    read csv-data and put it in an array
    313 Posts 3 Posters 590.2k Views 4 Watching
    • PerlchampP
      Perlchamp
      i could send you the three files (node_helper.js, MMM-Perlchamp.js, birthdays.csv) via email ?
        sdetweil @Perlchamp
        @Perlchamp sent chat message
        • PerlchampP
          Perlchamp
          node_helper.js:
          var NodeHelper = require("node_helper");
          var moment = require("moment");
          // add require of other javascripot components here
          // var xxx = require('yyy'); here
          const csv = require("csvtojson");
          var birthdaysArray = [];
          	init(){
          		console.log("init module helper MMM-Perlchamp");
          	start() {
          	stop(){
          		console.log("Stopping module helper: ",this.name);
          	// handle messages from our module// each notification indicates a different messages
          	// payload is a data structure that is different per message.. up to you to design this
          	socketNotificationReceived(notification, payload) {
          		var self = this;
          		console.log("Starting module helper: ",this.name);
          		// convert the csv-file into a JSON-String
          		const csvFilePath = this.path + '/data/birthdays.csv';
          		csv()
          		.fromFile(csvFilePath)
          		.then(function(jsonObj) {
          			JSON.stringify(jsonObj);
          			// send data to [modulname].js
          			self.sendSocketNotification("HAVEDATA", jsonObj);
          		// if config message from module
          		if (notification === "CONFIG") {
          			// save payload config info
          			this.config = payload;
          			// wait 15 seconds, send a message back to module
          			setTimeout(()=> {this.sendSocketNotification("message_from_helper"," this is a test_message")}, 15000);
          		else if(notification === "????2") {
          MMM-Perlchamp.js:
          Module.register("MMM-Perlchamp", {
          	defaults: {
          		language: "de",
          		dimmEntries: true   // true: dims entries and the associated
          							//       symbol when the date has expired.
          							// false: delete entries and the associated
          	active_birthdays: {
          	init: function(){
          		Log.log(this.name + " is in init!");
          	start: function(){
          		Log.log("Starting module: " + this.name);
          		// Set locale
          		moment.locale(config.language);
          	loaded: function(callback) {
          		Log.log(this.name + " is loaded!");
          		callback();
          	// return list of other functional scripts to use, if any (like require in node_helper)
          	getScripts: function() {
          		return	["moment.js"];
          	// return list of stylesheet files to use if any
          	getStyles: function() {
          		return 	[this.data.path + "/css/MMM-Perlchamp.css"];
          	// only called if the module header was configured in module config in config.js
          	getHeader: function() {
          		return this.data.header;
          	// messages received from other modules and the system (NOT from your node helper)
          	// payload is a notification dependent data structure
          		// once everybody is loaded up
          		if(notification === "ALL_MODULES_STARTED"){
          			// send our config to our node_helper
          			this.sendSocketNotification("CONFIG",this.config);
          		if (sender) {
          			Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
          		} else {
          			Log.log(this.name + " received a system notification: " + notification);
          	// messages received from from your node helper (NOT other modules or the system)
          	// payload is a notification dependent data structure, up to you to design between module and node_helper
          		if(notification === "HAVEDATA") {
          			var self = this;
          			Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
          			var now = moment();
          			for(var birthday of payload) {
          				// get 1st 5 chars of birthdate, thru month
          				// we will use this as the key in the hash
          				var birth_date = birthday.birth.substring(0,5);
          				// get the birthday as a moment in this year, for comparing
          				var birth_date_moment = moment(birth_date + now.year(),"DD.MMYYYY");
          				// u can add days to a moment object and then compare
          				//     if the birthdate is before that date (and after now)
          				//     so within the next xx days
          				// if the date is the same or later, don't use time of day
          				if(birth_date_moment.startOf('day').isSameOrAfter(now.startOf('day')) &&
          		   	  birth_date_moment.startOf('day').isSameOrBefore(birthday_time_window.startOf('day'))) {
          					// birthday is in this month
          					// check the hash if we've seen anything for today yet
          					// if we haven't see this date yet
          					if(this.active_birthdays[birth_date] == undefined){
          						//  create the holder for its info (array of
          						//		names) in the hash
          						this.active_birthdays[birth_date] = [];
          					// save the persons name on the list
          					self.active_birthdays[birth_date].push({'name':birthday.name, 'age': now.diff(moment(birthday.birth,'DD.MM.YYYY'), 'years') })
          //					this.active_birthdays[birth_date].push(birthday.name);
          			Log.log("this.active_birthdays >>>>> ", this.active_birthdays);
          //			var currentMonth = new Date().toLocaleDateString('en', {month:'2-digit'});
          			var currentMonth = moment().format("MM");
          			var result = Object.entries(payload
          			.filter(({birth}) => birth.split('.')[1] === currentMonth)
          			.reduce((a, {birth, name}) => {
          				const day = +birth.split('.')[0];
          				a[day] = [...(a[day] || []), name];
          				return a
          			).map(([day, name]) => ({day, name})).sort((a, b) => +a.day - b.day);
          			console.log("LISTE >> ", result);
          			// tell MM to call and get our content
          			self.updateDom();
          	// system notification your module is being hidden
          	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
          	suspend: function() {
          	// system notification your module is being unhidden/shown
          	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
          	resume: function() {
          	// this is the major worker of the module, it provides the displayable content for this module
          	getDom: function() {
          		var self = this;
          Log.log(JSON.stringify(this.active_birthdays))    // add this line
          			self.updateDom();                          // before this line in the notification code..
          		for(var birthday of Object.keys(this.active_birthdays)) {
          			for(var name of this.active_birthdays[birthday]) {
          				var m = document.createElement("div");
          				Log.log("BIRTHDAY >> " + birthday);
          				Log.log("NAME >> " + name);
          				m.innerText = birthday + " " + name;
          				wrapper.appendChild(m);
          		// pass the created content back to MM to add to DOM.
          		return wrapper;
          birthdays.csv in folder MMM-Perlchamp/data:
          birth,name
          03.01.1940,aaa AAAAA
          06.01.1969,bbb BBBBB
          15.02.1939,ccc CCCCC
          07.03.1972,ddd DDDDD
          10.05.1969,eee EEEEE
          16.05.2012,fff FFFFF
          16.05.1988,ggg GGGGG
          27.05.2002,hhh HHHHH
          08.07.1976,iiii IIIII
          13.07.1914,jjj JJJJJ
          27.08.1968,kkk KKKKK
          21.09.1967,lll LLLLL
          13.10.1965,mmm MMMMM
          16.10.2010,nnn NNNNN
          23.10.1941,ooo OOOOO
          19.12.1935,ppp PPPPP
          MMM-Perlchamp.css in folder MMM-Perlchamp/css
          .MMM-Perlchamp header {
            letter-spacing: 0.1em;
            text-transform: uppercase;
            font-size: 20px;
            font-family: "Roboto Condensed", Arial, Helvetica, sans-serif;
            font-weight: 400;
            border-bottom: 1px solid #444444;
            line-height: 20px;
            padding-bottom: 5px;
            color: #ffffff;
            font-variant: small-caps;
            sdetweil @Perlchamp
            @Perlchamp said in read csv-data and put it in an array:
            yes it only shows for today+some possible offset… I said u had to fix that to do month comparison
            • PerlchampP
              Perlchamp
              shame on me, sorry for that. now it’s changed to:
              if(birth_date_moment.startOf('month').isSameOrAfter(now.startOf('month')) &&
              					birth_date_moment.startOf('month').isSameOrBefore(birthday_time_window.startOf('month'))) {
              nothing changed, i have configured the terminal-window to scroll about 3000 (!) lines, but can’t see the beginning …
                sdetweil @Perlchamp
                @Perlchamp redirect the terminal window to a file and edit that
                do this in the code
                			 	//if(birth_date_moment.startOf('day').isSameOrAfter(now.startOf('day')) &&
                                                //  birth_date_moment.startOf('day').isSameOrBefore(birthday_time_window.startOf('day'))) {
                			   	if( birth_date_moment.month() == now.month() ){
                • PerlchampP
                  Perlchamp
                  done, it’s frozen now. must restart …
                  • PerlchampP
                    Perlchamp
                    question:
                    in the
                    			var self = this;
                    payload should be the variable in which the jsonString is saved ?
                      sdetweil @Perlchamp
                      @Perlchamp it has the jsonObj from the node_helper
                      u can call it anything, its just a name
                      so, if you put a stop right on the var self = this
                      and then cursor over the work payload in
                      it will show you that object content, and u can go up and click on parts to make them expand to examine the contents
                      • PerlchampP
                        Perlchamp
                        ok, there is a light at the end of the tunnel:
                          code was changed to add ages
                          in getDom()
                          now is
                          			for(var person of this.active_birthdays[birthday]){
                          				var m=document.createElement('div')
                          // create your table row here
                          				m.innerText=birthday+ ' '+ person.name+' age='+person.age
                          • PerlchampP
                            Perlchamp
                            great, thanks !
                            to your information:
                            there are NO semikolons in your posted code. within them it goes !
                              sdetweil @Perlchamp
                              @Perlchamp end of line ; are not required… I cut/pasted that code out of the running module
                              • PerlchampP
                                Perlchamp
                                without i have a black screen, with everythings fine.
                                another information:
                                age must be +1 but i think i will solve this alone. if not i’m too stuipid for this all :-)
                                so i can create my table now. but i see:
                                people who has birthday the same day:
                                date should be displayed once, and the names in the same , separated by
                                  sdetweil @Perlchamp
                                  @Perlchamp ok, I think you can fix those… age is a date diff()… add to results
                                  edit: age needs more work that just number… because they were comparing MONTH, but age was exact days.
                                  so I change my bd to may, but TODAY I am 68… in may i WILL BE 69 (in the future)
                                  so if TODAY or before, do NOT add one, if tomorrow or after (in the month) add 1
                                  • PerlchampP
                                    Perlchamp
                                    i think, too. thanks very much, sam. I don’t know how to thank you Thank you very much !
                                    you’re great !
                                    and it is up to you whether you publish this module. I will not adorn myself with foreign feathers!
                                    S 2 Replies Last reply
                                      sdetweil @Perlchamp
                                      @Perlchamp its not my module… its yours…
                                        sdetweil @Perlchamp
                                        @Perlchamp see how interesting ‘just a birthday list’ can be! and u still have styles to apply etc
                                        • PerlchampP
                                          Perlchamp
                                          I do not think so. I could never answer questions about any problems …
                                          i did:
                                          ... age='+(person.age + 1);
                                          the styles you could get from me, no problem. it’s just fair, isn’t it ?
                                            sdetweil @Perlchamp
                                            @Perlchamp should be wrong for people with birthday yesterday
                                            • 10
                                            • 11
                                            • 15
                                            • 16
                                            • 9 / 16
