    read csv-data and put it in an array
    313 Posts 3 Posters 590.1k Views 4 Watching
    • PerlchampP
      Perlchamp
      another question:
      what can i do with MMM-logging. if i start npm start in the MagicMirror folder nothing will displayed. and to test, etc. i have to close MagicMirror because it fill the hole screen …
        sdetweil @Perlchamp
        @Perlchamp log.log only works in the modulename.js (the part loaded in the browser)
        we call it that cause its filename matches the module name
        • PerlchampP
          Perlchamp
          ok, thanks again :-)
            sdetweil @Perlchamp
            @Perlchamp u can redirect the output of npm start to a file, npm start >somefile
            u can minimize the window with alt-spacebar, n
            u can open the developers window ( for the modulename,js debugging) npm start dev
            or if mirror already running use f12 or ctrl-shift-i on the keyboard
            I debug from my PC, ssh connected to pi, or I run MM on my PC… and debug there
            • PerlchampP
              Perlchamp
              what do you use for debugging on pc ?
              do you have x64 or arm-based pc ?
                sdetweil @Perlchamp
                @Perlchamp x64, run linux or windows (today on linux), doesn’t matter… same debug process… look at console or browser window
                if I need to debug modulename.js on pi, I open browser from PC to the mirror URL and do it there
                • PerlchampP
                  Perlchamp
                  AND:
                  thanks a lot for YOUR time. i hope it will not been wasted … i will working hard to get some results …
                  • PerlchampP
                    Perlchamp
                    @sdetweil said in read csv-data and put it in an array:
                    how ?
                      sdetweil @Perlchamp
                      @Perlchamp on MagicMirror, in config, set address:“0.0.0.0”,
                      And ipWhitelist:[],
                      Then u can connect to the mm url from anywhere in your house/office.
                      http://ipaddress:port
                      Then f12 or ctrl-shift-i on the browser keyboard to open the developers window.
                      • PerlchampP
                        Perlchamp
                        ok thank.
                        if i want to test
                            readCSV: fs.readFile('birthdaylist.csv', 'utf8', function (err, data) {
                        	var dataArray = data.split(/\r?\n/);
                        	Log.log(dataArray);
                        or
                        readList: function() {
                        	var JFile=require('jfile');
                        	var myF=new JFile("MMM-birthday.txt");
                        	myF.lines // ["first line","second line"]
                        i have to do this in node_helper right? and first i have to require them and of course to install them … something i forgot ?
                          sdetweil @Perlchamp
                          @Perlchamp Log.log is ONLY in the browser, but fs. Is not usable in browser
                          U can test it w node to make sure it works. Then for mm it has to be in node_helper
                          Install library, so that you CAN require
                          • PerlchampP
                            Perlchamp
                            hallo sam :-)
                            i have now this in my node_helper.js:
                            var NodeHelper = require("node_helper");
                            // add require of other javascripot components here
                            // var xxx = require('yyy'); here
                            const csv = require("csvtojson");
                            const csvFilePath = this.path + 'birthdaylist.csv';
                            	init(){
                            		console.log("init module helper perlchamp");
                            	start() {
                            		console.log("Starting module helper: ${this.name}");
                            		console.log("dieser Pfad: ${this.path}");
                            		csv()
                            		.fromFile(csvFilePath)
                            		.then((jsonObj)=>{
                            			console.log(jsonObj);
                            	stop(){
                            		console.log(`Stopping module helper: ${this.name}`);
                            	// handle messages from our module// each notification indicates a different messages
                            	// payload is a data structure that is different per message.. up to you to design this
                            	socketNotificationReceived(notification, payload) {
                            		console.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                            		// if config message from module
                            		if (notification === "CONFIG") {
                            			// save payload config info
                            			this.config=payload
                            			// wait 15 seconds, send a message back to module
                            			setTimeout(()=> { this.sendSocketNotification("message_from_helper"," this is a test_message")}, 15000)
                            		else if(notification === "????2") {
                            terminal says:
                            Unhandled rejection Error: File does not exist. Check to make sure the file path to your csv is correct.
                                at /home/dirk/MagicMirror/node_modules/csvtojson/v2/Converter.js:81:37
                                at suppressedCallback (fs.js:209:5)
                                at FSReqCallback.oncomplete (fs.js:153:23)
                            it’s from your SampleModule …
                            1. how can i see the console.log statements in the browser, starting MM ?
                            2. did i enter the code in the right place?
                            3. if I enter the following into the terminal window:
                              node console.log (‘path: $ {this.path}’)
                              i got an error message:
                              bash: Syntaxerror unexpected word `(’
                              what am I doing wrong ?
                            many thanks in advance
                              sdetweil @Perlchamp
                              @Perlchamp said in read csv-data and put it in an array:
                              • how can i see the console.log statements in the browser, starting MM ?
                                cannot see node_helper messages in browser, must look in the terminal window where u did npm start
                                you can redirect those messages to a file
                                npm start >somefile
                                and then look at somefile live with editor
                              • did i enter the code in the right place?
                                const csvFilePath = this.path + ‘birthdaylist.csv’;
                                u have this.path outside the NodeHelper.create, at that time ‘this’ does not exist
                                ‘this’ means ‘instance of’, and u are outside the thing that creates the instance
                              • if I enter the following into the terminal window:
                              because u are not running in magic mirror , ‘this’ does not exist
                              • i got an error message:
                              • bash: Syntaxerror unexpected word `(’
                                what am I doing wrong…
                                bash would not see any ( unless u put it on the line with node
                              node (something)
                              that is a command to bash (the terminal window program, he has his own rules about parens, and other special characters (* means ALL filenames in this folder for example!)
                              I never ever use $ in node_helper (or anywhere else)
                              I would do this
                              console.log (‘path: '+ this.path)
                              • PerlchampP
                                Perlchamp
                                thank you. ok, i will test …
                                only for your information:
                                start() {
                                		console.log(`Starting module helper: ${this.name}`);
                                	stop(){
                                this is from your SampleModule. i’m not here to reprimand you. it should only be information. so please do not misunderstand.
                                  sdetweil @Perlchamp
                                  @Perlchamp thanks… will fix… never copy from another without review!!
                                  • PerlchampP
                                    Perlchamp
                                    always my pleasure
                                      @Perlchamp fixed
                                        if u redirect the output of npm start to a file, this is what you will see in the file
                                        > magicmirror@2.11.0 start /home/sam/MagicMirror
                                        [2020-04-30 11:15:53.521] [LOG]    Starting MagicMirror: v2.11.0
                                        [2020-04-30 11:15:53.524] [LOG]    Loading config ...
                                        [2020-04-30 11:15:53.526] [LOG]    Loading module helpers ...
                                        [2020-04-30 11:15:53.528] [LOG]    Initializing new module helper ...
                                        [2020-04-30 11:15:53.528] [LOG]    Module helper loaded: MMM-Logging
                                        [2020-04-30 11:15:53.529] [LOG]    No helper found for module: alert.
                                        [2020-04-30 11:15:53.529] [LOG]    No helper found for module: clock.
                                        [2020-04-30 11:15:53.663] [LOG]    Initializing new module helper ...
                                        [2020-04-30 11:15:53.663] [LOG]    Module helper loaded: MyCovid19
                                        [2020-04-30 11:15:53.784] [LOG]    Initializing new module helper ...
                                        [2020-04-30 11:15:53.785] [LOG]    Module helper loaded: MMM-AlexaControl
                                        [2020-04-30 11:15:53.786] [LOG]    handler helper in init
                                        [2020-04-30 11:15:53.786] [LOG]    Module helper loaded: MMM-SleepWake
                                        [2020-04-30 11:15:53.786] [LOG]    All module helpers loaded.
                                        [2020-04-30 11:15:53.820] [LOG]    Starting server on port 8090 ...
                                        [2020-04-30 11:15:53.821] [INFO]   You're using a full whitelist configuration to allow for all IPs
                                        [2020-04-30 11:15:53.823] [LOG]    Server started ...
                                        [2020-04-30 11:15:53.823] [LOG]    Connecting socket for: MMM-Logging
                                        [2020-04-30 11:15:53.824] [LOG]    Module helper started for MMM-Logging
                                        [2020-04-30 11:15:53.824] [LOG]    Connecting socket for: MyCovid19
                                        [2020-04-30 11:15:53.824] [LOG]    Starting node_helper for module: MyCovid19
                                        [2020-04-30 11:15:53.824] [LOG]    path=/home/sam/MagicMirror/modules/MyCovid19
                                        [2020-04-30 11:15:53.824] [LOG]    Connecting socket for: MMM-AlexaControl
                                        [2020-04-30 11:15:53.824] [LOG]    MMM-AlexaControl helper, started...
                                        [2020-04-30 11:15:53.824] [LOG]    Connecting socket for: MMM-SleepWake
                                        [2020-04-30 11:15:53.825] [LOG]    handler helper in start
                                        [2020-04-30 11:15:53.825] [LOG]    Sockets connected & modules started ...
                                        [2020-04-30 11:15:53.906] [LOG]    Launching application.
                                        [2020-04-30 11:15:53.928] [LOG]    setup for latent showing  // < --- from my module node_helper
                                        [2020-04-30 11:15:54.487] [LOG]    requested file exists=modules/MyCovid19/states-rawdata-04-30-2020 sending back to module_13_MyCovid19_5731  // < --- from my module node_helper
                                        [2020-04-30 11:15:54.490] [LOG]    requested file exists=modules/MyCovid19/countries-rawdata-04-30-2020 sending back to module_16_MyCovid19_7951  // < --- from my module node_helper
                                        [2020-04-30 11:15:54.492] [LOG]    requested file exists=modules/MyCovid19/countries-rawdata-04-30-2020 sending back to module_14_MyCovid19_1721  // < --- from my module node_helper
                                        [2020-04-30 11:15:54.493] [LOG]    requested file exists=modules/MyCovid19/countries-rawdata-04-30-2020 sending back to module_15_MyCovid19_91  // < --- from my module node_helper
                                        [2020-04-30 11:15:54.498] [LOG]    requested file exists=modules/MyCovid19/countries-rawdata-04-30-2020 sending back to module_17_MyCovid19_2191  // < --- from my module node_helper
                                        etc
                                        • PerlchampP
                                          Perlchamp
                                          ok, it’s slowly dawning on me, see little light at the end of the tunnel
                                            sdetweil @Perlchamp
                                            @Perlchamp if u install the logging module I suggested, then it captures all the messages from the modulename.js in the browser and prints them to the terminal window log, which would be saved to the file as well.
                                            • 15
                                            • 16
                                            • 3 / 16
