    read csv-data and put it in an array
    313 Posts 3 Posters 552.7k Views 4 Watching
      code was changed to add ages
      in getDom()
      			for(var name of this.active_birthdays[birthday]) {
      				var m = document.createElement("div");
      				Log.log("BIRTHDAY >> " + birthday);
      				Log.log("NAME >> " + name);
      				m.innerText = birthday + " " + name;
      				wrapper.appendChild(m);
      now is
      			for(var person of this.active_birthdays[birthday]){
      				var m=document.createElement('div')
      // create your table row here
      				m.innerText=birthday+ ' '+ person.name+' age='+person.age
      • PerlchampP Offline
        Perlchamp
        great, thanks !
        to your information:
        there are NO semikolons in your posted code. within them it goes !
          sdetweil @Perlchamp
          @Perlchamp end of line ; are not required… I cut/pasted that code out of the running module
            Perlchamp
            without i have a black screen, with everythings fine.
            another information:
            age must be +1 but i think i will solve this alone. if not i’m too stuipid for this all :-)
            so i can create my table now. but i see:
            people who has birthday the same day:
            date should be displayed once, and the names in the same , separated by
              sdetweil @Perlchamp
              @Perlchamp ok, I think you can fix those… age is a date diff()… add to results
              edit: age needs more work that just number… because they were comparing MONTH, but age was exact days.
              so I change my bd to may, but TODAY I am 68… in may i WILL BE 69 (in the future)
              so if TODAY or before, do NOT add one, if tomorrow or after (in the month) add 1
                Perlchamp
                i think, too. thanks very much, sam. I don’t know how to thank you Thank you very much !
                you’re great !
                and it is up to you whether you publish this module. I will not adorn myself with foreign feathers!
                  sdetweil @Perlchamp
                  @Perlchamp its not my module… its yours…
                    sdetweil @Perlchamp
                    @Perlchamp see how interesting ‘just a birthday list’ can be! and u still have styles to apply etc
                      Perlchamp
                      I do not think so. I could never answer questions about any problems …
                      i did:
                      ... age='+(person.age + 1);
                      the styles you could get from me, no problem. it’s just fair, isn’t it ?
                        sdetweil @Perlchamp
                        @Perlchamp should be wrong for people with birthday yesterday
                          Perlchamp
                          ah, oooook … hm. shooted to fast. but let me figured out by myself, cause i don’t wonna feel like a baby … i think if-statements and moment() could be helpfully.
                            Perlchamp
                            general question:
                            is there something like “print”? (for debugging) or have i use innerText or innerHTML or Log.log ? … to display something on screen ?
                              sdetweil @Perlchamp
                              @Perlchamp Log.log only
                              did u see my chat message about fixing a bug in the MMM-Logging module
                                Perlchamp
                                i will have a look on it, though MERCI !
                                  sdetweil @Perlchamp
                                  @Perlchamp one other thing, u need to start a timer for when the month changes, when the timer expires, send a CONFIG message to the node_helper and it will send the latest birthdays list and everything will recalculate
                                    Perlchamp
                                    hi sam, yes i thought about. in the moment this is the actually file, though there is code annotate and at the wrong place, … just so you don’t wonder … :
                                    /* global Module */
                                    /* Magic Mirror
                                     * Module: birthdaylist
                                     * Author: perlchamp@gmx.net
                                     * Lizenz: MIT
                                    Module.register("birthdaylist", {
                                        // Default module config.
                                        defaults: {
                                    	debugging: false,
                                    	initialLoadDelay: 0,		// How many seconds to wait on a fresh start up.
                                    					// This is to prevent collision with all other modules also
                                    					// loading all at the same time. This only happens once,
                                    					// when the mirror first starts up.
                                    	dimmEntries: true,   		// true: dims entries and the associated
                                    					//       symbol when the date has expired.
                                    					// false: delete entries and the associated
                                    	language: "de",			// needed for dateformatting
                                    	updateDelay: 5		        // How many seconds after midnight before a refresh
                                    				        // This is to prevent collision with other modules refreshing
                                    				        // at the same time.
                                        active_birthdays: {
                                        init: function() {
                                    	Log.log(this.name + " is in init!");
                                        // Override start method
                                        start: function() {
                                    	Log.log("Starting module: " + this.name);
                                    	// set locale here, default: de
                                    	moment.locale(config.language);
                                    	// Calculate next midnight and add updateDelay
                                    	var now = moment();
                                    	this.midnight = moment([now.year(), now.month(), now.date() + 1]).add(this.config.updateDelay, "seconds");
                                    	this.loaded = false;
                                    	this.scheduleUpdate(this.config.initialLoadDelay * 1000);
                                        loaded: function(callback) {
                                    	Log.log(this.name + " is loaded!");
                                    	callback();
                                        // return list of other functional scripts to use, if any (like require in node_helper)
                                        getScripts: function () {
                                    	return ["moment.js"];
                                        // return list of stylesheet files to use if any
                                        getStyles: function() {
                                    	return [this.data.path + "/css/bdl.css"];
                                        // you can configure the heading of the list in config.js
                                        getHeader: function() {
                                    	return this.data.header;
                                        // messages received from other modules and the system (NOT from your node helper)
                                        // payload is a notification dependent data structure
                                    	// once everybody is loaded up
                                    	if(notification === "ALL_MODULES_STARTED") {
                                    	    // send our config to our node_helper
                                    	    this.sendSocketNotification("CONFIG",this.config);
                                    	if (sender) {
                                    	    Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
                                    	else {
                                    	    Log.log(this.name + " received a system notification: " + notification);
                                        // messages received from from your node helper (NOT other modules or the system)
                                        // payload is a notification dependent data structure, up to you to design between module and node_helper
                                    	if(notification === "JSONDATA") {
                                    	    var self = this;
                                    	    Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                                    	    var now = moment();
                                    	    var day_month = moment().format("DD");
                                    	    for(var birthday of payload) {
                                    		// get 1st 5 chars of birthdate, thru month
                                    		// we will use this as the key in the hash
                                    		var birth_date = birthday.birth.substring(0,5);
                                    		// get the birthday as a moment in this year, for comparing
                                    		var birth_date_moment = moment(birth_date + now.year(),"DD.MMYYYY");
                                    		// you can add days to a moment object and then compare
                                    		//     if the birthdate is before that date (and after now)
                                    		//     so within the next xx days
                                    		// if the date is the same or later, don't use time of day
                                    		if(birth_date_moment.month() == now.month() ) {
                                    		    // birthday is in this month
                                    		    // check the hash if we've seen anything for today yet
                                    		    // if we haven't see this date yet
                                    		    if(this.active_birthdays[birth_date] == undefined) {
                                    			// create the holder for its info (array of
                                    			//	names) in the hash
                                    			this.active_birthdays[birth_date] = [];
                                    		    // save the persons name on the list
                                    		    self.active_birthdays[birth_date].push({'name':birthday.name,
                                    			'age': now.diff(moment(birthday.birth,'DD.MM.YYYY'), 'years') })
                                    	    // tell MM to call and get our content
                                    	    self.updateDom();
                                        // system notification your module is being hidden
                                        // typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
                                        suspend: function() {
                                        // system notification your module is being unhidden/shown
                                        // typically you would resume doing UI updates (getDom/updateDom) if the module is shown
                                        resume: function() {
                                        // this is the major worker of the module, it provides the
                                        // 	   displayable content for this module
                                        getDom: function() {
                                    	var self = this;
                                    	Log.log(JSON.stringify(this.active_birthdays))
                                    	if ((moment() > this.midnight) || (!this.loaded)) {
                                    	    var month = moment().month();
                                    	    var year = moment().year();
                                    //	    var monthName = moment().format("MMMM");
                                    //	    var monthLength = moment().daysInMonth();
                                    	    // tabelle erstellen
                                    	    var wrapper = document.createElement("table");
                                    	    wrapper.className = 'table';
                                    	    wrapper.id = 'birthday-table';
                                    	    // tabellenkopf erstellen
                                    	    var tHeader = document.createElement("thead");
                                    	    tHeader.className = "thead";
                                    	    tHeader.id = "birthday-thead";
                                    	    var headerTR = document.createElement("tr");
                                    	    headerTR.className = "tr-head";
                                    	    headerTR.id = "birthday-tr-head";
                                    	    var headerTH = document.createElement("th");
                                    	    headerTH.colSpan = "2";
                                    	    headerTH.scope = "col";
                                    	    headerTH.className = "th-head";
                                    	    headerTH.id = "birthday-th-head";
                                    	    headerTH.innerHTML = this.translate(this.config.title);
                                    	    headerTR.appendChild(headerTH);
                                    	    tHeader.appendChild(headerTR);
                                    	    wrapper.appendChild(tHeader);
                                    	    // Create TFOOT section -- currently used for debugging only
                                    	    var tFooter = document.createElement('tfoot');
                                    	    tFooter.className = "tfoot";
                                    	    tFooter.id = "birthday-tfoot";
                                    	    var footerTR = document.createElement("tr");
                                    	    footerTR.className = "tr-foot";
                                    	    footerTR.id = "birthday-tr-foot";
                                    	    var footerTD = document.createElement("td");
                                    	    footerTD.colSpan ="2";
                                    	    footerTD.className = "td-foot";
                                    	    footerTD.id = "birthday-td-foot";
                                    	    if (this.config.debugging) {
                                    		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
                                    	    else {
                                    		footerTD.innerHTML = "";
                                    	    footerTR.appendChild(footerTD);
                                    	    tFooter.appendChild(footerTR);
                                    	    wrapper.appendChild(tFooter);
                                    	for(var birthday of Object.keys(this.active_birthdays)) {
                                    	    for(var person of this.active_birthdays[birthday]) {
                                    		var m=document.createElement('div');
                                    		// create tour table row here
                                    		m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
                                    	// pass the created content back to MM to add to DOM.
                                    	this.loaded = true;
                                    	return wrapper;
                                    	    // Create TBODY section with day names
                                    	    var eintraege = 3;
                                    	    for (var i=1; i<=eintraege; i++) {
                                    		var tBody = document.createElement("tBody");
                                    		tBody.className = "tbody";
                                    		tBody.id = "birthday-tbody";
                                    		var bodyTR = document.createElement("tr");
                                    		bodyTR.className = "tr-body";
                                    		bodyTR.id = "birthday-tr-body";
                                    		var bodyTDimage = document.createElement("td");
                                    		bodyTDimage.className = "td-image";
                                    		bodyTDimage.id = "birthday-td-image";
                                    		bodyTDimage.innerHTML = "23";
                                    		var bodyTD = document.createElement("td");
                                    		bodyTD.className = "td-body";
                                    		bodyTD.id = "birthday-td-body";
                                    		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;<span class=\"age-span\">46</span></br>Frank Dubiel&nbsp;&nbsp;<span class=\"age-span\">54</span></br>Jürgen Gruse&nbsp;&nbsp;<span class=\"age-span\">52</span>";
                                    //		var bodyAgeSpan = document.createElement("span");
                                    //		bodyAgeSpan.className = "age-span";
                                    //		bodyAgeSpan.id = "birthday-age-span";
                                    //		bodyAgeSpan.innerHTML = "&nbsp;&nbsp;46";
                                    //		bodyTD.appendChild(bodyAgeSpan);
                                    		bodyTR.appendChild(bodyTDimage);
                                    		bodyTR.appendChild(bodyTD);
                                    		tBody.appendChild(bodyTR);
                                    		wrapper.appendChild(tBody);
                                        scheduleUpdate: function(delay) {
                                    	    Log.log("= = = = = = = = = = = = = = = = = = = = = = = = = = = = = =");
                                    	    Log.log("Birthdaylist IS IN DEBUG MODE!");
                                    	    Log.log("Remove 'debugging' option from config/config.js to disable.");
                                    	    Log.log("Current moment(): " + moment() + " (" + moment().format("hh:mm:ss a") + ")");
                                    	    Log.log("scheduleUpdate() delay set at: " + delay);
                                    	if (typeof delay !== "undefined" && delay >= 0) {
                                    	    nextReload = delay;
                                    	if (delay > 0) {
                                    	    // Calculate the time DIFFERENCE to that next reload!
                                    	    nextReload = moment.duration(nextReload.diff(moment(), "milliseconds"));
                                    		var hours = Math.floor(nextReload.asHours());
                                    		var  mins = Math.floor(nextReload.asMinutes()) - hours * 60;
                                    		var  secs = Math.floor(nextReload.asSeconds()) - ((hours * 3600 ) + (mins * 60));
                                    		Log.log("  nextReload should happen at: " + delay + " (" + moment(delay).format("hh:mm:ss a") + ")");
                                    		Log.log("                  which is in: " + mins + " minutes and " + secs + " seconds.");
                                    		Log.log("              midnight set at: " + this.midnight + " (" + moment(this.midnight).format("hh:mm:ss a") + ")");
                                    	var self = this;
                                    	setTimeout(function() {
                                    	    self.reloadDom();
                                    	}, nextReload);
                                        reloadDom: function() {
                                    	    Log.log("          Calling reloadDom()!");
                                    	var now = moment();
                                    	if (now > this.midnight) {
                                    	    this.updateDom(this.config.fadeSpeed * 1000);
                                    	var nextRefresh = moment([now.year(), now.month(), now.date(), now.hour() + 1]);
                                    	this.scheduleUpdate(nextRefresh);
                                    and thanks agaibn for your time …
                                      sdetweil @Perlchamp
                                      @Perlchamp awesome…
                                        Perlchamp
                                        i although thought about to include a template, but first i want to figure out the html-stuff and the if … than -statements (people the same day, date passed, and so on …), but you see i’m on fire right now …
                                          sdetweil @Perlchamp
                                          @Perlchamp cool… i did the age correction
                                            Perlchamp
                                            cool too :-) , so you still burn, too :-))
                                            • 10
                                            • 11
                                            • 12
                                            • 15
                                            • 16
                                            • 10 / 16
