    read csv-data and put it in an array
    313 Posts 3 Posters 590.1k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp on MagicMirror, in config, set address:“0.0.0.0”,
      And ipWhitelist:[],
      Then u can connect to the mm url from anywhere in your house/office.
      http://ipaddress:port
      Then f12 or ctrl-shift-i on the browser keyboard to open the developers window.
      • PerlchampP
        Perlchamp
        ok thank.
        if i want to test
            readCSV: fs.readFile('birthdaylist.csv', 'utf8', function (err, data) {
        	var dataArray = data.split(/\r?\n/);
        	Log.log(dataArray);
        or
        readList: function() {
        	var JFile=require('jfile');
        	var myF=new JFile("MMM-birthday.txt");
        	myF.lines // ["first line","second line"]
        i have to do this in node_helper right? and first i have to require them and of course to install them … something i forgot ?
          sdetweil @Perlchamp
          @Perlchamp Log.log is ONLY in the browser, but fs. Is not usable in browser
          U can test it w node to make sure it works. Then for mm it has to be in node_helper
          Install library, so that you CAN require
          • PerlchampP
            Perlchamp
            hallo sam :-)
            i have now this in my node_helper.js:
            var NodeHelper = require("node_helper");
            // add require of other javascripot components here
            // var xxx = require('yyy'); here
            const csv = require("csvtojson");
            const csvFilePath = this.path + 'birthdaylist.csv';
            	init(){
            		console.log("init module helper perlchamp");
            	start() {
            		console.log("Starting module helper: ${this.name}");
            		console.log("dieser Pfad: ${this.path}");
            		csv()
            		.fromFile(csvFilePath)
            		.then((jsonObj)=>{
            			console.log(jsonObj);
            	stop(){
            		console.log(`Stopping module helper: ${this.name}`);
            	// handle messages from our module// each notification indicates a different messages
            	// payload is a data structure that is different per message.. up to you to design this
            	socketNotificationReceived(notification, payload) {
            		console.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
            		// if config message from module
            		if (notification === "CONFIG") {
            			// save payload config info
            			this.config=payload
            			// wait 15 seconds, send a message back to module
            			setTimeout(()=> { this.sendSocketNotification("message_from_helper"," this is a test_message")}, 15000)
            		else if(notification === "????2") {
            terminal says:
            Unhandled rejection Error: File does not exist. Check to make sure the file path to your csv is correct.
                at /home/dirk/MagicMirror/node_modules/csvtojson/v2/Converter.js:81:37
                at suppressedCallback (fs.js:209:5)
                at FSReqCallback.oncomplete (fs.js:153:23)
            it’s from your SampleModule …
            1. how can i see the console.log statements in the browser, starting MM ?
            2. did i enter the code in the right place?
            3. if I enter the following into the terminal window:
              node console.log (‘path: $ {this.path}’)
              i got an error message:
              bash: Syntaxerror unexpected word `(’
              what am I doing wrong ?
            many thanks in advance
              sdetweil @Perlchamp
              @Perlchamp said in read csv-data and put it in an array:
              • how can i see the console.log statements in the browser, starting MM ?
                cannot see node_helper messages in browser, must look in the terminal window where u did npm start
                you can redirect those messages to a file
                npm start >somefile
                and then look at somefile live with editor
              • did i enter the code in the right place?
                const csvFilePath = this.path + ‘birthdaylist.csv’;
                u have this.path outside the NodeHelper.create, at that time ‘this’ does not exist
                ‘this’ means ‘instance of’, and u are outside the thing that creates the instance
              • if I enter the following into the terminal window:
              because u are not running in magic mirror , ‘this’ does not exist
              • i got an error message:
              • bash: Syntaxerror unexpected word `(’
                what am I doing wrong…
                bash would not see any ( unless u put it on the line with node
              node (something)
              that is a command to bash (the terminal window program, he has his own rules about parens, and other special characters (* means ALL filenames in this folder for example!)
              I never ever use $ in node_helper (or anywhere else)
              I would do this
              console.log (‘path: '+ this.path)
              • PerlchampP
                Perlchamp
                thank you. ok, i will test …
                only for your information:
                start() {
                		console.log(`Starting module helper: ${this.name}`);
                	stop(){
                this is from your SampleModule. i’m not here to reprimand you. it should only be information. so please do not misunderstand.
                  sdetweil @Perlchamp
                  @Perlchamp thanks… will fix… never copy from another without review!!
                  • PerlchampP
                    Perlchamp
                    always my pleasure
                      @Perlchamp fixed
                        if u redirect the output of npm start to a file, this is what you will see in the file
                        > magicmirror@2.11.0 start /home/sam/MagicMirror
                        [2020-04-30 11:15:53.521] [LOG]    Starting MagicMirror: v2.11.0
                        [2020-04-30 11:15:53.524] [LOG]    Loading config ...
                        [2020-04-30 11:15:53.526] [LOG]    Loading module helpers ...
                        [2020-04-30 11:15:53.528] [LOG]    Initializing new module helper ...
                        [2020-04-30 11:15:53.528] [LOG]    Module helper loaded: MMM-Logging
                        [2020-04-30 11:15:53.529] [LOG]    No helper found for module: alert.
                        [2020-04-30 11:15:53.529] [LOG]    No helper found for module: clock.
                        [2020-04-30 11:15:53.663] [LOG]    Initializing new module helper ...
                        [2020-04-30 11:15:53.663] [LOG]    Module helper loaded: MyCovid19
                        [2020-04-30 11:15:53.784] [LOG]    Initializing new module helper ...
                        [2020-04-30 11:15:53.785] [LOG]    Module helper loaded: MMM-AlexaControl
                        [2020-04-30 11:15:53.786] [LOG]    handler helper in init
                        [2020-04-30 11:15:53.786] [LOG]    Module helper loaded: MMM-SleepWake
                        [2020-04-30 11:15:53.786] [LOG]    All module helpers loaded.
                        [2020-04-30 11:15:53.820] [LOG]    Starting server on port 8090 ...
                        [2020-04-30 11:15:53.821] [INFO]   You're using a full whitelist configuration to allow for all IPs
                        [2020-04-30 11:15:53.823] [LOG]    Server started ...
                        [2020-04-30 11:15:53.823] [LOG]    Connecting socket for: MMM-Logging
                        [2020-04-30 11:15:53.824] [LOG]    Module helper started for MMM-Logging
                        [2020-04-30 11:15:53.824] [LOG]    Connecting socket for: MyCovid19
                        [2020-04-30 11:15:53.824] [LOG]    Starting node_helper for module: MyCovid19
                        [2020-04-30 11:15:53.824] [LOG]    path=/home/sam/MagicMirror/modules/MyCovid19
                        [2020-04-30 11:15:53.824] [LOG]    Connecting socket for: MMM-AlexaControl
                        [2020-04-30 11:15:53.824] [LOG]    MMM-AlexaControl helper, started...
                        [2020-04-30 11:15:53.824] [LOG]    Connecting socket for: MMM-SleepWake
                        [2020-04-30 11:15:53.825] [LOG]    handler helper in start
                        [2020-04-30 11:15:53.825] [LOG]    Sockets connected & modules started ...
                        [2020-04-30 11:15:53.906] [LOG]    Launching application.
                        [2020-04-30 11:15:53.928] [LOG]    setup for latent showing  // < --- from my module node_helper
                        [2020-04-30 11:15:54.487] [LOG]    requested file exists=modules/MyCovid19/states-rawdata-04-30-2020 sending back to module_13_MyCovid19_5731  // < --- from my module node_helper
                        [2020-04-30 11:15:54.490] [LOG]    requested file exists=modules/MyCovid19/countries-rawdata-04-30-2020 sending back to module_16_MyCovid19_7951  // < --- from my module node_helper
                        [2020-04-30 11:15:54.492] [LOG]    requested file exists=modules/MyCovid19/countries-rawdata-04-30-2020 sending back to module_14_MyCovid19_1721  // < --- from my module node_helper
                        [2020-04-30 11:15:54.493] [LOG]    requested file exists=modules/MyCovid19/countries-rawdata-04-30-2020 sending back to module_15_MyCovid19_91  // < --- from my module node_helper
                        [2020-04-30 11:15:54.498] [LOG]    requested file exists=modules/MyCovid19/countries-rawdata-04-30-2020 sending back to module_17_MyCovid19_2191  // < --- from my module node_helper
                        etc
                        • PerlchampP
                          Perlchamp
                          ok, it’s slowly dawning on me, see little light at the end of the tunnel
                            sdetweil @Perlchamp
                            @Perlchamp if u install the logging module I suggested, then it captures all the messages from the modulename.js in the browser and prints them to the terminal window log, which would be saved to the file as well.
                              @sdetweil a node_helper has two built in functions (I have never useed init() or stop() for anything, but they are available)
                              start: when the helper is loaded
                              socketNotificationReceived, when the modulename.js sends a message to the helper
                              the helper has one useful function
                              sendSocketNotification , to send a message back to the modulename.js
                              everything else is all up to you
                              note that the modulename.js gets the config.js config:{} info for this module, NOT the node_helper… so if the node_helper needs to know (filenames, timings, ???) , the modulename.js has to send a message with the this.config info down to the helper, and the helper has to save it to use later
                              • PerlchampP
                                Perlchamp
                                @sdetweil said in read csv-data and put it in an array:
                                so i also can do (?):
                                npm start dev
                                in the window on the right klicking on “console”. there i see a lot of massages coming from console/moduls
                                and then i can use your module to lock out other modules (?) …
                                  sdetweil @Perlchamp
                                  @Perlchamp
                                  npm start dev
                                  yes
                                  no… it collects all messages. so I add my module name to them…
                                  on windows the notepad++ editor allows you to find all, and gives a new window with the lines
                                  from where the find was done and allows u to click on the find results and navigate to the original file…
                                  very helpful when there is a big log and maybe only 1 or 2 specific messages u are looking for
                                  • PerlchampP
                                    Perlchamp
                                    ok, understand
                                    • PerlchampP
                                      Perlchamp
                                      i have another information for you (github - MMM-Logging):
                                      You can find more detailed information on debugging your MagicMirror here: Module Debugging. If you also want the Electron rederer (web browser) console logs to be printed to the standard console (or PM2 logs), change the following line to the very top of ~/MagicMirror/run-start.sh <<
                                      this file does not exist. i can’t find it in the file-manager (i see all hidden files) …
                                        sdetweil @Perlchamp
                                        @Perlchamp yeh, that shell script was removed in 2.11… again I copied someone elses module and improved it for me.
                                        you can do that
                                        export ELECTRON_ENABLE_LOGGING=true
                                        in the terminal window where you will do npm start
                                        but with my changes, I don’t think u need to do that instruction anymore…
                                        • PerlchampP
                                          Perlchamp
                                          ok, that’s fine
                                          • PerlchampP
                                            Perlchamp
                                            ok, now i can see the output of my csvtojson object. now the question about handle this all:
                                            is it better (csv-file) to call the rows ‘month of birth’, ‘birthday’, ‘year of birth’, ‘name’
                                            => mai,23,1964,stan smith
                                            or ‘birth’,name
                                            => 05.23.1964,stan smith
                                            how said:
                                            i want to display the birthdays of the current month, then the name and the age. if people should have birthday at the same day, they should listed, in which the daynumber only displayed once (=> two cells).
                                            what should happen, if the day of birth is over, i don’t know yet. there will be two options, i think, between the user can choose:
                                            1. delete the names on the list (with daynumber)
                                            2. dimm these entries.
                                              finally it should display like this:
                                            • 15
                                            • 16
                                            • 3 / 16
