    read csv-data and put it in an array
    313 Posts 3 Posters 590.4k Views 4 Watching
    • PerlchampP
      Perlchamp
      shame on me, sorry for that. now it’s changed to:
      if(birth_date_moment.startOf('month').isSameOrAfter(now.startOf('month')) &&
      					birth_date_moment.startOf('month').isSameOrBefore(birthday_time_window.startOf('month'))) {
      nothing changed, i have configured the terminal-window to scroll about 3000 (!) lines, but can’t see the beginning …
        sdetweil @Perlchamp
        @Perlchamp redirect the terminal window to a file and edit that
        do this in the code
        				// if the date is the same or later, don't use time of day
        			 	//if(birth_date_moment.startOf('day').isSameOrAfter(now.startOf('day')) &&
                                        //  birth_date_moment.startOf('day').isSameOrBefore(birthday_time_window.startOf('day'))) {
        			   	if( birth_date_moment.month() == now.month() ){
        • PerlchampP
          Perlchamp
          done, it’s frozen now. must restart …
          • PerlchampP
            Perlchamp
            question:
            in the
            		if(notification === "HAVEDATA") {
            			var self = this;
            payload should be the variable in which the jsonString is saved ?
              sdetweil @Perlchamp
              @Perlchamp it has the jsonObj from the node_helper
              u can call it anything, its just a name
              so, if you put a stop right on the var self = this
              and then cursor over the work payload in
              it will show you that object content, and u can go up and click on parts to make them expand to examine the contents
              • PerlchampP
                Perlchamp
                ok, there is a light at the end of the tunnel:
                  code was changed to add ages
                  in getDom()
                  			for(var name of this.active_birthdays[birthday]) {
                  				var m = document.createElement("div");
                  				Log.log("BIRTHDAY >> " + birthday);
                  				Log.log("NAME >> " + name);
                  				m.innerText = birthday + " " + name;
                  				wrapper.appendChild(m);
                  now is
                  			for(var person of this.active_birthdays[birthday]){
                  				var m=document.createElement('div')
                  // create your table row here
                  				m.innerText=birthday+ ' '+ person.name+' age='+person.age
                  • PerlchampP
                    Perlchamp
                    great, thanks !
                    to your information:
                    there are NO semikolons in your posted code. within them it goes !
                      sdetweil @Perlchamp
                      @Perlchamp end of line ; are not required… I cut/pasted that code out of the running module
                      • PerlchampP
                        Perlchamp
                        without i have a black screen, with everythings fine.
                        another information:
                        age must be +1 but i think i will solve this alone. if not i’m too stuipid for this all :-)
                        so i can create my table now. but i see:
                        people who has birthday the same day:
                        date should be displayed once, and the names in the same , separated by
                          sdetweil @Perlchamp
                          @Perlchamp ok, I think you can fix those… age is a date diff()… add to results
                          edit: age needs more work that just number… because they were comparing MONTH, but age was exact days.
                          so I change my bd to may, but TODAY I am 68… in may i WILL BE 69 (in the future)
                          so if TODAY or before, do NOT add one, if tomorrow or after (in the month) add 1
                          • PerlchampP
                            Perlchamp
                            i think, too. thanks very much, sam. I don’t know how to thank you Thank you very much !
                            you’re great !
                            and it is up to you whether you publish this module. I will not adorn myself with foreign feathers!
                            S 2 Replies Last reply
                              sdetweil @Perlchamp
                              @Perlchamp its not my module… its yours…
                                sdetweil @Perlchamp
                                @Perlchamp see how interesting ‘just a birthday list’ can be! and u still have styles to apply etc
                                • PerlchampP
                                  Perlchamp
                                  I do not think so. I could never answer questions about any problems …
                                  i did:
                                  ... age='+(person.age + 1);
                                  the styles you could get from me, no problem. it’s just fair, isn’t it ?
                                    sdetweil @Perlchamp
                                    @Perlchamp should be wrong for people with birthday yesterday
                                    • PerlchampP
                                      Perlchamp
                                      ah, oooook … hm. shooted to fast. but let me figured out by myself, cause i don’t wonna feel like a baby … i think if-statements and moment() could be helpfully.
                                      • PerlchampP
                                        Perlchamp
                                        general question:
                                        is there something like “print”? (for debugging) or have i use innerText or innerHTML or Log.log ? … to display something on screen ?
                                          sdetweil @Perlchamp
                                          @Perlchamp Log.log only
                                          did u see my chat message about fixing a bug in the MMM-Logging module
                                          • PerlchampP
                                            Perlchamp
                                            i will have a look on it, though MERCI !
                                            • 10
                                            • 11
                                            • 15
                                            • 16
                                            • 9 / 16
