    MMM-ModuleScheduler - Module Schedules and Notifications
    moduleschedulecronnotifications
    82 Posts 20 Posters 166.4k Views 20 Watching
    • I
      ianperrin @cowboysdude
      @cowboysdude said in MMM-ModuleScheduler:
      Okay I have another curve ball for you… how about … the ability to turn the mirror off and back on with this? :)
      So I’m thinking there are a number of approaches here.
      One approach might be to add a mechanism to schedule the sending of notifications e.g
      notification_schedule: [{cronTime: '0 22 * * *', notification: 'MONITOR_OFF'}, {cronTime: '0 9 * * *', notification: 'MONITOR_ON'}]
      Another module could then be built (or may already exist) to listen to the notifications and react accordingly, e.g. control the monitor.
      What do you think?
      “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
      • cowboysdudeC
        Right now I’m doing it with crontab… my schedule is complex hahahah
        BUT you have a great idea there, That sir would work perfectly!!!
        Yes that would work… currently people are doing it with either the camera or PIR sensor but for those who have neither this would be a great replacement!
        My schedule works like this:
        On at 7 am
        Off at 9 am
        On at 5 pm
        Off at 11 pm
        However, this will change because I only want that to happen M-F on Sat and Sun I want it differently…
        On top of using the scheduler to show different things throughout those times… I gotta tell you how much I really like this module! :)
        • A
          Alvinger
          I can’t get the dimLevel to work on the clock. I have the following config:
           module: "clock",
           classes: "scheduler",
            module_schedule: [
             {from: "00 06 * * *", to: "30 09 * * *", dimLevel: "50"},
             {from: "00 16 * * *", to: "30 22 * * *", dimLevel: "50"}
          When the time reaches “to” the clock just disappears rather than being dimmed.
          What am I doing wrong? (I am running the latest version of the module)
          cowboysdudeC I 2 Replies Last reply Reply Quote 0
          • cowboysdudeC
            cowboysdude Module Developer @Alvinger
            @Alvinger
            Try this instead:
            {from: '0 06 * * * ', to: '30 09 * * * ', dimLevel: ‘50’},
            {from: '0 16 * * * ', to: '30 22 * * * ', dimLevel: ‘50’}
            • I
              ianperrin @Alvinger
              @Alvinger:
              A few quick observations,
              Firstly I’d suggest removing the leading zeros from each field in the cron expression, i.e. changing 00 06 * * * to 0 6 * * * - some parsers may support this but I believe the cron tab specification states the valid values for the minute field is 0-59 and hour field is 0-23. If in doubt, try using http://crontab.guru/ to test your expressions.
              Next up, make sure you updated to the latest version (git pull from the module directory and restart the mirror) to ensure the dim functionality is available to your mirror.
              If after ensuring the cron expressions are correct and you have the latest version, you are still experiencing this problem, can you check the output of the log (pm2 logs mm). You should have something like this
              MM-ModuleScheduler received CREATE_MODULE_SCHEDULE
              MMM-ModuleScheduler is scheduling clock using '0 6 * * *' and '30 9 * * *'
              MMM-ModuleScheduler is dimming clock
              MMM-ModuleScheduler has scheduled clock
              MMM-ModuleScheduler will next show clock at Wed Oct 15 2016 06:00:00 GMT+0000 (UTC)
              MMM-ModuleScheduler will next dim clock at Wed Oct 15 2016 09:30:00 GMT+0000 (UTC)
              Can you share the output of your log here so I can take a look?
              • I
                ianperrin
                @Alvinger, @cowboysdude
                Having looked at the code, there may be certain circumstances where the module is initially hidden, even when the dimLevel option is defined. I believe this only relates to schedules are defined using arrays with a particular show > dim > show > dim sequence.
                I’ve pushed an update to try an fix this, so feel free to update the module and give it a go.
                Alternatively, (and also highly recommended) would be to minimise the number of cron jobs create by simplifying your schedule as follows
                 module: "clock",
                  // Show at 06:00 and 16:00, then dim to 50% at 09:30 and 22:30 every day
                  module_schedule: {from: '0 6,16 * * *', to: '30 9,22 * * *', dimLevel: '50'},
                • A
                  Alvinger
                  @ianperrin
                  It works! It was probably the code update that fixed even though I also simplified the cron expression.
                  All my other schedules (which hides, not dims, modules) worked before even with arrays having double quotes and leading zeroes. And they still work.
                  Great work @ianperrin, and thank you for a must-have module!
                  • I
                    ianperrin
                    An update to MMM-ModuleScheduler is now available which includes the ability to
                    • Send notifications using a schedule - thanks for the idea @cowboysdude
                    • Control how quickly modules are shown/hidden (animationSpeed option)
                    • Override the name of the class used to identify the modules which have a schedule (schedulerClass option)
                    Check out the updated documentation for more information.
                    • cowboysdudeC
                      That is awesome!! You just keep making this better and better!!! Thank you!
                      • A
                        Alvinger
                        @ianperrin @cowboysdude
                        Check out my new module MMM-tvservice in the System section of the forum. I took the idea from @ianperrin when he suggested a module to act on notifications.
                        • I
                          ianperrin
                          @Alvinger interesting, I’ll check it out.
                          You may also be interested in taking a look at MMM-Remote-Control. It contains a heap of functions to control your mirror (including turning the monitor off and on, rebooting the pi, restarting the MM process etc) remotely.
                          I’ve been working with @Jopyth to expose this functionality via the use of sendNotification.
                          This should allow schedules like:
                              {notification: 'REMOTE_ACTION', schedule: '30 9 * * *', payload: {action: 'MONITOROFF'}},
                              {notification: 'REMOTE_ACTION', schedule: '30 18 * * *', payload: {action: 'MONITORON'}}
                          Check out the repository on GitHub - the latest code includes this capability
                            Jopyth Moderator @ianperrin
                            @ianperrin The actions available are now also documented in the readme, so noone has to dig through all the code neccessarily. See this section, a table is down below.
                            • A
                              Alvinger
                              @ianperrin @Jopyth: sorry, wasn’t aware that MMM-Remote-Control had that ability. I would recommend MMM-Remote-Control instead of MMM-tvservice to the general user as it covers all functionality needed.
                              MMM-tvservice is more for the linux enthusiast who wants a program to do one thing and one thing only. I am not running MagicMirror through PM2 but rather directly via systemd so I cannot use all functionality of MMM-Remote-Control without editing the source. Also, as I am running through systemd I do not need to prefix the commands with sudo as the service already runs as root.
                              • MichMichM
                                MichMich
                                Very awesome work on this module! It might be interesting to look at the new show/hide mechanism: https://forum.magicmirror.builders/topic/241/revising-the-show-hide-mechanism/9
                                • MichMichM
                                  MichMich
                                  One other feature request:
                                  It would be nice if there is a way to schedule a hide show based on a classname. This way I can give all my modules a class like “day” and “night”, and make a schedule:
                                          module: 'MMM-ModuleScheduler',
                                              visibility_schedule: [
                                                  {classes: 'day', schedule: {from: '0 6 * * *', to: '0 22 * * *' }},
                                                  {classes: 'night',  schedule: {from: '0 22 * * *', to: '0 6 * * *' }}
                                  I 1 Reply Last reply Reply Quote 2
                                  • I
                                    ianperrin @MichMich
                                    @MichMich said in MMM-ModuleScheduler:
                                    Great idea. I was planning on adding a global module_schedule functionality, i.e. the ability to hide all modules at 10pm, rather than having to configure multiple schedules on a per-module basis.
                                    I think the idea of class-based module groups makes for an interesting extension of the idea.
                                    So to take your config example, if the global schedule definition includes the classes property, only those modules with that class are affected. If the global schedule definition omits the classes field then all modules are affected.
                                    One for next week I suspect!
                                    • MichMichM
                                      MichMich
                                      An other small suggestion: delay all show effects with the a delay equal to the animation time. This way all Modules that will need to hide will nicely hide before any new modules fade in.
                                      • I
                                        ianperrin
                                        @MichMich - some great ideas, keep them coming.
                                        I’ve created issues (or rather enhancements) for these on GitHub - https://github.com/ianperrin/MMM-ModuleScheduler/issues. Feel free to review, comment etc.
                                          Mr.Meeseeks
                                          Is it required to restart mm/server if a scheduler configuration is changed, add, removed?
                                          CAAAAN DOO!👍
                                          • I
                                            ianperrin @Mr.Meeseeks
                                            @Mr.Meeseeks Apologies for missing this one.
                                            The schedules are set up after the ALL_MODULES_STARTED or DOM_OBJECTS_CREATED notifications have been received from the core. So a restart should not be required and a refresh of the browser should be sufficient to pick up config changes.
                                            • 2 / 5
