    read csv-data and put it in an array
    313 Posts 3 Posters 579.1k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp the [ (open square bracket) means array in javascript
      the array can be numbers, strings or objects (open squiggly bracket)
      • PerlchampP
        Perlchamp
        status:
        i wanted to “play” with the jsonArray, but things like jsonArray[“birth”][0] or jsonArray.birth[3] will not be accepted, although it is listed in many websites … i try and try and read and read, but in the moment no solution. the parameter “length” count the number of letters and numbers ?
        then I will have to deal with moment () first …
          sdetweil @Perlchamp
          @Perlchamp u did not show the code, so I will call the output of the csvtojson() birthday_info
          example of how to navigate the json data
          in module there would be no ‘var’ cause of the way the modulename and helper are packaged inside object
          // if not using numbers but month names
          // make indexOf return 1-12, not 0-11 (dummy thing never matched 1st)
          // fix this with your language abbreviations
          // usually in lower case, then always convert data to lowercase for compare to prevent having users remember to get the case right
          var months= ["0", "jan","feb","mar"...."dec"]
          var today_day_month = moment().format("DDMM")
          // today would be "3004"
          // tomorrow will be "0105"
          // loop thru the array of birthday info from file, one 'row' per birthday
          for(var birthday of birthday_info) {
               // get the day/month string in numbers to match output of moment()
               // get the last 2 chars of the day and month with a 0 on front.. 01-09, 12, ---31, or 01-09,10/11/12
               if( ("0"+birthday.Geburtstag).subString(-2)+("0"+months.indexOf(birthday.Geburtsmonat.toLowerCase())).subString(-2)
                                   == today_month_day) {
                   // this birthday is for today
                      condole.log(" birthday on "+ today_day _month+" is for "+birthday.Name);
          • PerlchampP
            Perlchamp
            i didn’t post the code, because it only was a status-info …
            but here is the code. i think i will first try alone. if there any questions i will post them.
            here is my array:
            [{"birth":"12.09.1967", "name":"Otto Billing"},{...}]
            many thanks in advance
              sdetweil @Perlchamp
              @Perlchamp ok, went to numbers, SO much easier!!
              var today_day_month = moment().format("DD.MM")
              // today would be "30.04"
              // tomorrow will be "01.05"
                   if( (birthday.birth.startsWith(today_day_month)) {
                          console.log(" birthday on "+ today_day_month+" is for "+birthday.name);
              • PerlchampP
                Perlchamp
                @sdetweil said in read csv-data and put it in an array:
                ok, i will try. therefor my array don’t match, i think … that’s right ?
                  sdetweil @Perlchamp
                  @Perlchamp the new data matches my new code
                  • PerlchampP
                    Perlchamp
                    thanks, but now i’m a little bit confused, because my master problem will be, to reorg the array, to combine people with the same date of birth in as list in one row with the day of birth. but let me try …
                      sdetweil @Perlchamp
                      @Perlchamp ok, this was just to give you ideas on how to access the data… in a useful way
                      • PerlchampP
                        Perlchamp
                        … and I’m very grateful to you for that. I learn from your messages every time. I think it’s great that there are people like you. that also costs time (apart from health, the most important thing in life). Thanks again for that!
                        • PerlchampP
                          Perlchamp
                          hi sam,
                          i have a major problem, that i don’t understand. this is my code in node_helper.js:
                          var NodeHelper = require("node_helper");
                          var moment = require("moment");
                          // add require of other javascripot components here
                          // var xxx = require('yyy'); here
                          const csv = require("csvtojson");
                          var birthdaysArray = [];
                          	init(){
                          		console.log("init module helper perlchamp");
                          	start() {
                          		console.log("Starting module helper: " + this.name);
                          		//	console.log("Pfad zur csv-Datei: " + this.path + "/data/birthdays.csv");
                          		const csvFilePath = this.path + '/data/birthdays.csv';
                          		csv()
                          		.fromFile(csvFilePath)
                          		.then((jsonObj)=>{
                          			birthdaysArray = JSON.stringify(jsonObj);
                          			console.log("birthdaysArray: " + birthdaysArray);
                          			var today_day_month = moment().format("DD.MM");
                          			var today_month = moment().format("MM");
                          		console.log("birthdaysArray #2: " + birthdaysArray);
                          		// moment.js
                          		moment.locale(config.language);  // set locale
                          		console.log("aktuelle Zeit: " + moment().format('Do MMMM YYYY, hh:mm:ss'));
                          		console.log("aktueller Monat(Zahl): " + moment().format('MM'));
                          		console.log("aktueller Monat(Text): " + moment().format('MMM'));
                          		console.log("aktueller Tag(Zahl mit führender Null): " + moment().format('DD'));
                          		console.log("aktueller Tag(Text): " + moment().format('dddd'));
                          		console.log("aktueller Tag(Abkürzung): " + moment().format('dd'));
                          		console.log("aktuelles Jahr(Zahl): " + moment().format('YYYY'));
                          	stop(){
                          		console.log("Stopping module helper: " + this.name);
                          	// handle messages from our module// each notification indicates a different messages
                          	// payload is a data structure that is different per message.. up to you to design this
                          	socketNotificationReceived(notification, payload) {
                          		//	console.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                          		console.log(this.name + " received a socket notification: " + birthdays);
                          		// if config message from module
                          		if (notification === "CONFIG") {
                          			// save payload config info
                          			this.config=payload
                          			// wait 15 seconds, send a message back to module
                          			setTimeout(()=> { this.sendSocketNotification("message_from_helper"," this is a test_message")}, 15000)
                          		else if(notification === "????2") {
                          why returns
                          nothing.
                          • PerlchampP
                            Perlchamp
                            should be
                            console.log(this.name + " received a socket notification: " + birthdaysArray);
                            of course. couldn’t edit it, because of spam-message from board …
                              sdetweil @Perlchamp
                              @Perlchamp said in read csv-data and put it in an array:
                              > 		csv()
                              > 		.then((jsonObj)=>{
                              welcome to programming with a asyncronous libraries
                              csv().fromFile(csvFilePath) starts a ‘long’ operation,
                              going out to disk, reading in the data, and converting it to json from spreadsheet… (long is milliseconds)
                              the processor should not wait, so it does not, and the next instruction AFTER the start of the fromFile()
                              is console.log("birthdaysArray #2: " + birthdaysArray);
                              	// moment.js
                              and the start function runs out of things to do and returns back to MM…
                              sometime later , the fromFile() will complete, and call the .then() routine with the data
                              (jsonObj)=>{
                              so, if you need to wait for the data(to prints is content) , then the operations would be inside the .then() handler.
                              • PerlchampP
                                Perlchamp
                                ok, thanks. to move the code is not heavy ;-) … i’ve found a snippte to sort my birthdaysArray, but that doesn’t match :
                                		csv()
                                		.then((jsonObj)=>{
                                		var result = Object.entries(birthdaysArray.reduce((a, {birth, name}) => {
                                			const day = +birth.split('.')[0];
                                			a[day] = [...(a[day] || []), name];
                                			return a
                                		}, {})).map(([day, name]) => ({day, name})).sort((a, b) => +a.day - b.day)
                                		console.log("sorted birthdays : " + result);
                                now i’m looking for another one. is the birthdaysArray a json-Array or a javascript-array or … someone told me, it’s an object-Array and that this has nothing to do witch json … but: csvtojson, so …
                                • PerlchampP
                                  Perlchamp
                                  so i’m bloody happy :
                                  	init(){
                                  	start() {
                                  		console.log("Pfad zur csv-Datei: ", this.path + "/data/birthdays.csv");
                                  		csv()
                                  		.then((jsonObj)=>{
                                  			console.log("birthdaysArray: ", birthdaysArray);
                                  		var result = Object.entries(jsonObj.reduce((a, {birth, name}) => {
                                  			return a
                                  		console.log("sorted birthdays : ", result);
                                  	stop(){
                                  			this.config=payload
                                  so now I just have to manage to filter out the people from the complete csv-file who have their birthday in the current month …
                                  • PerlchampP
                                    Perlchamp
                                    if i run :
                                    		for(var birthday of birthdaysArray) {
                                    			if(birthday.birth.startsWith(today_day_month)) {
                                    than i get the following error-messages:
                                     Unhandled rejection TypeError: Cannot read property 'startsWith' of undefined
                                        at /home/dirk/MagicMirror/modules/perlchamp/node_helper.js:33:22
                                        at Object.onfulfilled (/home/dirk/MagicMirror/node_modules/csvtojson/v2/Converter.js:112:33)
                                        at Result.endProcess (/home/dirk/MagicMirror/node_modules/csvtojson/v2/Result.js:83:50)
                                        at Converter.processEnd (/home/dirk/MagicMirror/node_modules/csvtojson/v2/Converter.js:179:21)
                                        at /home/dirk/MagicMirror/node_modules/csvtojson/v2/Converter.js:172:19
                                        at tryCatcher (/home/dirk/MagicMirror/node_modules/bluebird/js/release/util.js:16:23)
                                        at Promise._settlePromiseFromHandler (/home/dirk/MagicMirror/node_modules/bluebird/js/release/promise.js:547:31)
                                        at Promise._settlePromise (/home/dirk/MagicMirror/node_modules/bluebird/js/release/promise.js:604:18)
                                        at Promise._settlePromise0 (/home/dirk/MagicMirror/node_modules/bluebird/js/release/promise.js:649:10)
                                        at Promise._settlePromises (/home/dirk/MagicMirror/node_modules/bluebird/js/release/promise.js:729:18)
                                        at _drainQueueStep (/home/dirk/MagicMirror/node_modules/bluebird/js/release/async.js:93:12)
                                        at _drainQueue (/home/dirk/MagicMirror/node_modules/bluebird/js/release/async.js:86:9)
                                        at Async._drainQueues (/home/dirk/MagicMirror/node_modules/bluebird/js/release/async.js:102:5)
                                        at Immediate.Async.drainQueues [as _onImmediate] (/home/dirk/MagicMirror/node_modules/bluebird/js/release/async.js:15:14)
                                        at processImmediate (internal/timers.js:439:21)
                                    I was probably happy too early ;-( … shit happens.
                                      sdetweil @Perlchamp
                                      @Perlchamp you converted the array to text format, so now its just one big string…
                                      to print it out do this
                                                              birthdaysArray = jsonObj;
                                      			console.log("birthdaysArray: "+JSON.stringify(jsonObj););
                                      why do you need to sort them?
                                      as you go thru you can just not save the ones not for today, plus/minus some lookahead
                                      once you get to the today list you can sort the names if you need to.
                                        sdetweil @Perlchamp
                                        json is a TEXT structure…
                                        but it just so happens that javascript represents objects the same way… so the JSON library provides utilities to convert in both directions.
                                        json text to object JSON.parse(text)
                                        object to json text JSON.stringify(object)
                                        text is text and has no meaning (its called opaque because u cannot tell what it is)
                                        no reason to split the birthdate, as u won’t do anything with the individual parts
                                        don’t do work if u don’t need the results
                                        you do NOT Need to do this data reformatting IN the node helper… you can do it all in the modulename.js file, which would let you use the code debugger in the dev console.
                                        in the .then of the node_helper csvtojson, just send the data to the module
                                        self.sendsocketNotification(“have data”, jsonObj)
                                        and the helper is done
                                        on the modulename.js side
                                        socketNotificationReceived(notification, payload){
                                        if(notification =='have data'){
                                        var now = moment()
                                        var active_birthdays={}
                                        for( var birthday of payload) {
                                        // get 1st 5 chars of birthdate, thru month
                                        // we will use this as the key in the hash
                                        var birth_date=birthday.birth.subString(0,4)
                                        // get the birthday as a moment in this year, for comparing
                                        var birth_date_moment = moment(birth_date+now.getYear(),"DD.MMYYYY")
                                        // u can add days to a moment object and then compare if the birthdate is before that date (and after now)
                                        // so within the next xx days
                                          // if the date is the same or later, don't use time of day
                                           if(birth_date.startOf('day').isSame(now.startOf('day')){
                                               // birthday is in this month
                                              // check the hash if we've seen anything for today yet
                                              // if we haven't see this date yet
                                              if(active_birthdays[birth_date] == undefined){
                                                   //  create the holder for its info (array of names) in the hash
                                                   active_birthdays[birth_date]=[]
                                              // save the persons name on the list
                                              active_birthdays[birth_date].push(birthday.name)
                                             // tell MM to call and get our content
                                             self. updateDom()
                                        at the end, you will have just birthdays in this month and for people with the same day
                                        a list of people on that day
                                        in the hash reader (getDom(), Object.keys(active_birthdays) will get you back an array of the
                                        DD.MM strings that are present
                                        but you can probably do without that… u know what today is, so if there is an object with todays DD.MM
                                        then u have the list of people for today
                                        if u want to allow (in the next 5 days,matching what the node_helper did), using moment, u can add a day, extract the DD.MM, check the hash,
                                        repeat 4 more times
                                        • PerlchampP
                                          Perlchamp
                                          ok, thank you sam.
                                          Now I have to process the whole thing first, otherwise my head will burst ;-) …
                                          • PerlchampP
                                            Perlchamp
                                            this is the actual node_helper.js:
                                            	init(){
                                            	start() {
                                            		//console.log("Pfad zur csv-Datei: ", this.path + "/data/birthdays.csv");
                                            		// convert the csv-file into a JSON-String
                                            		csv()
                                            		.then((jsonObj)=>{
                                            			// for debugging only
                                            			//console.log("birthdaysArray: ", birthdaysArray);
                                            			// send data to [modulname].js
                                            			self.sendsocketNotification("have data", birthdaysArray)
                                            			// loop thru the array of birthday_info from file (jsonObj),
                                            			// one 'row' per birthday
                                            	stop(){
                                            			this.config=payload
                                            i got an error-message :
                                            [2020-05-01 23:21:12.072] [WARN]   Unhandled rejection ReferenceError: self is not defined
                                                at /home/dirk/MagicMirror/modules/perlchamp/node_helper.js:34:4
                                            i think this could be the problem:
                                            i tried “this.” and without “self.” and “this.” but nothing changed. now i’m searching in the web, maybe i will found some answers ;-)
                                            • 15
                                            • 16
                                            • 5 / 16
