heap of functions to control your mirror (including turning the monitor off and on, rebooting the pi, restarting the MM process etc) remotely.
                                I’ve been working with @Jopyth to expose this functionality via the use of sendNotification.
                                This should allow schedules like:
                                    {notification: 'REMOTE_ACTION', schedule: '30 9 * * *', payload: {action: 'MONITOROFF'}},
                                    {notification: 'REMOTE_ACTION', schedule: '30 18 * * *', payload: {action: 'MONITORON'}}
                                Check out the repository on GitHub - the latest code includes this capability
                                J 1 Reply Last reply
                                  Jopyth Moderator @ianperrin
                                  @ianperrin The actions available are now also documented in the readme, so noone has to dig through all the code neccessarily. See this section, a table is down below.
                                  • AlvingerA
                                    Alvinger
                                    @ianperrin @Jopyth: sorry, wasn’t aware that MMM-Remote-Control had that ability. I would recommend MMM-Remote-Control instead of MMM-tvservice to the general user as it covers all functionality needed.
                                    MMM-tvservice is more for the linux enthusiast who wants a program to do one thing and one thing only. I am not running MagicMirror through PM2 but rather directly via systemd so I cannot use all functionality of MMM-Remote-Control without editing the source. Also, as I am running through systemd I do not need to prefix the commands with sudo as the service already runs as root.
                                    • MichMichM
                                      MichMich
                                      Very awesome work on this module! It might be interesting to look at the new show/hide mechanism: https://forum.magicmirror.builders/topic/241/revising-the-show-hide-mechanism/9
                                      • MichMichM
                                        MichMich
                                        One other feature request:
                                        It would be nice if there is a way to schedule a hide show based on a classname. This way I can give all my modules a class like “day” and “night”, and make a schedule:
                                                module: 'MMM-ModuleScheduler',
                                                    visibility_schedule: [
                                                        {classes: 'day', schedule: {from: '0 6 * * *', to: '0 22 * * *' }},
                                                        {classes: 'night',  schedule: {from: '0 22 * * *', to: '0 6 * * *' }}
                                        I 1 Reply Last reply
                                        Reply Quote 2
                                        • I
                                          ianperrin @MichMich
                                          @MichMich said in MMM-ModuleScheduler:
                                          Great idea. I was planning on adding a global module_schedule functionality, i.e. the ability to hide all modules at 10pm, rather than having to configure multiple schedules on a per-module basis.
                                          I think the idea of class-based module groups makes for an interesting extension of the idea.
                                          So to take your config example, if the global schedule definition includes the classes property, only those modules with that class are affected. If the global schedule definition omits the classes field then all modules are affected.
                                          One for next week I suspect!
                                          • MichMichM
                                            MichMich
                                            An other small suggestion: delay all show effects with the a delay equal to the animation time. This way all Modules that will need to hide will nicely hide before any new modules fade in.
                                            • 2 / 5
