    read csv-data and put it in an array
    313 Posts 3 Posters 546.4k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp sent chat message
      • PerlchampP Offline
        Perlchamp
        node_helper.js:
        var NodeHelper = require("node_helper");
        var moment = require("moment");
        // add require of other javascripot components here
        // var xxx = require('yyy'); here
        const csv = require("csvtojson");
        var birthdaysArray = [];
        	init(){
        		console.log("init module helper MMM-Perlchamp");
        	start() {
        	stop(){
        		console.log("Stopping module helper: ",this.name);
        	// handle messages from our module// each notification indicates a different messages
        	// payload is a data structure that is different per message.. up to you to design this
        	socketNotificationReceived(notification, payload) {
        		var self = this;
        		console.log("Starting module helper: ",this.name);
        		// convert the csv-file into a JSON-String
        		const csvFilePath = this.path + '/data/birthdays.csv';
        		csv()
        		.fromFile(csvFilePath)
        		.then(function(jsonObj) {
        			JSON.stringify(jsonObj);
        			// send data to [modulname].js
        			self.sendSocketNotification("HAVEDATA", jsonObj);
        		// if config message from module
        		if (notification === "CONFIG") {
        			// save payload config info
        			this.config = payload;
        			// wait 15 seconds, send a message back to module
        			setTimeout(()=> {this.sendSocketNotification("message_from_helper"," this is a test_message")}, 15000);
        		else if(notification === "????2") {
        MMM-Perlchamp.js:
        Module.register("MMM-Perlchamp", {
        	defaults: {
        		language: "de",
        		dimmEntries: true   // true: dims entries and the associated
        							//       symbol when the date has expired.
        							// false: delete entries and the associated
        	active_birthdays: {
        	init: function(){
        		Log.log(this.name + " is in init!");
        	start: function(){
        		Log.log("Starting module: " + this.name);
        		// Set locale
        		moment.locale(config.language);
        	loaded: function(callback) {
        		Log.log(this.name + " is loaded!");
        		callback();
        	// return list of other functional scripts to use, if any (like require in node_helper)
        	getScripts: function() {
        		return	["moment.js"];
        	// return list of stylesheet files to use if any
        	getStyles: function() {
        		return 	[this.data.path + "/css/MMM-Perlchamp.css"];
        	// only called if the module header was configured in module config in config.js
        	getHeader: function() {
        		return this.data.header;
        	// messages received from other modules and the system (NOT from your node helper)
        	// payload is a notification dependent data structure
        		// once everybody is loaded up
        		if(notification === "ALL_MODULES_STARTED"){
        			// send our config to our node_helper
        			this.sendSocketNotification("CONFIG",this.config);
        		if (sender) {
        			Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
        		} else {
        			Log.log(this.name + " received a system notification: " + notification);
        	// messages received from from your node helper (NOT other modules or the system)
        	// payload is a notification dependent data structure, up to you to design between module and node_helper
        		if(notification === "HAVEDATA") {
        			var self = this;
        			Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
        			var now = moment();
        			for(var birthday of payload) {
        				// get 1st 5 chars of birthdate, thru month
        				// we will use this as the key in the hash
        				var birth_date = birthday.birth.substring(0,5);
        				// get the birthday as a moment in this year, for comparing
        				var birth_date_moment = moment(birth_date + now.year(),"DD.MMYYYY");
        				// u can add days to a moment object and then compare
        				//     if the birthdate is before that date (and after now)
        				//     so within the next xx days
        				// if the date is the same or later, don't use time of day
        				if(birth_date_moment.startOf('day').isSameOrAfter(now.startOf('day')) &&
        		   	  birth_date_moment.startOf('day').isSameOrBefore(birthday_time_window.startOf('day'))) {
        					// birthday is in this month
        					// check the hash if we've seen anything for today yet
        					// if we haven't see this date yet
        					if(this.active_birthdays[birth_date] == undefined){
        						//  create the holder for its info (array of
        						//		names) in the hash
        						this.active_birthdays[birth_date] = [];
        					// save the persons name on the list
        					self.active_birthdays[birth_date].push({'name':birthday.name, 'age': now.diff(moment(birthday.birth,'DD.MM.YYYY'), 'years') })
        //					this.active_birthdays[birth_date].push(birthday.name);
        			Log.log("this.active_birthdays >>>>> ", this.active_birthdays);
        //			var currentMonth = new Date().toLocaleDateString('en', {month:'2-digit'});
        			var currentMonth = moment().format("MM");
        			var result = Object.entries(payload
        			.filter(({birth}) => birth.split('.')[1] === currentMonth)
        			.reduce((a, {birth, name}) => {
        				const day = +birth.split('.')[0];
        				a[day] = [...(a[day] || []), name];
        				return a
        			).map(([day, name]) => ({day, name})).sort((a, b) => +a.day - b.day);
        			console.log("LISTE >> ", result);
        			// tell MM to call and get our content
        			self.updateDom();
        	// system notification your module is being hidden
        	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
        	suspend: function() {
        	// system notification your module is being unhidden/shown
        	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
        	resume: function() {
        	// this is the major worker of the module, it provides the displayable content for this module
        	getDom: function() {
        		var self = this;
        Log.log(JSON.stringify(this.active_birthdays))    // add this line
        			self.updateDom();                          // before this line in the notification code..
        		for(var birthday of Object.keys(this.active_birthdays)) {
        			for(var name of this.active_birthdays[birthday]) {
        				var m = document.createElement("div");
        				Log.log("BIRTHDAY >> " + birthday);
        				Log.log("NAME >> " + name);
        				m.innerText = birthday + " " + name;
        				wrapper.appendChild(m);
        		// pass the created content back to MM to add to DOM.
        		return wrapper;
        birthdays.csv in folder MMM-Perlchamp/data:
        birth,name
        03.01.1940,aaa AAAAA
        06.01.1969,bbb BBBBB
        15.02.1939,ccc CCCCC
        07.03.1972,ddd DDDDD
        10.05.1969,eee EEEEE
        16.05.2012,fff FFFFF
        16.05.1988,ggg GGGGG
        27.05.2002,hhh HHHHH
        08.07.1976,iiii IIIII
        13.07.1914,jjj JJJJJ
        27.08.1968,kkk KKKKK
        21.09.1967,lll LLLLL
        13.10.1965,mmm MMMMM
        16.10.2010,nnn NNNNN
        23.10.1941,ooo OOOOO
        19.12.1935,ppp PPPPP
        MMM-Perlchamp.css in folder MMM-Perlchamp/css
        .MMM-Perlchamp header {
          letter-spacing: 0.1em;
          text-transform: uppercase;
          font-size: 20px;
          font-family: "Roboto Condensed", Arial, Helvetica, sans-serif;
          font-weight: 400;
          border-bottom: 1px solid #444444;
          line-height: 20px;
          padding-bottom: 5px;
          color: #ffffff;
          font-variant: small-caps;
          sdetweil @Perlchamp
          @Perlchamp said in read csv-data and put it in an array:
          yes it only shows for today+some possible offset… I said u had to fix that to do month comparison
            Perlchamp
            shame on me, sorry for that. now it’s changed to:
            if(birth_date_moment.startOf('month').isSameOrAfter(now.startOf('month')) &&
            					birth_date_moment.startOf('month').isSameOrBefore(birthday_time_window.startOf('month'))) {
            nothing changed, i have configured the terminal-window to scroll about 3000 (!) lines, but can’t see the beginning …
              sdetweil @Perlchamp
              @Perlchamp redirect the terminal window to a file and edit that
              do this in the code
              			 	//if(birth_date_moment.startOf('day').isSameOrAfter(now.startOf('day')) &&
                                              //  birth_date_moment.startOf('day').isSameOrBefore(birthday_time_window.startOf('day'))) {
              			   	if( birth_date_moment.month() == now.month() ){
                Perlchamp
                done, it’s frozen now. must restart …
                  Perlchamp
                  question:
                  in the
                  			var self = this;
                  payload should be the variable in which the jsonString is saved ?
                    sdetweil @Perlchamp
                    @Perlchamp it has the jsonObj from the node_helper
                    u can call it anything, its just a name
                    so, if you put a stop right on the var self = this
                    and then cursor over the work payload in
                    it will show you that object content, and u can go up and click on parts to make them expand to examine the contents
                      Perlchamp
                      ok, there is a light at the end of the tunnel:
                        code was changed to add ages
                        in getDom()
                        now is
                        			for(var person of this.active_birthdays[birthday]){
                        				var m=document.createElement('div')
                        // create your table row here
                        				m.innerText=birthday+ ' '+ person.name+' age='+person.age
                          Perlchamp
                          great, thanks !
                          to your information:
                          there are NO semikolons in your posted code. within them it goes !
                            sdetweil @Perlchamp
                            @Perlchamp end of line ; are not required… I cut/pasted that code out of the running module
                              Perlchamp
                              without i have a black screen, with everythings fine.
                              another information:
                              age must be +1 but i think i will solve this alone. if not i’m too stuipid for this all :-)
                              so i can create my table now. but i see:
                              people who has birthday the same day:
                              date should be displayed once, and the names in the same , separated by
                                sdetweil @Perlchamp
                                @Perlchamp ok, I think you can fix those… age is a date diff()… add to results
                                edit: age needs more work that just number… because they were comparing MONTH, but age was exact days.
                                so I change my bd to may, but TODAY I am 68… in may i WILL BE 69 (in the future)
                                so if TODAY or before, do NOT add one, if tomorrow or after (in the month) add 1
                                  Perlchamp
                                  i think, too. thanks very much, sam. I don’t know how to thank you Thank you very much !
                                  you’re great !
                                  and it is up to you whether you publish this module. I will not adorn myself with foreign feathers!
                                    sdetweil @Perlchamp
                                    @Perlchamp its not my module… its yours…
                                      sdetweil @Perlchamp
                                      @Perlchamp see how interesting ‘just a birthday list’ can be! and u still have styles to apply etc
                                        Perlchamp
                                        I do not think so. I could never answer questions about any problems …
                                        i did:
                                        ... age='+(person.age + 1);
                                        the styles you could get from me, no problem. it’s just fair, isn’t it ?
                                          sdetweil @Perlchamp
                                          @Perlchamp should be wrong for people with birthday yesterday
                                            Perlchamp
                                            ah, oooook … hm. shooted to fast. but let me figured out by myself, cause i don’t wonna feel like a baby … i think if-statements and moment() could be helpfully.
                                            • 10
                                            • 11
                                            • 15
                                            • 16
                                            • 9 / 16
