    read csv-data and put it in an array
    313 Posts 3 Posters 590.9k Views 4 Watching
    • PerlchampP
      Perlchamp
      console.log(this.name + " received a socket notification: " + birthdays);
      should be
      console.log(this.name + " received a socket notification: " + birthdaysArray);
      of course. couldn’t edit it, because of spam-message from board …
        sdetweil @Perlchamp
        @Perlchamp said in read csv-data and put it in an array:
        > 	const csvFilePath = this.path + '/data/birthdays.csv';
        > 		csv()
        > 		.fromFile(csvFilePath)
        > 		.then((jsonObj)=>{
        > 			birthdaysArray = JSON.stringify(jsonObj);
        > 			console.log("birthdaysArray: " + birthdaysArray);
        > 			var today_day_month = moment().format("DD.MM");
        > 			var today_month = moment().format("MM");
        > 		console.log("birthdaysArray #2: " + birthdaysArray);
        welcome to programming with a asyncronous libraries
        csv().fromFile(csvFilePath) starts a ‘long’ operation,
        going out to disk, reading in the data, and converting it to json from spreadsheet… (long is milliseconds)
        the processor should not wait, so it does not, and the next instruction AFTER the start of the fromFile()
        is console.log("birthdaysArray #2: " + birthdaysArray);
        	// moment.js
        	moment.locale(config.language);  // set locale
        	console.log("aktuelle Zeit: " + moment().format('Do MMMM YYYY, hh:mm:ss'));
        	console.log("aktueller Monat(Zahl): " + moment().format('MM'));
        	console.log("aktueller Monat(Text): " + moment().format('MMM'));
        	console.log("aktueller Tag(Zahl mit führender Null): " + moment().format('DD'));
        	console.log("aktueller Tag(Text): " + moment().format('dddd'));
        	console.log("aktueller Tag(Abkürzung): " + moment().format('dd'));
        	console.log("aktuelles Jahr(Zahl): " + moment().format('YYYY'));
        and the start function runs out of things to do and returns back to MM…
        sometime later , the fromFile() will complete, and call the .then() routine with the data
        (jsonObj)=>{
        so, if you need to wait for the data(to prints is content) , then the operations would be inside the .then() handler.
        • PerlchampP
          Perlchamp
          ok, thanks. to move the code is not heavy ;-) … i’ve found a snippte to sort my birthdaysArray, but that doesn’t match :
          		csv()
          		.then((jsonObj)=>{
          		var result = Object.entries(birthdaysArray.reduce((a, {birth, name}) => {
          			const day = +birth.split('.')[0];
          			a[day] = [...(a[day] || []), name];
          			return a
          		}, {})).map(([day, name]) => ({day, name})).sort((a, b) => +a.day - b.day)
          		console.log("sorted birthdays : " + result);
          now i’m looking for another one. is the birthdaysArray a json-Array or a javascript-array or … someone told me, it’s an object-Array and that this has nothing to do witch json … but: csvtojson, so …
          • PerlchampP
            Perlchamp
            so i’m bloody happy :
            var NodeHelper = require("node_helper");
            var moment = require("moment");
            // add require of other javascripot components here
            // var xxx = require('yyy'); here
            const csv = require("csvtojson");
            var birthdaysArray = [];
            	init(){
            		console.log("init module helper perlchamp");
            	start() {
            		console.log("Starting module helper: " + this.name);
            		console.log("Pfad zur csv-Datei: ", this.path + "/data/birthdays.csv");
            		csv()
            		.then((jsonObj)=>{
            			console.log("birthdaysArray: ", birthdaysArray);
            		var result = Object.entries(jsonObj.reduce((a, {birth, name}) => {
            			return a
            		console.log("sorted birthdays : ", result);
            	stop(){
            		console.log("Stopping module helper: " + this.name);
            	// handle messages from our module// each notification indicates a different messages
            	// payload is a data structure that is different per message.. up to you to design this
            	socketNotificationReceived(notification, payload) {
            		//	console.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
            		// if config message from module
            		if (notification === "CONFIG") {
            			// save payload config info
            			this.config=payload
            			// wait 15 seconds, send a message back to module
            			setTimeout(()=> { this.sendSocketNotification("message_from_helper"," this is a test_message")}, 15000)
            		else if(notification === "????2") {
            so now I just have to manage to filter out the people from the complete csv-file who have their birthday in the current month …
            • PerlchampP
              Perlchamp
              if i run :
              		for(var birthday of birthdaysArray) {
              			if(birthday.birth.startsWith(today_day_month)) {
              				// this birthday is for today
              				console.log(" birthday on "+ today_day_month+" is for "+birthday.name);
              than i get the following error-messages:
               Unhandled rejection TypeError: Cannot read property 'startsWith' of undefined
                  at /home/dirk/MagicMirror/modules/perlchamp/node_helper.js:33:22
                  at Object.onfulfilled (/home/dirk/MagicMirror/node_modules/csvtojson/v2/Converter.js:112:33)
                  at Result.endProcess (/home/dirk/MagicMirror/node_modules/csvtojson/v2/Result.js:83:50)
                  at Converter.processEnd (/home/dirk/MagicMirror/node_modules/csvtojson/v2/Converter.js:179:21)
                  at /home/dirk/MagicMirror/node_modules/csvtojson/v2/Converter.js:172:19
                  at tryCatcher (/home/dirk/MagicMirror/node_modules/bluebird/js/release/util.js:16:23)
                  at Promise._settlePromiseFromHandler (/home/dirk/MagicMirror/node_modules/bluebird/js/release/promise.js:547:31)
                  at Promise._settlePromise (/home/dirk/MagicMirror/node_modules/bluebird/js/release/promise.js:604:18)
                  at Promise._settlePromise0 (/home/dirk/MagicMirror/node_modules/bluebird/js/release/promise.js:649:10)
                  at Promise._settlePromises (/home/dirk/MagicMirror/node_modules/bluebird/js/release/promise.js:729:18)
                  at _drainQueueStep (/home/dirk/MagicMirror/node_modules/bluebird/js/release/async.js:93:12)
                  at _drainQueue (/home/dirk/MagicMirror/node_modules/bluebird/js/release/async.js:86:9)
                  at Async._drainQueues (/home/dirk/MagicMirror/node_modules/bluebird/js/release/async.js:102:5)
                  at Immediate.Async.drainQueues [as _onImmediate] (/home/dirk/MagicMirror/node_modules/bluebird/js/release/async.js:15:14)
                  at processImmediate (internal/timers.js:439:21)
              I was probably happy too early ;-( … shit happens.
                sdetweil @Perlchamp
                @Perlchamp you converted the array to text format, so now its just one big string…
                to print it out do this
                                        birthdaysArray = jsonObj;
                			console.log("birthdaysArray: "+JSON.stringify(jsonObj););
                why do you need to sort them?
                as you go thru you can just not save the ones not for today, plus/minus some lookahead
                once you get to the today list you can sort the names if you need to.
                  sdetweil @Perlchamp
                  json is a TEXT structure…
                  but it just so happens that javascript represents objects the same way… so the JSON library provides utilities to convert in both directions.
                  json text to object JSON.parse(text)
                  object to json text JSON.stringify(object)
                  text is text and has no meaning (its called opaque because u cannot tell what it is)
                  no reason to split the birthdate, as u won’t do anything with the individual parts
                  don’t do work if u don’t need the results
                  you do NOT Need to do this data reformatting IN the node helper… you can do it all in the modulename.js file, which would let you use the code debugger in the dev console.
                  in the .then of the node_helper csvtojson, just send the data to the module
                  self.sendsocketNotification(“have data”, jsonObj)
                  and the helper is done
                  on the modulename.js side
                  socketNotificationReceived(notification, payload){
                  if(notification =='have data'){
                  var now = moment()
                  var active_birthdays={}
                  for( var birthday of payload) {
                  // get 1st 5 chars of birthdate, thru month
                  // we will use this as the key in the hash
                  var birth_date=birthday.birth.subString(0,4)
                  // get the birthday as a moment in this year, for comparing
                  var birth_date_moment = moment(birth_date+now.getYear(),"DD.MMYYYY")
                  // u can add days to a moment object and then compare if the birthdate is before that date (and after now)
                  // so within the next xx days
                    // if the date is the same or later, don't use time of day
                     if(birth_date.startOf('day').isSame(now.startOf('day')){
                         // birthday is in this month
                        // check the hash if we've seen anything for today yet
                        // if we haven't see this date yet
                        if(active_birthdays[birth_date] == undefined){
                             //  create the holder for its info (array of names) in the hash
                             active_birthdays[birth_date]=[]
                        // save the persons name on the list
                        active_birthdays[birth_date].push(birthday.name)
                       // tell MM to call and get our content
                       self. updateDom()
                  at the end, you will have just birthdays in this month and for people with the same day
                  a list of people on that day
                  in the hash reader (getDom(), Object.keys(active_birthdays) will get you back an array of the
                  DD.MM strings that are present
                  but you can probably do without that… u know what today is, so if there is an object with todays DD.MM
                  then u have the list of people for today
                  if u want to allow (in the next 5 days,matching what the node_helper did), using moment, u can add a day, extract the DD.MM, check the hash,
                  repeat 4 more times
                  • PerlchampP
                    Perlchamp
                    ok, thank you sam.
                    Now I have to process the whole thing first, otherwise my head will burst ;-) …
                    • PerlchampP
                      Perlchamp
                      this is the actual node_helper.js:
                      	init(){
                      	start() {
                      		//console.log("Pfad zur csv-Datei: ", this.path + "/data/birthdays.csv");
                      		// convert the csv-file into a JSON-String
                      		csv()
                      		.then((jsonObj)=>{
                      			// for debugging only
                      			//console.log("birthdaysArray: ", birthdaysArray);
                      			// send data to [modulname].js
                      			self.sendsocketNotification("have data", birthdaysArray)
                      			// loop thru the array of birthday_info from file (jsonObj),
                      			// one 'row' per birthday
                      	stop(){
                      			this.config=payload
                      i got an error-message :
                      [2020-05-01 23:21:12.072] [WARN]   Unhandled rejection ReferenceError: self is not defined
                          at /home/dirk/MagicMirror/modules/perlchamp/node_helper.js:34:4
                      i think this could be the problem:
                      i tried “this.” and without “self.” and “this.” but nothing changed. now i’m searching in the web, maybe i will found some answers ;-)
                      • PerlchampP
                        Perlchamp
                        i have found a typing error. Socket instead socket. if i than change self. to this. no errror messages will displayed. but still black screen.
                        maybe i did not understand how to handle the getDom-section … i will still try …
                        but:
                        i see no notification in the terminal. ‘have data’ should actually appear there, shouldn’t it ?
                          sdetweil @Perlchamp
                          @Perlchamp
                          do this, you need self
                          start() {
                          		var self = this
                          the use self
                                          self.sendsocketNotification("have data", jsonObj)
                          u need to send the obj, not the string
                          as for black screen , that means the modulename side died…
                          f12 on the keyboard or ctrl-shift-i, select the console tab, and look for red text … usually a syntax error…
                            @Perlchamp
                            no, the message is sent to the modulename.js side of your module…
                            using my sample code , right here
                                    // messages received from from your node helper (NOT other modules or the system)
                            	// payload is a notification dependent data structure, up to you to design between module and node_helper
                              the two parts look like this
                              |                                  browser  side                                                 |
                              |                                       modulename.js (SampleModule.js)                          |
                              |     receive (socketNotificationReceived)                send ( sendSocketNotification)         |
                                                  |                                                     V
                              |      send ( sendSocketNotification)                   receive (socketNotificationReceived)     |
                              |                                       node_helper.js                                           |
                              |                                  server side                                                   |
                              • PerlchampP
                                Perlchamp
                                yes, i understood. here’s my perlchamp.js (only socketNitificationReceived)
                                		Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                                		if(notification === "message_from_helper"){
                                			this.config.message = payload;
                                			// tell mirror runtime that our data has changed,
                                			// we will be called back at GetDom() to provide the updated content
                                			this.updateDom(1000)
                                		if(notification === "have data"){
                                			var now = moment()
                                				var birth_date = birthday.birth.subString(0,4)
                                				Log.log("Tag.Monat :", birth_date)
                                				var birth_date_moment = moment(birth_date + now.getYear(),"DD.MMYYYY")
                                				//     if the birthdate is before that date (and after now)
                                						//		names) in the hash
                                						active_birthdays[birth_date] = []
                                			self.updateDom();
                                  sdetweil @Perlchamp
                                  @Perlchamp very good… now, I didn’t test the code I wrote, so there are a couple errors…
                                  but you should be able to see that code in the developers window, sources tab,
                                  navigate on the left tree, modules, your module_name (which has to be perchamp,
                                  folder, filename and the register at the top) all have to match)
                                  • PerlchampP
                                    Perlchamp
                                    i can’t find … so everything’s right ?
                                      sdetweil @Perlchamp
                                      @Perlchamp you shouldScreenshot at 2020-05-01 18-12-15.png see an error like this
                                      note that I put part of the module name in the filter field
                                      • PerlchampP
                                        Perlchamp
                                        ok, thanks
                                          sdetweil @Perlchamp
                                          @Perlchamp and if something not spelled right (this image also shows the module tree navigation on the left)
                                          when its used !
                                          • PerlchampP
                                            Perlchamp
                                            so, sam, everything is fixed :-)
                                            but now i don’t know how to handle the receiving data. i only need a little entry … don’t know how to handle this object-element. actually nothing is displayed except the header i configured …
                                            • 15
                                            • 16
                                            • 5 / 16
