    read csv-data and put it in an array
    313 Posts 3 Posters 535.7k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp log.log only works in the modulename.js (the part loaded in the browser)
      we call it that cause its filename matches the module name
      • PerlchampP Offline
        Perlchamp
        ok, thanks again :-)
          sdetweil @Perlchamp
          @Perlchamp u can redirect the output of npm start to a file, npm start >somefile
          u can minimize the window with alt-spacebar, n
          u can open the developers window ( for the modulename,js debugging) npm start dev
          or if mirror already running use f12 or ctrl-shift-i on the keyboard
          I debug from my PC, ssh connected to pi, or I run MM on my PC… and debug there
            Perlchamp
            what do you use for debugging on pc ?
            do you have x64 or arm-based pc ?
              sdetweil @Perlchamp
              @Perlchamp x64, run linux or windows (today on linux), doesn’t matter… same debug process… look at console or browser window
              if I need to debug modulename.js on pi, I open browser from PC to the mirror URL and do it there
                Perlchamp
                AND:
                thanks a lot for YOUR time. i hope it will not been wasted … i will working hard to get some results …
                  Perlchamp
                  @sdetweil said in read csv-data and put it in an array:
                  how ?
                    sdetweil @Perlchamp
                    @Perlchamp on MagicMirror, in config, set address:“0.0.0.0”,
                    And ipWhitelist:[],
                    Then u can connect to the mm url from anywhere in your house/office.
                    http://ipaddress:port
                    Then f12 or ctrl-shift-i on the browser keyboard to open the developers window.
                      Perlchamp
                      ok thank.
                      if i want to test
                          readCSV: fs.readFile('birthdaylist.csv', 'utf8', function (err, data) {
                      	var dataArray = data.split(/\r?\n/);
                      	Log.log(dataArray);
                      or
                      readList: function() {
                      	var JFile=require('jfile');
                      	var myF=new JFile("MMM-birthday.txt");
                      	myF.lines // ["first line","second line"]
                      i have to do this in node_helper right? and first i have to require them and of course to install them … something i forgot ?
                        sdetweil @Perlchamp
                        @Perlchamp Log.log is ONLY in the browser, but fs. Is not usable in browser
                        U can test it w node to make sure it works. Then for mm it has to be in node_helper
                        Install library, so that you CAN require
                          Perlchamp
                          hallo sam :-)
                          i have now this in my node_helper.js:
                          var NodeHelper = require("node_helper");
                          // add require of other javascripot components here
                          // var xxx = require('yyy'); here
                          const csv = require("csvtojson");
                          const csvFilePath = this.path + 'birthdaylist.csv';
                          	init(){
                          		console.log("init module helper perlchamp");
                          	start() {
                          		console.log("Starting module helper: ${this.name}");
                          		console.log("dieser Pfad: ${this.path}");
                          		csv()
                          		.fromFile(csvFilePath)
                          		.then((jsonObj)=>{
                          			console.log(jsonObj);
                          	stop(){
                          		console.log(`Stopping module helper: ${this.name}`);
                          	// handle messages from our module// each notification indicates a different messages
                          	// payload is a data structure that is different per message.. up to you to design this
                          	socketNotificationReceived(notification, payload) {
                          		console.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                          		// if config message from module
                          		if (notification === "CONFIG") {
                          			// save payload config info
                          			this.config=payload
                          			// wait 15 seconds, send a message back to module
                          			setTimeout(()=> { this.sendSocketNotification("message_from_helper"," this is a test_message")}, 15000)
                          		else if(notification === "????2") {
                          terminal says:
                          Unhandled rejection Error: File does not exist. Check to make sure the file path to your csv is correct.
                              at /home/dirk/MagicMirror/node_modules/csvtojson/v2/Converter.js:81:37
                              at suppressedCallback (fs.js:209:5)
                              at FSReqCallback.oncomplete (fs.js:153:23)
                          it’s from your SampleModule …
                          1. how can i see the console.log statements in the browser, starting MM ?
                          2. did i enter the code in the right place?
                          3. if I enter the following into the terminal window:
                            node console.log (‘path: $ {this.path}’)
                            i got an error message:
                            bash: Syntaxerror unexpected word `(’
                            what am I doing wrong ?
                          many thanks in advance
                            sdetweil @Perlchamp
                            @Perlchamp said in read csv-data and put it in an array:
                            • how can i see the console.log statements in the browser, starting MM ?
                              cannot see node_helper messages in browser, must look in the terminal window where u did npm start
                              you can redirect those messages to a file
                              npm start >somefile
                              and then look at somefile live with editor
                            • did i enter the code in the right place?
                              const csvFilePath = this.path + ‘birthdaylist.csv’;
                              u have this.path outside the NodeHelper.create, at that time ‘this’ does not exist
                              ‘this’ means ‘instance of’, and u are outside the thing that creates the instance
                            • if I enter the following into the terminal window:
                            because u are not running in magic mirror , ‘this’ does not exist
                            • i got an error message:
                            • bash: Syntaxerror unexpected word `(’
                              what am I doing wrong…
                              bash would not see any ( unless u put it on the line with node
                            node (something)
                            that is a command to bash (the terminal window program, he has his own rules about parens, and other special characters (* means ALL filenames in this folder for example!)
                            I never ever use $ in node_helper (or anywhere else)
                            I would do this
                            console.log (‘path: '+ this.path)
                              Perlchamp
                              thank you. ok, i will test …
                              only for your information:
                              start() {
                              		console.log(`Starting module helper: ${this.name}`);
                              	stop(){
                              this is from your SampleModule. i’m not here to reprimand you. it should only be information. so please do not misunderstand.
                                sdetweil @Perlchamp
                                @Perlchamp thanks… will fix… never copy from another without review!!
                                  Perlchamp
                                  always my pleasure
                                    @Perlchamp fixed
                                      if u redirect the output of npm start to a file, this is what you will see in the file
                                      > magicmirror@2.11.0 start /home/sam/MagicMirror
                                      [2020-04-30 11:15:53.521] [LOG]    Starting MagicMirror: v2.11.0
                                      [2020-04-30 11:15:53.524] [LOG]    Loading config ...
                                      [2020-04-30 11:15:53.526] [LOG]    Loading module helpers ...
                                      [2020-04-30 11:15:53.528] [LOG]    Initializing new module helper ...
                                      [2020-04-30 11:15:53.528] [LOG]    Module helper loaded: MMM-Logging
                                      [2020-04-30 11:15:53.529] [LOG]    No helper found for module: alert.
                                      [2020-04-30 11:15:53.529] [LOG]    No helper found for module: clock.
                                      [2020-04-30 11:15:53.663] [LOG]    Initializing new module helper ...
                                      [2020-04-30 11:15:53.663] [LOG]    Module helper loaded: MyCovid19
                                      [2020-04-30 11:15:53.784] [LOG]    Initializing new module helper ...
                                      [2020-04-30 11:15:53.785] [LOG]    Module helper loaded: MMM-AlexaControl
                                      [2020-04-30 11:15:53.786] [LOG]    handler helper in init
                                      [2020-04-30 11:15:53.786] [LOG]    Module helper loaded: MMM-SleepWake
                                      [2020-04-30 11:15:53.786] [LOG]    All module helpers loaded.
                                      [2020-04-30 11:15:53.820] [LOG]    Starting server on port 8090 ...
                                      [2020-04-30 11:15:53.821] [INFO]   You're using a full whitelist configuration to allow for all IPs
                                      [2020-04-30 11:15:53.823] [LOG]    Server started ...
                                      [2020-04-30 11:15:53.823] [LOG]    Connecting socket for: MMM-Logging
                                      [2020-04-30 11:15:53.824] [LOG]    Module helper started for MMM-Logging
                                      [2020-04-30 11:15:53.824] [LOG]    Connecting socket for: MyCovid19
                                      [2020-04-30 11:15:53.824] [LOG]    Starting node_helper for module: MyCovid19
                                      [2020-04-30 11:15:53.824] [LOG]    path=/home/sam/MagicMirror/modules/MyCovid19
                                      [2020-04-30 11:15:53.824] [LOG]    Connecting socket for: MMM-AlexaControl
                                      [2020-04-30 11:15:53.824] [LOG]    MMM-AlexaControl helper, started...
                                      [2020-04-30 11:15:53.824] [LOG]    Connecting socket for: MMM-SleepWake
                                      [2020-04-30 11:15:53.825] [LOG]    handler helper in start
                                      [2020-04-30 11:15:53.825] [LOG]    Sockets connected & modules started ...
                                      [2020-04-30 11:15:53.906] [LOG]    Launching application.
                                      [2020-04-30 11:15:53.928] [LOG]    setup for latent showing  // < --- from my module node_helper
                                      [2020-04-30 11:15:54.487] [LOG]    requested file exists=modules/MyCovid19/states-rawdata-04-30-2020 sending back to module_13_MyCovid19_5731  // < --- from my module node_helper
                                      [2020-04-30 11:15:54.490] [LOG]    requested file exists=modules/MyCovid19/countries-rawdata-04-30-2020 sending back to module_16_MyCovid19_7951  // < --- from my module node_helper
                                      [2020-04-30 11:15:54.492] [LOG]    requested file exists=modules/MyCovid19/countries-rawdata-04-30-2020 sending back to module_14_MyCovid19_1721  // < --- from my module node_helper
                                      [2020-04-30 11:15:54.493] [LOG]    requested file exists=modules/MyCovid19/countries-rawdata-04-30-2020 sending back to module_15_MyCovid19_91  // < --- from my module node_helper
                                      [2020-04-30 11:15:54.498] [LOG]    requested file exists=modules/MyCovid19/countries-rawdata-04-30-2020 sending back to module_17_MyCovid19_2191  // < --- from my module node_helper
                                      etc
                                        Perlchamp
                                        ok, it’s slowly dawning on me, see little light at the end of the tunnel
                                          sdetweil @Perlchamp
                                          @Perlchamp if u install the logging module I suggested, then it captures all the messages from the modulename.js in the browser and prints them to the terminal window log, which would be saved to the file as well.
                                            @sdetweil a node_helper has two built in functions (I have never useed init() or stop() for anything, but they are available)
                                            start: when the helper is loaded
                                            socketNotificationReceived, when the modulename.js sends a message to the helper
                                            the helper has one useful function
                                            sendSocketNotification , to send a message back to the modulename.js
                                            everything else is all up to you
                                            note that the modulename.js gets the config.js config:{} info for this module, NOT the node_helper… so if the node_helper needs to know (filenames, timings, ???) , the modulename.js has to send a message with the this.config info down to the helper, and the helper has to save it to use later
                                            • 15
                                            • 16
                                            • 3 / 16
