    read csv-data and put it in an array
    313 Posts 3 Posters 579.1k Views 4 Watching
    • PerlchampP
      Perlchamp
      @sdetweil said in read csv-data and put it in an array:
      ok, went to numbers, SO much easier!!
      ok, i will try. therefor my array don’t match, i think … that’s right ?
        sdetweil @Perlchamp
        @Perlchamp the new data matches my new code
        • PerlchampP
          Perlchamp
          thanks, but now i’m a little bit confused, because my master problem will be, to reorg the array, to combine people with the same date of birth in as list in one row with the day of birth. but let me try …
            sdetweil @Perlchamp
            @Perlchamp ok, this was just to give you ideas on how to access the data… in a useful way
            • PerlchampP
              Perlchamp
              … and I’m very grateful to you for that. I learn from your messages every time. I think it’s great that there are people like you. that also costs time (apart from health, the most important thing in life). Thanks again for that!
              • PerlchampP
                Perlchamp
                hi sam,
                i have a major problem, that i don’t understand. this is my code in node_helper.js:
                var NodeHelper = require("node_helper");
                var moment = require("moment");
                // add require of other javascripot components here
                // var xxx = require('yyy'); here
                const csv = require("csvtojson");
                var birthdaysArray = [];
                	init(){
                		console.log("init module helper perlchamp");
                	start() {
                		console.log("Starting module helper: " + this.name);
                		//	console.log("Pfad zur csv-Datei: " + this.path + "/data/birthdays.csv");
                		const csvFilePath = this.path + '/data/birthdays.csv';
                		csv()
                		.fromFile(csvFilePath)
                		.then((jsonObj)=>{
                			birthdaysArray = JSON.stringify(jsonObj);
                			console.log("birthdaysArray: " + birthdaysArray);
                			var today_day_month = moment().format("DD.MM");
                			var today_month = moment().format("MM");
                		console.log("birthdaysArray #2: " + birthdaysArray);
                		// moment.js
                		moment.locale(config.language);  // set locale
                		console.log("aktuelle Zeit: " + moment().format('Do MMMM YYYY, hh:mm:ss'));
                		console.log("aktueller Monat(Zahl): " + moment().format('MM'));
                		console.log("aktueller Monat(Text): " + moment().format('MMM'));
                		console.log("aktueller Tag(Zahl mit führender Null): " + moment().format('DD'));
                		console.log("aktueller Tag(Text): " + moment().format('dddd'));
                		console.log("aktueller Tag(Abkürzung): " + moment().format('dd'));
                		console.log("aktuelles Jahr(Zahl): " + moment().format('YYYY'));
                	stop(){
                		console.log("Stopping module helper: " + this.name);
                	// handle messages from our module// each notification indicates a different messages
                	// payload is a data structure that is different per message.. up to you to design this
                	socketNotificationReceived(notification, payload) {
                		//	console.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                		console.log(this.name + " received a socket notification: " + birthdays);
                		// if config message from module
                		if (notification === "CONFIG") {
                			// save payload config info
                			this.config=payload
                			// wait 15 seconds, send a message back to module
                			setTimeout(()=> { this.sendSocketNotification("message_from_helper"," this is a test_message")}, 15000)
                		else if(notification === "????2") {
                why returns
                nothing.
                many thanks in advance
                • PerlchampP
                  Perlchamp
                  should be
                  console.log(this.name + " received a socket notification: " + birthdaysArray);
                  of course. couldn’t edit it, because of spam-message from board …
                    sdetweil @Perlchamp
                    @Perlchamp said in read csv-data and put it in an array:
                    > 		csv()
                    > 		.then((jsonObj)=>{
                    welcome to programming with a asyncronous libraries
                    csv().fromFile(csvFilePath) starts a ‘long’ operation,
                    going out to disk, reading in the data, and converting it to json from spreadsheet… (long is milliseconds)
                    the processor should not wait, so it does not, and the next instruction AFTER the start of the fromFile()
                    is console.log("birthdaysArray #2: " + birthdaysArray);
                    	// moment.js
                    and the start function runs out of things to do and returns back to MM…
                    sometime later , the fromFile() will complete, and call the .then() routine with the data
                    (jsonObj)=>{
                    so, if you need to wait for the data(to prints is content) , then the operations would be inside the .then() handler.
                    • PerlchampP
                      Perlchamp
                      ok, thanks. to move the code is not heavy ;-) … i’ve found a snippte to sort my birthdaysArray, but that doesn’t match :
                      		csv()
                      		.then((jsonObj)=>{
                      		var result = Object.entries(birthdaysArray.reduce((a, {birth, name}) => {
                      			const day = +birth.split('.')[0];
                      			a[day] = [...(a[day] || []), name];
                      			return a
                      		}, {})).map(([day, name]) => ({day, name})).sort((a, b) => +a.day - b.day)
                      		console.log("sorted birthdays : " + result);
                      now i’m looking for another one. is the birthdaysArray a json-Array or a javascript-array or … someone told me, it’s an object-Array and that this has nothing to do witch json … but: csvtojson, so …
                      • PerlchampP
                        Perlchamp
                        so i’m bloody happy :
                        	init(){
                        	start() {
                        		console.log("Pfad zur csv-Datei: ", this.path + "/data/birthdays.csv");
                        		csv()
                        		.then((jsonObj)=>{
                        			console.log("birthdaysArray: ", birthdaysArray);
                        		var result = Object.entries(jsonObj.reduce((a, {birth, name}) => {
                        			return a
                        		console.log("sorted birthdays : ", result);
                        	stop(){
                        			this.config=payload
                        so now I just have to manage to filter out the people from the complete csv-file who have their birthday in the current month …
                        • PerlchampP
                          Perlchamp
                          if i run :
                          		for(var birthday of birthdaysArray) {
                          			if(birthday.birth.startsWith(today_day_month)) {
                          				// this birthday is for today
                          				console.log(" birthday on "+ today_day_month+" is for "+birthday.name);
                          than i get the following error-messages:
                           Unhandled rejection TypeError: Cannot read property 'startsWith' of undefined
                              at /home/dirk/MagicMirror/modules/perlchamp/node_helper.js:33:22
                              at Object.onfulfilled (/home/dirk/MagicMirror/node_modules/csvtojson/v2/Converter.js:112:33)
                              at Result.endProcess (/home/dirk/MagicMirror/node_modules/csvtojson/v2/Result.js:83:50)
                              at Converter.processEnd (/home/dirk/MagicMirror/node_modules/csvtojson/v2/Converter.js:179:21)
                              at /home/dirk/MagicMirror/node_modules/csvtojson/v2/Converter.js:172:19
                              at tryCatcher (/home/dirk/MagicMirror/node_modules/bluebird/js/release/util.js:16:23)
                              at Promise._settlePromiseFromHandler (/home/dirk/MagicMirror/node_modules/bluebird/js/release/promise.js:547:31)
                              at Promise._settlePromise (/home/dirk/MagicMirror/node_modules/bluebird/js/release/promise.js:604:18)
                              at Promise._settlePromise0 (/home/dirk/MagicMirror/node_modules/bluebird/js/release/promise.js:649:10)
                              at Promise._settlePromises (/home/dirk/MagicMirror/node_modules/bluebird/js/release/promise.js:729:18)
                              at _drainQueueStep (/home/dirk/MagicMirror/node_modules/bluebird/js/release/async.js:93:12)
                              at _drainQueue (/home/dirk/MagicMirror/node_modules/bluebird/js/release/async.js:86:9)
                              at Async._drainQueues (/home/dirk/MagicMirror/node_modules/bluebird/js/release/async.js:102:5)
                              at Immediate.Async.drainQueues [as _onImmediate] (/home/dirk/MagicMirror/node_modules/bluebird/js/release/async.js:15:14)
                              at processImmediate (internal/timers.js:439:21)
                          I was probably happy too early ;-( … shit happens.
                            sdetweil @Perlchamp
                            @Perlchamp you converted the array to text format, so now its just one big string…
                            to print it out do this
                                                    birthdaysArray = jsonObj;
                            			console.log("birthdaysArray: "+JSON.stringify(jsonObj););
                            why do you need to sort them?
                            as you go thru you can just not save the ones not for today, plus/minus some lookahead
                            once you get to the today list you can sort the names if you need to.
                              sdetweil @Perlchamp
                              json is a TEXT structure…
                              but it just so happens that javascript represents objects the same way… so the JSON library provides utilities to convert in both directions.
                              json text to object JSON.parse(text)
                              object to json text JSON.stringify(object)
                              text is text and has no meaning (its called opaque because u cannot tell what it is)
                              no reason to split the birthdate, as u won’t do anything with the individual parts
                              don’t do work if u don’t need the results
                              you do NOT Need to do this data reformatting IN the node helper… you can do it all in the modulename.js file, which would let you use the code debugger in the dev console.
                              in the .then of the node_helper csvtojson, just send the data to the module
                              self.sendsocketNotification(“have data”, jsonObj)
                              and the helper is done
                              on the modulename.js side
                              socketNotificationReceived(notification, payload){
                              if(notification =='have data'){
                              var now = moment()
                              var active_birthdays={}
                              for( var birthday of payload) {
                              // get 1st 5 chars of birthdate, thru month
                              // we will use this as the key in the hash
                              var birth_date=birthday.birth.subString(0,4)
                              // get the birthday as a moment in this year, for comparing
                              var birth_date_moment = moment(birth_date+now.getYear(),"DD.MMYYYY")
                              // u can add days to a moment object and then compare if the birthdate is before that date (and after now)
                              // so within the next xx days
                                // if the date is the same or later, don't use time of day
                                 if(birth_date.startOf('day').isSame(now.startOf('day')){
                                     // birthday is in this month
                                    // check the hash if we've seen anything for today yet
                                    // if we haven't see this date yet
                                    if(active_birthdays[birth_date] == undefined){
                                         //  create the holder for its info (array of names) in the hash
                                         active_birthdays[birth_date]=[]
                                    // save the persons name on the list
                                    active_birthdays[birth_date].push(birthday.name)
                                   // tell MM to call and get our content
                                   self. updateDom()
                              at the end, you will have just birthdays in this month and for people with the same day
                              a list of people on that day
                              in the hash reader (getDom(), Object.keys(active_birthdays) will get you back an array of the
                              DD.MM strings that are present
                              but you can probably do without that… u know what today is, so if there is an object with todays DD.MM
                              then u have the list of people for today
                              if u want to allow (in the next 5 days,matching what the node_helper did), using moment, u can add a day, extract the DD.MM, check the hash,
                              repeat 4 more times
                              • PerlchampP
                                Perlchamp
                                ok, thank you sam.
                                Now I have to process the whole thing first, otherwise my head will burst ;-) …
                                • PerlchampP
                                  Perlchamp
                                  this is the actual node_helper.js:
                                  	init(){
                                  	start() {
                                  		//console.log("Pfad zur csv-Datei: ", this.path + "/data/birthdays.csv");
                                  		// convert the csv-file into a JSON-String
                                  		csv()
                                  		.then((jsonObj)=>{
                                  			// for debugging only
                                  			//console.log("birthdaysArray: ", birthdaysArray);
                                  			// send data to [modulname].js
                                  			self.sendsocketNotification("have data", birthdaysArray)
                                  			// loop thru the array of birthday_info from file (jsonObj),
                                  			// one 'row' per birthday
                                  	stop(){
                                  			this.config=payload
                                  i got an error-message :
                                  [2020-05-01 23:21:12.072] [WARN]   Unhandled rejection ReferenceError: self is not defined
                                      at /home/dirk/MagicMirror/modules/perlchamp/node_helper.js:34:4
                                  i think this could be the problem:
                                  i tried “this.” and without “self.” and “this.” but nothing changed. now i’m searching in the web, maybe i will found some answers ;-)
                                  • PerlchampP
                                    Perlchamp
                                    i have found a typing error. Socket instead socket. if i than change self. to this. no errror messages will displayed. but still black screen.
                                    maybe i did not understand how to handle the getDom-section … i will still try …
                                    but:
                                    i see no notification in the terminal. ‘have data’ should actually appear there, shouldn’t it ?
                                      sdetweil @Perlchamp
                                      @Perlchamp
                                      do this, you need self
                                      start() {
                                      		var self = this
                                      the use self
                                                      self.sendsocketNotification("have data", jsonObj)
                                      u need to send the obj, not the string
                                      as for black screen , that means the modulename side died…
                                      f12 on the keyboard or ctrl-shift-i, select the console tab, and look for red text … usually a syntax error…
                                        @Perlchamp
                                        no, the message is sent to the modulename.js side of your module…
                                        using my sample code , right here
                                                // messages received from from your node helper (NOT other modules or the system)
                                        	// payload is a notification dependent data structure, up to you to design between module and node_helper
                                          the two parts look like this
                                          |                                  browser  side                                                 |
                                          |                                       modulename.js (SampleModule.js)                          |
                                          |     receive (socketNotificationReceived)                send ( sendSocketNotification)         |
                                                              |                                                     V
                                          |      send ( sendSocketNotification)                   receive (socketNotificationReceived)     |
                                          |                                       node_helper.js                                           |
                                          |                                  server side                                                   |
                                          • PerlchampP
                                            Perlchamp
                                            yes, i understood. here’s my perlchamp.js (only socketNitificationReceived)
                                            		Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                                            		if(notification === "message_from_helper"){
                                            			this.config.message = payload;
                                            			// tell mirror runtime that our data has changed,
                                            			// we will be called back at GetDom() to provide the updated content
                                            			this.updateDom(1000)
                                            		if(notification === "have data"){
                                            			var now = moment()
                                            				var birth_date = birthday.birth.subString(0,4)
                                            				Log.log("Tag.Monat :", birth_date)
                                            				var birth_date_moment = moment(birth_date + now.getYear(),"DD.MMYYYY")
                                            				//     if the birthdate is before that date (and after now)
                                            						//		names) in the hash
                                            						active_birthdays[birth_date] = []
                                            			self.updateDom();
                                            • 15
                                            • 16
                                            • 5 / 16
