    read csv-data and put it in an array
    313 Posts 3 Posters 590.4k Views 4 Watching
    • PerlchampP
      Perlchamp
      before you do this. stop. i make an error. the code you posted is not in the notification section. it’s in the getDom section … so i placed it there. was this wrong ?
        sdetweil @Perlchamp
        @Perlchamp there is NOT an this. updateDom() in the getDom() section…
        still doesn’t change the result… there are no birthdays found that match 02/05
        • PerlchampP
          Perlchamp
          the columns are:
          birth, name
          and is called “birthdays.csv”
          the data are:
          23.01.1987,Thomas Roth
            sdetweil @Perlchamp
            @Perlchamp so there are no birthdays for today… we are ONLY selecting for TODAY. not every day
            • PerlchampP
              Perlchamp
              why for TODAY ? and not for current MONTH ?
              getDon:
              	getDom: function() {
              		var self = this;
              		// tell MM to call and get our content
              Log.log("LOOK >>>>>>" + JSON.stringify(this.active_birthdays))    // add this line
              			self.updateDom();                          // before this line in the notification code..
              		for(var birthday of Object.keys(this.active_birthdays)) {
              			for(var name of this.active_birthdays[birthday]) {
              				var m = document.createElement("div");
              				Log.log("BIRTHDAY >> " + birthday);
              				Log.log("NAME >> " + name);
              				m.innerText = birthday + " " + name;
              				wrapper.appendChild(m);
              		// pass the created content back to MM to add to DOM.
              		return wrapper;
                sdetweil @Perlchamp
                @Perlchamp said in read csv-data and put it in an array:
                Log.log(“LOOK >>>>>>” + JSON.stringify(this.active_birthdays)) // add this line
                self.updateDom();
                not that way
                			      // save the persons name and age on the list
                			      self.active_birthdays[birth_date].push({'name':birthday.name, 'age': now.diff(moment(birthday.birth,'DD.MM.YYYY'), 'years') })
                Log.log(JSON.stringify(this.active_birthdays))		  // add this line
                sorry, didn’t see the ‘month’.
                still doesn’t matter, that birthday is for january, so nothing to show for may
                change this compare to do only month
                		  // if the date is the same or later, don't use time of day
                		   if(birth_date_moment.startOf('day').isSameOrAfter(now.startOf('day')) &&
                		   	  birth_date_moment.startOf('day').isSameOrBefore(birthday_time_window.startOf('day'))
                hint, google get month from moment
                • PerlchampP
                  Perlchamp
                  i got this:
                  [2020-05-02 18:10:50.465] [LOG]    {} (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  for each entry. i have 5 birthdays in may …
                    sdetweil @Perlchamp
                    @Perlchamp look in the console log, MMM-Logging is redirecting everything there
                    my mmm-logging config
                                module: 'MMM-Logging',
                                disabled: false,
                                    // Module functions out of the box with nothing set here.
                                    // See below for configurable options.
                                    echoLocal: true,
                                    echoRemote: true,
                                    overwriteBrowserMethods: true,
                                    format: "{{message}} ({{folder}}/{{file}}:{{line}} {{method}})",
                    • PerlchampP
                      Perlchamp
                      i could send you the three files (node_helper.js, MMM-Perlchamp.js, birthdays.csv) via email ?
                        sdetweil @Perlchamp
                        @Perlchamp sent chat message
                        • PerlchampP
                          Perlchamp
                          node_helper.js:
                          var NodeHelper = require("node_helper");
                          var moment = require("moment");
                          // add require of other javascripot components here
                          // var xxx = require('yyy'); here
                          const csv = require("csvtojson");
                          var birthdaysArray = [];
                          	init(){
                          		console.log("init module helper MMM-Perlchamp");
                          	start() {
                          	stop(){
                          		console.log("Stopping module helper: ",this.name);
                          	// handle messages from our module// each notification indicates a different messages
                          	// payload is a data structure that is different per message.. up to you to design this
                          	socketNotificationReceived(notification, payload) {
                          		var self = this;
                          		console.log("Starting module helper: ",this.name);
                          		// convert the csv-file into a JSON-String
                          		const csvFilePath = this.path + '/data/birthdays.csv';
                          		csv()
                          		.fromFile(csvFilePath)
                          		.then(function(jsonObj) {
                          			JSON.stringify(jsonObj);
                          			// send data to [modulname].js
                          			self.sendSocketNotification("HAVEDATA", jsonObj);
                          		// if config message from module
                          		if (notification === "CONFIG") {
                          			// save payload config info
                          			this.config = payload;
                          			// wait 15 seconds, send a message back to module
                          			setTimeout(()=> {this.sendSocketNotification("message_from_helper"," this is a test_message")}, 15000);
                          		else if(notification === "????2") {
                          MMM-Perlchamp.js:
                          Module.register("MMM-Perlchamp", {
                          	defaults: {
                          		language: "de",
                          		dimmEntries: true   // true: dims entries and the associated
                          							//       symbol when the date has expired.
                          							// false: delete entries and the associated
                          	active_birthdays: {
                          	init: function(){
                          		Log.log(this.name + " is in init!");
                          	start: function(){
                          		Log.log("Starting module: " + this.name);
                          		// Set locale
                          		moment.locale(config.language);
                          	loaded: function(callback) {
                          		Log.log(this.name + " is loaded!");
                          		callback();
                          	// return list of other functional scripts to use, if any (like require in node_helper)
                          	getScripts: function() {
                          		return	["moment.js"];
                          	// return list of stylesheet files to use if any
                          	getStyles: function() {
                          		return 	[this.data.path + "/css/MMM-Perlchamp.css"];
                          	// only called if the module header was configured in module config in config.js
                          	getHeader: function() {
                          		return this.data.header;
                          	// messages received from other modules and the system (NOT from your node helper)
                          	// payload is a notification dependent data structure
                          		// once everybody is loaded up
                          		if(notification === "ALL_MODULES_STARTED"){
                          			// send our config to our node_helper
                          			this.sendSocketNotification("CONFIG",this.config);
                          		if (sender) {
                          			Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
                          		} else {
                          			Log.log(this.name + " received a system notification: " + notification);
                          	// messages received from from your node helper (NOT other modules or the system)
                          	// payload is a notification dependent data structure, up to you to design between module and node_helper
                          		if(notification === "HAVEDATA") {
                          			var self = this;
                          			Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                          			var now = moment();
                          			for(var birthday of payload) {
                          				// get 1st 5 chars of birthdate, thru month
                          				// we will use this as the key in the hash
                          				var birth_date = birthday.birth.substring(0,5);
                          				// get the birthday as a moment in this year, for comparing
                          				var birth_date_moment = moment(birth_date + now.year(),"DD.MMYYYY");
                          				// u can add days to a moment object and then compare
                          				//     if the birthdate is before that date (and after now)
                          				//     so within the next xx days
                          		   	  birth_date_moment.startOf('day').isSameOrBefore(birthday_time_window.startOf('day'))) {
                          					// birthday is in this month
                          					// check the hash if we've seen anything for today yet
                          					// if we haven't see this date yet
                          					if(this.active_birthdays[birth_date] == undefined){
                          						//  create the holder for its info (array of
                          						//		names) in the hash
                          						this.active_birthdays[birth_date] = [];
                          					// save the persons name on the list
                          //					this.active_birthdays[birth_date].push(birthday.name);
                          			Log.log("this.active_birthdays >>>>> ", this.active_birthdays);
                          //			var currentMonth = new Date().toLocaleDateString('en', {month:'2-digit'});
                          			var currentMonth = moment().format("MM");
                          			var result = Object.entries(payload
                          			.filter(({birth}) => birth.split('.')[1] === currentMonth)
                          			.reduce((a, {birth, name}) => {
                          				const day = +birth.split('.')[0];
                          				a[day] = [...(a[day] || []), name];
                          				return a
                          			).map(([day, name]) => ({day, name})).sort((a, b) => +a.day - b.day);
                          			console.log("LISTE >> ", result);
                          			self.updateDom();
                          	// system notification your module is being hidden
                          	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
                          	suspend: function() {
                          	// system notification your module is being unhidden/shown
                          	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
                          	resume: function() {
                          	// this is the major worker of the module, it provides the displayable content for this module
                          		var self = this;
                          		return wrapper;
                          birthdays.csv in folder MMM-Perlchamp/data:
                          birth,name
                          03.01.1940,aaa AAAAA
                          06.01.1969,bbb BBBBB
                          15.02.1939,ccc CCCCC
                          07.03.1972,ddd DDDDD
                          10.05.1969,eee EEEEE
                          16.05.2012,fff FFFFF
                          16.05.1988,ggg GGGGG
                          27.05.2002,hhh HHHHH
                          08.07.1976,iiii IIIII
                          13.07.1914,jjj JJJJJ
                          27.08.1968,kkk KKKKK
                          21.09.1967,lll LLLLL
                          13.10.1965,mmm MMMMM
                          16.10.2010,nnn NNNNN
                          23.10.1941,ooo OOOOO
                          19.12.1935,ppp PPPPP
                          MMM-Perlchamp.css in folder MMM-Perlchamp/css
                          .MMM-Perlchamp header {
                            letter-spacing: 0.1em;
                            text-transform: uppercase;
                            font-size: 20px;
                            font-family: "Roboto Condensed", Arial, Helvetica, sans-serif;
                            font-weight: 400;
                            border-bottom: 1px solid #444444;
                            line-height: 20px;
                            padding-bottom: 5px;
                            color: #ffffff;
                            font-variant: small-caps;
                            sdetweil @Perlchamp
                            yes it only shows for today+some possible offset… I said u had to fix that to do month comparison
                            • PerlchampP
                              Perlchamp
                              shame on me, sorry for that. now it’s changed to:
                              if(birth_date_moment.startOf('month').isSameOrAfter(now.startOf('month')) &&
                              					birth_date_moment.startOf('month').isSameOrBefore(birthday_time_window.startOf('month'))) {
                              nothing changed, i have configured the terminal-window to scroll about 3000 (!) lines, but can’t see the beginning …
                                sdetweil @Perlchamp
                                @Perlchamp redirect the terminal window to a file and edit that
                                do this in the code
                                			 	//if(birth_date_moment.startOf('day').isSameOrAfter(now.startOf('day')) &&
        //  birth_date_moment.startOf('day').isSameOrBefore(birthday_time_window.startOf('day'))) {
                                			   	if( birth_date_moment.month() == now.month() ){
                                • PerlchampP
                                  Perlchamp
                                  done, it’s frozen now. must restart …
                                  • PerlchampP
                                    Perlchamp
                                    question:
                                    in the
                                    			var self = this;
                                    payload should be the variable in which the jsonString is saved ?
                                      sdetweil @Perlchamp
                                      @Perlchamp it has the jsonObj from the node_helper
                                      u can call it anything, its just a name
                                      so, if you put a stop right on the var self = this
                                      and then cursor over the work payload in
                                      it will show you that object content, and u can go up and click on parts to make them expand to examine the contents
                                      • PerlchampP
                                        Perlchamp
                                        ok, there is a light at the end of the tunnel:
                                          code was changed to add ages
                                          in getDom()
                                          now is
                                          			for(var person of this.active_birthdays[birthday]){
                                          				var m=document.createElement('div')
                                          // create your table row here
                                          				m.innerText=birthday+ ' '+ person.name+' age='+person.age
                                          • PerlchampP
                                            Perlchamp
                                            great, thanks !
                                            to your information:
                                            there are NO semikolons in your posted code. within them it goes !
                                            • 10
                                            • 11
                                            • 15
                                            • 16
                                            • 9 / 16
