    read csv-data and put it in an array
    313 Posts 3 Posters 590.1k Views 4 Watching
    • PerlchampP
      Perlchamp
      ok, thank you sam.
      Now I have to process the whole thing first, otherwise my head will burst ;-) …
      • PerlchampP
        Perlchamp
        this is the actual node_helper.js:
        var NodeHelper = require("node_helper");
        var moment = require("moment");
        // add require of other javascripot components here
        // var xxx = require('yyy'); here
        const csv = require("csvtojson");
        var birthdaysArray = [];
        	init(){
        		console.log("init module helper perlchamp");
        	start() {
        		console.log("Starting module helper: " + this.name);
        		//console.log("Pfad zur csv-Datei: ", this.path + "/data/birthdays.csv");
        		moment.locale(config.language);  // set locale
        		// convert the csv-file into a JSON-String
        		const csvFilePath = this.path + '/data/birthdays.csv';
        		csv()
        		.fromFile(csvFilePath)
        		.then((jsonObj)=>{
        			birthdaysArray = JSON.stringify(jsonObj);
        			// for debugging only
        			//console.log("birthdaysArray: ", birthdaysArray);
        			// send data to [modulname].js
        			self.sendsocketNotification("have data", birthdaysArray)
        			// loop thru the array of birthday_info from file (jsonObj),
        			// one 'row' per birthday
        	stop(){
        		console.log("Stopping module helper: " + this.name);
        	// handle messages from our module// each notification indicates a different messages
        	// payload is a data structure that is different per message.. up to you to design this
        	socketNotificationReceived(notification, payload) {
        		// if config message from module
        		if (notification === "CONFIG") {
        			// save payload config info
        			this.config=payload
        			// wait 15 seconds, send a message back to module
        			setTimeout(()=> { this.sendSocketNotification("message_from_helper"," this is a test_message")}, 15000)
        		else if(notification === "????2") {
        i got an error-message :
        [2020-05-01 23:21:12.072] [WARN]   Unhandled rejection ReferenceError: self is not defined
            at /home/dirk/MagicMirror/modules/perlchamp/node_helper.js:34:4
        i think this could be the problem:
        i tried “this.” and without “self.” and “this.” but nothing changed. now i’m searching in the web, maybe i will found some answers ;-)
        • PerlchampP
          Perlchamp
          i have found a typing error. Socket instead socket. if i than change self. to this. no errror messages will displayed. but still black screen.
          maybe i did not understand how to handle the getDom-section … i will still try …
          but:
          i see no notification in the terminal. ‘have data’ should actually appear there, shouldn’t it ?
            sdetweil @Perlchamp
            @Perlchamp
            do this, you need self
            start() {
            		var self = this
            the use self
                            self.sendsocketNotification("have data", jsonObj)
            u need to send the obj, not the string
            as for black screen , that means the modulename side died…
            f12 on the keyboard or ctrl-shift-i, select the console tab, and look for red text … usually a syntax error…
              @Perlchamp
              no, the message is sent to the modulename.js side of your module…
              using my sample code , right here
                      // messages received from from your node helper (NOT other modules or the system)
              	// payload is a notification dependent data structure, up to you to design between module and node_helper
                the two parts look like this
                |                                  browser  side                                                 |
                |                                       modulename.js (SampleModule.js)                          |
                |     receive (socketNotificationReceived)                send ( sendSocketNotification)         |
                                    |                                                     V
                |      send ( sendSocketNotification)                   receive (socketNotificationReceived)     |
                |                                       node_helper.js                                           |
                |                                  server side                                                   |
                • PerlchampP
                  Perlchamp
                  yes, i understood. here’s my perlchamp.js (only socketNitificationReceived)
                  		Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                  		if(notification === "message_from_helper"){
                  			this.config.message = payload;
                  			// tell mirror runtime that our data has changed,
                  			// we will be called back at GetDom() to provide the updated content
                  			this.updateDom(1000)
                  		if(notification === "have data"){
                  			var now = moment()
                  			var active_birthdays={}
                  			for( var birthday of payload) {
                  				// get 1st 5 chars of birthdate, thru month
                  				// we will use this as the key in the hash
                  				var birth_date = birthday.birth.subString(0,4)
                  				Log.log("Tag.Monat :", birth_date)
                  				// get the birthday as a moment in this year, for comparing
                  				var birth_date_moment = moment(birth_date + now.getYear(),"DD.MMYYYY")
                  				// u can add days to a moment object and then compare
                  				//     if the birthdate is before that date (and after now)
                  				//     so within the next xx days
                  				// if the date is the same or later, don't use time of day
                  				if(birth_date.startOf('day').isSame(now.startOf('day')){
                  					// birthday is in this month
                  					// check the hash if we've seen anything for today yet
                  					// if we haven't see this date yet
                  					if(active_birthdays[birth_date] == undefined){
                  						//  create the holder for its info (array of
                  						//		names) in the hash
                  						active_birthdays[birth_date] = []
                  					// save the persons name on the list
                  					active_birthdays[birth_date].push(birthday.name)
                  			// tell MM to call and get our content
                  			self.updateDom();
                    sdetweil @Perlchamp
                    @Perlchamp very good… now, I didn’t test the code I wrote, so there are a couple errors…
                    but you should be able to see that code in the developers window, sources tab,
                    navigate on the left tree, modules, your module_name (which has to be perchamp,
                    folder, filename and the register at the top) all have to match)
                    • PerlchampP
                      Perlchamp
                      i can’t find … so everything’s right ?
                        sdetweil @Perlchamp
                        @Perlchamp you shouldScreenshot at 2020-05-01 18-12-15.png see an error like this
                        note that I put part of the module name in the filter field
                        • PerlchampP
                          Perlchamp
                          ok, thanks
                            sdetweil @Perlchamp
                            @Perlchamp and if something not spelled right (this image also shows the module tree navigation on the left)
                            when its used !
                            • PerlchampP
                              Perlchamp
                              so, sam, everything is fixed :-)
                              but now i don’t know how to handle the receiving data. i only need a little entry … don’t know how to handle this object-element. actually nothing is displayed except the header i configured …
                                sdetweil @Perlchamp
                                @Perlchamp cool, now you’ve collected the data… you should be able to see the results on the exit from the notification handler…
                                now to tell MM to come get the stuff to display…
                                thats the self.updateDom() call
                                hey MM, get my stuff
                                then MM will call getDom()
                                I have implemented the module too
                                getDom: function() {
                                		for(var birthday of Object.keys(this.active_birthdays)){
                                				for(var name of this.active_birthdays[birthday]){
                                					var m=document.createElement('div')
                                					m.innerText=birthday + ' '+ name
                                					wrapper.appendChild(m)
                                		// pass the created content back to MM to add to DOM.
                                		return wrapper;
                                  @Perlchamp one thing to watch out for, getDom() will be called immediately, long before you have any data,
                                  but you MUST return something… so an empty div works… (this is where that 'Loading…" message would be presented
                                  • PerlchampP
                                    Perlchamp
                                    black screen, again. this is my perlchamp.js:
                                    Module.register("perlchamp", {
                                    	defaults: {
                                    		language: "de",
                                    		dimmEntries: true   // true: dims entries and the associated
                                    							//       symbol when the date has expired.
                                    							// false: delete entries and the associated
                                    	init: function(){
                                    		Log.log(this.name + " is in init!");
                                    	start: function(){
                                    		Log.log("Starting module: " + this.name);
                                    		// Set locale
                                    	loaded: function(callback) {
                                    		Log.log(this.name + " is loaded!");
                                    		callback();
                                    	// return list of other functional scripts to use, if any (like require in node_helper)
                                    	getScripts: function() {
                                    		return	["moment.js"];
                                    	// return list of stylesheet files to use if any
                                    	getStyles: function() {
                                    		return 	[this.data.path + "/css/perlchamp.css"];
                                    	// return list of translation files to use, if any
                                    	getTranslations: function() {
                                    		return {
                                    			// sample of list of files to specify here, if no files, do not use this routine, , or return empty list
                                    			// en: "translations/en.json",  (folders and filenames in your module folder)
                                    			// de: "translations/de.json"
                                    	// only called if the module header was configured in module config in config.js
                                    	getHeader: function() {
                                    		return this.data.header;
                                    	// messages received from other modules and the system (NOT from your node helper)
                                    		// once everybody is loaded up
                                    		if(notification==="ALL_MODULES_STARTED"){
                                    			// send our config to our node_helper
                                    			this.sendSocketNotification("CONFIG",this.config);
                                    		if (sender) {
                                    			Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
                                    		} else {
                                    			Log.log(this.name + " received a system notification: " + notification);
                                    			this.updateDom(1000);
                                    			var now = moment();
                                    			var active_birthdays = {};
                                    			for(var birthday of payload) {
                                    				var birth_date = birthday.birth.subString(0,4);
                                    				var birth_date_moment = moment(birth_date + now.getYear(),"DD.MMYYYY");
                                    				if(birth_date.startOf('day').isSame(now.startOf('day'))) {
                                    						active_birthdays[birth_date] = [];
                                    					active_birthdays[birth_date].push(birthday.name);
                                    			self.updateDom();
                                    			// filters the birthdaylist and output only the birthdays
                                    			// of the current month, sorted (ascending) by days in
                                    			// the following format:
                                    			// [{ day: "10", name: ["firstname lastname",...] }]
                                    			// set variables
                                    			var today_month = moment().format("MM");
                                    			var today_day_month = moment().format("DD.MM");
                                    			var result = Object.entries(jsonObj
                                    			.filter(({birth}) => birth.split('.')[1] === today_month)
                                    			.reduce((a, {birth, name}) => {
                                    				const day = +birth.split('.')[0];
                                    				a[day] = [...(a[day] || []), name];
                                    				return a
                                    			).map(([day, name]) => ({day, name})).sort((a, b) => +a.day - b.day);
                                    			birthdaysArray = result;
                                    			//console.log("filtered and sorted: ", birthdaysArray);
                                    	// system notification your module is being hidden
                                    	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
                                    	suspend: function(){
                                    	// system notification your module is being unhidden/shown
                                    	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
                                    	resume: function(){
                                    	// this is the major worker of the module, it provides the displayable content for this module
                                    				var m = document.createElement('div');
                                    				m.innerText = birthday + ' '+ name;
                                    				wrapper.appendChild(m);
                                    		return wrapper;
                                    this the node_helper.js:
                                    	init(){
                                    	start() {
                                    		var self = this;
                                    		csv()
                                    		.then((jsonObj)=>{
                                    			self.sendSocketNotification("have data", jsonObj);
                                    	stop(){
                                    			this.config = payload;
                                    			setTimeout(()=> { this.sendSocketNotification("message_from_helper"," this is a test_message")}, 15000);
                                    these are the terminal outputs:
                                    dirk@raspberrypi:~/MagicMirror/modules/perlchamp $ npm start
                                    > magicmirror@2.11.0 start /home/dirk/MagicMirror
                                    [2020-05-02 02:52:02.407] [LOG]    Starting MagicMirror: v2.11.0
                                    [2020-05-02 02:52:02.414] [LOG]    Loading config ...
                                    [2020-05-02 02:52:02.418] [LOG]    Loading module helpers ...
                                    [2020-05-02 02:52:02.424] [LOG]    Initializing new module helper ...
                                    [2020-05-02 02:52:02.425] [LOG]    Module helper loaded: MMM-Logging
                                    [2020-05-02 02:52:02.579] [LOG]    init module helper perlchamp
                                    [2020-05-02 02:52:02.580] [LOG]    Module helper loaded: perlchamp
                                    [2020-05-02 02:52:02.580] [LOG]    All module helpers loaded.
                                    [2020-05-02 02:52:02.711] [LOG]    Starting server on port 8080 ...
                                    [2020-05-02 02:52:02.718] [INFO]   You're using a full whitelist configuration to allow for all IPs
                                    [2020-05-02 02:52:02.726] [LOG]    Server started ...
                                    [2020-05-02 02:52:02.727] [LOG]    Connecting socket for: MMM-Logging
                                    [2020-05-02 02:52:02.727] [LOG]    Module helper started for MMM-Logging
                                    [2020-05-02 02:52:02.728] [LOG]    Connecting socket for: perlchamp
                                    [2020-05-02 02:52:02.728] [LOG]    Starting module helper: perlchamp
                                    [2020-05-02 02:52:02.732] [LOG]    Sockets connected & modules started ...
                                    [2020-05-02 02:52:02.829] [LOG]    Launching application.
                                    [2020-05-02 02:52:04.803] [LOG]    Starting module: perlchamp (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                    [2020-05-02 02:52:04.805] [LOG]    All modules started! (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:37 Class.socketNotificationReceived)
                                    [2020-05-02 02:52:04.806] [LOG]     payload: undefined (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:31 Class.socketNotificationReceived)
                                    [2020-05-02 02:52:04.807] [LOG]    perlchamp received a system notification: ALL_MODULES_STARTED (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                    [2020-05-02 02:52:04.810] [ERROR]  {} (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:43 Class.socketNotificationReceived)
                                    [2020-05-02 02:52:04.811] [LOG]    Browser Error: {} (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:46 Class.socketNotificationReceived)
                                    [2020-05-02 02:52:07.185] [LOG]    Shutting down server... (/home/dirk/MagicMirror/js/electron.js:105 App.<anonymous>)
                                    [2020-05-02 02:52:07.188] [LOG]    Stopping module helper: MMM-Logging (/home/dirk/MagicMirror/js/node_helper.js:33 Class.stop)
                                    [2020-05-02 02:52:07.190] [LOG]    Stopping module helper: perlchamp (/home/dirk/MagicMirror/modules/perlchamp/node_helper.js:39 Class.stop)
                                    i didn’t never seen the notification “have data” …
                                    • PerlchampP
                                      Perlchamp
                                      this is the getDom-section where the data finally should be placed (perlchamp is for testing) :
                                      	if ((moment() > this.midnight) || (!this.loaded)) {
                                      	    var month = moment().month();
                                      	    var year = moment().year();
                                      	    var monthName = moment().format("MMMM");
                                      	    var monthLength = moment().daysInMonth();
                                      	    // tabelle erstellen
                                      	    var wrapper = document.createElement("table");
                                      	    wrapper.className = 'table';
                                      	    wrapper.id = 'birthday-table';
                                      	    // tabellenkopf erstellen
                                      	    var tHeader = document.createElement("thead");
                                      	    tHeader.className = "thead";
                                      	    tHeader.id = "birthday-thead";
                                      	    var headerTR = document.createElement("tr");
                                      	    headerTR.className = "tr-head";
                                      	    headerTR.id = "birthday-tr-head";
                                      	    var headerTH = document.createElement("th");
                                      	    headerTH.colSpan = "2";
                                      	    headerTH.scope = "col";
                                      	    headerTH.className = "th-head";
                                      	    headerTH.id = "birthday-th-head";
                                      	    headerTH.innerHTML = this.translate(this.config.title);
                                      	    headerTR.appendChild(headerTH);
                                      	    tHeader.appendChild(headerTR);
                                      	    wrapper.appendChild(tHeader);
                                      	    // Create TFOOT section -- currently used for debugging only
                                      	    var tFooter = document.createElement('tfoot');
                                      	    tFooter.className = "tfoot";
                                      	    tFooter.id = "birthday-tfoot";
                                      	    var footerTR = document.createElement("tr");
                                      	    footerTR.className = "tr-foot";
                                      	    footerTR.id = "birthday-tr-foot";
                                      	    var footerTD = document.createElement("td");
                                      	    footerTD.colSpan ="2";
                                      	    footerTD.className = "td-foot";
                                      	    footerTD.id = "birthday-td-foot";
                                      	    if (this.config.debugging) {
                                      		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
                                      	    else {
                                      		footerTD.innerHTML = "";
                                      	    footerTR.appendChild(footerTD);
                                      	    tFooter.appendChild(footerTR);
                                      	    wrapper.appendChild(tFooter);
                                      	    // Create TBODY section with day names
                                      	    var eintraege = 3;
                                      	    for (var i=1; i<=eintraege; i++) {
                                      		var tBody = document.createElement("tBody");
                                      		tBody.className = "tbody";
                                      		tBody.id = "birthday-tbody";
                                      		var bodyTR = document.createElement("tr");
                                      		bodyTR.className = "tr-body";
                                      		bodyTR.id = "birthday-tr-body";
                                      		var bodyTDimage = document.createElement("td");
                                      		bodyTDimage.className = "td-image";
                                      		bodyTDimage.id = "birthday-td-image";
                                      		bodyTDimage.innerHTML = "23";
                                      		var bodyTD = document.createElement("td");
                                      		bodyTD.className = "td-body";
                                      		bodyTD.id = "birthday-td-body";
                                      		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;<span class=\"age-span\">46</span></br>Frank Dubiel&nbsp;&nbsp;<span class=\"age-span\">54</span></br>Jürgen Gruse&nbsp;&nbsp;<span class=\"age-span\">52</span>";
                                      		var bodyAgeSpan = document.createElement("span");
                                      		bodyAgeSpan.className = "age-span";
                                      		bodyAgeSpan.id = "birthday-age-span";
                                      		bodyAgeSpan.innerHTML = "&nbsp;&nbsp;46";
                                      		bodyTD.appendChild(bodyAgeSpan);
                                      		bodyTR.appendChild(bodyTDimage);
                                      		bodyTR.appendChild(bodyTD);
                                      		tBody.appendChild(bodyTR);
                                      		wrapper.appendChild(tBody);
                                      	    this.loaded = true;
                                      	    return wrapper;
                                      the data here are text, ifilles in, no variables …
                                        sdetweil @Perlchamp
                                        @Perlchamp ok, couple problems… in teh notification handler we write to active_birthdays,
                                        but it is a variable local to this routine… so, when this routine ends, it goes awau
                                        need to move its definition to the top
                                        	defaults: {
                                        		language: "de",
                                            active_birthdays : {},
                                        then add ‘this.’ in front of it in the notification handler
                                        (and remove the var activebirthdays)
                                        now it is an instance variable (one per browser)
                                        also, I spelled substring wrong (I had it subString, its substring )
                                        gotta run to store, back in a little bit
                                        • PerlchampP
                                          Perlchamp
                                          ok, be carefully. keep corona away. use mouth and nose protection and wear disposable gloves !
                                          thanks, but doesn’t work. it seems, that i’m too stupid for this ?
                                          modified perlchamp.js:
                                          	defaults: {
                                          		language: "de",
                                          	active_birthdays: {
                                          	init: function(){
                                          	start: function(){
                                          		// Set locale
                                          		callback();
                                          		if (sender) {
                                          		} else {
                                          			var now = moment();
                                          				var birth_date = birthday.birth.substring(0,4);
                                          					if(this.active_birthdays[birth_date] == undefined){
                                          						this.active_birthdays[birth_date] = [];
                                          					this.active_birthdays[birth_date].push(birthday.name);
                                          			self.updateDom();
                                          	resume: function(){
                                          		return wrapper;
                                          in node_helper.js was nothing to be changed. maybe I put a few semicolons where none have to go?
                                            sorry, forgot one thing i saw in node helper,… need to move everything in the start function to the socketNotification section… at start time the module is not up yet, so the message goes nowhere
                                            	var self = this
                                            			var self = this;
                                            			const csvFilePath = this.path + '/birthdays.csv';
                                            			csv()
                                            			.then((jsonObj)=>{
                                            				console.log("birthdaysArray: ", JSON.stringify(birthdaysArray));
                                            also, by moving it here, all you have to do is fix the code, save and then refresh the page… don’t have to restart MM
                                            start is now empty
                                            	start() {
                                            • 15
                                            • 16
                                            • 5 / 16
