    read csv-data and put it in an array
    313 Posts 3 Posters 590.2k Views 4 Watching
    • PerlchampP
      Perlchamp
      i think, too. thanks very much, sam. I don’t know how to thank you Thank you very much !
      you’re great !
      and it is up to you whether you publish this module. I will not adorn myself with foreign feathers!
      S 2 Replies Last reply
        sdetweil @Perlchamp
        @Perlchamp its not my module… its yours…
          sdetweil @Perlchamp
          @Perlchamp see how interesting ‘just a birthday list’ can be! and u still have styles to apply etc
          • PerlchampP
            Perlchamp
            I do not think so. I could never answer questions about any problems …
            i did:
            ... age='+(person.age + 1);
            the styles you could get from me, no problem. it’s just fair, isn’t it ?
              sdetweil @Perlchamp
              @Perlchamp should be wrong for people with birthday yesterday
              • PerlchampP
                Perlchamp
                ah, oooook … hm. shooted to fast. but let me figured out by myself, cause i don’t wonna feel like a baby … i think if-statements and moment() could be helpfully.
                • PerlchampP
                  Perlchamp
                  general question:
                  is there something like “print”? (for debugging) or have i use innerText or innerHTML or Log.log ? … to display something on screen ?
                    sdetweil @Perlchamp
                    @Perlchamp Log.log only
                    did u see my chat message about fixing a bug in the MMM-Logging module
                    • PerlchampP
                      Perlchamp
                      i will have a look on it, though MERCI !
                        sdetweil @Perlchamp
                        @Perlchamp one other thing, u need to start a timer for when the month changes, when the timer expires, send a CONFIG message to the node_helper and it will send the latest birthdays list and everything will recalculate
                        • PerlchampP
                          Perlchamp
                          hi sam, yes i thought about. in the moment this is the actually file, though there is code annotate and at the wrong place, … just so you don’t wonder … :
                          /* global Module */
                          /* Magic Mirror
                           * Module: birthdaylist
                           * Author: perlchamp@gmx.net
                           * Lizenz: MIT
                          Module.register("birthdaylist", {
                              // Default module config.
                              defaults: {
                          	debugging: false,
                          	initialLoadDelay: 0,		// How many seconds to wait on a fresh start up.
                          					// This is to prevent collision with all other modules also
                          					// loading all at the same time. This only happens once,
                          					// when the mirror first starts up.
                          	dimmEntries: true,   		// true: dims entries and the associated
                          					//       symbol when the date has expired.
                          					// false: delete entries and the associated
                          	language: "de",			// needed for dateformatting
                          	updateDelay: 5		        // How many seconds after midnight before a refresh
                          				        // This is to prevent collision with other modules refreshing
                          				        // at the same time.
                              active_birthdays: {
                              init: function() {
                          	Log.log(this.name + " is in init!");
                              // Override start method
                              start: function() {
                          	Log.log("Starting module: " + this.name);
                          	// set locale here, default: de
                          	moment.locale(config.language);
                          	// Calculate next midnight and add updateDelay
                          	var now = moment();
                          	this.midnight = moment([now.year(), now.month(), now.date() + 1]).add(this.config.updateDelay, "seconds");
                          	this.loaded = false;
                          	this.scheduleUpdate(this.config.initialLoadDelay * 1000);
                              loaded: function(callback) {
                          	Log.log(this.name + " is loaded!");
                          	callback();
                              // return list of other functional scripts to use, if any (like require in node_helper)
                              getScripts: function () {
                          	return ["moment.js"];
                              // return list of stylesheet files to use if any
                              getStyles: function() {
                          	return [this.data.path + "/css/bdl.css"];
                              // you can configure the heading of the list in config.js
                              getHeader: function() {
                          	return this.data.header;
                              // messages received from other modules and the system (NOT from your node helper)
                              // payload is a notification dependent data structure
                          	// once everybody is loaded up
                          	if(notification === "ALL_MODULES_STARTED") {
                          	    // send our config to our node_helper
                          	    this.sendSocketNotification("CONFIG",this.config);
                          	if (sender) {
                          	    Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
                          	else {
                          	    Log.log(this.name + " received a system notification: " + notification);
                              // messages received from from your node helper (NOT other modules or the system)
                              // payload is a notification dependent data structure, up to you to design between module and node_helper
                          	if(notification === "JSONDATA") {
                          	    var self = this;
                          	    Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                          	    var now = moment();
                          	    var day_month = moment().format("DD");
                          	    for(var birthday of payload) {
                          		// get 1st 5 chars of birthdate, thru month
                          		// we will use this as the key in the hash
                          		var birth_date = birthday.birth.substring(0,5);
                          		// get the birthday as a moment in this year, for comparing
                          		var birth_date_moment = moment(birth_date + now.year(),"DD.MMYYYY");
                          		// you can add days to a moment object and then compare
                          		//     if the birthdate is before that date (and after now)
                          		//     so within the next xx days
                          		// if the date is the same or later, don't use time of day
                          		if(birth_date_moment.month() == now.month() ) {
                          		    // birthday is in this month
                          		    // check the hash if we've seen anything for today yet
                          		    // if we haven't see this date yet
                          		    if(this.active_birthdays[birth_date] == undefined) {
                          			// create the holder for its info (array of
                          			//	names) in the hash
                          			this.active_birthdays[birth_date] = [];
                          		    // save the persons name on the list
                          		    self.active_birthdays[birth_date].push({'name':birthday.name,
                          			'age': now.diff(moment(birthday.birth,'DD.MM.YYYY'), 'years') })
                          	    // tell MM to call and get our content
                          	    self.updateDom();
                              // system notification your module is being hidden
                              // typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
                              suspend: function() {
                              // system notification your module is being unhidden/shown
                              // typically you would resume doing UI updates (getDom/updateDom) if the module is shown
                              resume: function() {
                              // this is the major worker of the module, it provides the
                              // 	   displayable content for this module
                              getDom: function() {
                          	var self = this;
                          	Log.log(JSON.stringify(this.active_birthdays))
                          	if ((moment() > this.midnight) || (!this.loaded)) {
                          	    var month = moment().month();
                          	    var year = moment().year();
                          //	    var monthName = moment().format("MMMM");
                          //	    var monthLength = moment().daysInMonth();
                          	    // tabelle erstellen
                          	    var wrapper = document.createElement("table");
                          	    wrapper.className = 'table';
                          	    wrapper.id = 'birthday-table';
                          	    // tabellenkopf erstellen
                          	    var tHeader = document.createElement("thead");
                          	    tHeader.className = "thead";
                          	    tHeader.id = "birthday-thead";
                          	    var headerTR = document.createElement("tr");
                          	    headerTR.className = "tr-head";
                          	    headerTR.id = "birthday-tr-head";
                          	    var headerTH = document.createElement("th");
                          	    headerTH.colSpan = "2";
                          	    headerTH.scope = "col";
                          	    headerTH.className = "th-head";
                          	    headerTH.id = "birthday-th-head";
                          	    headerTH.innerHTML = this.translate(this.config.title);
                          	    headerTR.appendChild(headerTH);
                          	    tHeader.appendChild(headerTR);
                          	    wrapper.appendChild(tHeader);
                          	    // Create TFOOT section -- currently used for debugging only
                          	    var tFooter = document.createElement('tfoot');
                          	    tFooter.className = "tfoot";
                          	    tFooter.id = "birthday-tfoot";
                          	    var footerTR = document.createElement("tr");
                          	    footerTR.className = "tr-foot";
                          	    footerTR.id = "birthday-tr-foot";
                          	    var footerTD = document.createElement("td");
                          	    footerTD.colSpan ="2";
                          	    footerTD.className = "td-foot";
                          	    footerTD.id = "birthday-td-foot";
                          	    if (this.config.debugging) {
                          		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
                          	    else {
                          		footerTD.innerHTML = "";
                          	    footerTR.appendChild(footerTD);
                          	    tFooter.appendChild(footerTR);
                          	    wrapper.appendChild(tFooter);
                          	for(var birthday of Object.keys(this.active_birthdays)) {
                          	    for(var person of this.active_birthdays[birthday]) {
                          		var m=document.createElement('div');
                          		// create tour table row here
                          		m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
                          		wrapper.appendChild(m);
                          	// pass the created content back to MM to add to DOM.
                          	this.loaded = true;
                          	return wrapper;
                          	    // Create TBODY section with day names
                          	    var eintraege = 3;
                          	    for (var i=1; i<=eintraege; i++) {
                          		var tBody = document.createElement("tBody");
                          		tBody.className = "tbody";
                          		tBody.id = "birthday-tbody";
                          		var bodyTR = document.createElement("tr");
                          		bodyTR.className = "tr-body";
                          		bodyTR.id = "birthday-tr-body";
                          		var bodyTDimage = document.createElement("td");
                          		bodyTDimage.className = "td-image";
                          		bodyTDimage.id = "birthday-td-image";
                          		bodyTDimage.innerHTML = "23";
                          		var bodyTD = document.createElement("td");
                          		bodyTD.className = "td-body";
                          		bodyTD.id = "birthday-td-body";
                          		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;<span class=\"age-span\">46</span></br>Frank Dubiel&nbsp;&nbsp;<span class=\"age-span\">54</span></br>Jürgen Gruse&nbsp;&nbsp;<span class=\"age-span\">52</span>";
                          //		var bodyAgeSpan = document.createElement("span");
                          //		bodyAgeSpan.className = "age-span";
                          //		bodyAgeSpan.id = "birthday-age-span";
                          //		bodyAgeSpan.innerHTML = "&nbsp;&nbsp;46";
                          //		bodyTD.appendChild(bodyAgeSpan);
                          		bodyTR.appendChild(bodyTDimage);
                          		bodyTR.appendChild(bodyTD);
                          		tBody.appendChild(bodyTR);
                          		wrapper.appendChild(tBody);
                              scheduleUpdate: function(delay) {
                          	    Log.log("= = = = = = = = = = = = = = = = = = = = = = = = = = = = = =");
                          	    Log.log("Birthdaylist IS IN DEBUG MODE!");
                          	    Log.log("Remove 'debugging' option from config/config.js to disable.");
                          	    Log.log("Current moment(): " + moment() + " (" + moment().format("hh:mm:ss a") + ")");
                          	    Log.log("scheduleUpdate() delay set at: " + delay);
                          	if (typeof delay !== "undefined" && delay >= 0) {
                          	    nextReload = delay;
                          	if (delay > 0) {
                          	    // Calculate the time DIFFERENCE to that next reload!
                          	    nextReload = moment.duration(nextReload.diff(moment(), "milliseconds"));
                          		var hours = Math.floor(nextReload.asHours());
                          		var  mins = Math.floor(nextReload.asMinutes()) - hours * 60;
                          		var  secs = Math.floor(nextReload.asSeconds()) - ((hours * 3600 ) + (mins * 60));
                          		Log.log("  nextReload should happen at: " + delay + " (" + moment(delay).format("hh:mm:ss a") + ")");
                          		Log.log("                  which is in: " + mins + " minutes and " + secs + " seconds.");
                          		Log.log("              midnight set at: " + this.midnight + " (" + moment(this.midnight).format("hh:mm:ss a") + ")");
                          	var self = this;
                          	setTimeout(function() {
                          	    self.reloadDom();
                          	}, nextReload);
                              reloadDom: function() {
                          	    Log.log("          Calling reloadDom()!");
                          	var now = moment();
                          	if (now > this.midnight) {
                          	    this.updateDom(this.config.fadeSpeed * 1000);
                          	var nextRefresh = moment([now.year(), now.month(), now.date(), now.hour() + 1]);
                          	this.scheduleUpdate(nextRefresh);
                          and thanks agaibn for your time …
                            sdetweil @Perlchamp
                            @Perlchamp awesome…
                            • PerlchampP
                              Perlchamp
                              i although thought about to include a template, but first i want to figure out the html-stuff and the if … than -statements (people the same day, date passed, and so on …), but you see i’m on fire right now …
                                sdetweil @Perlchamp
                                @Perlchamp cool… i did the age correction
                                • PerlchampP
                                  Perlchamp
                                  cool too :-) , so you still burn, too :-))
                                  • PerlchampP
                                    Perlchamp
                                    hi sam, i know that the code of table is working (in testmodule). but can’t get objects in there. did look in dev-widow, but looks fine. in the terminal-window i see that objects have been handed over (node to module.js). this is the code for the body of the table:
                                    	    // create TBODY section with day names
                                    		    //var m = document.createElement('div');
                                    		    // create looped row section
                                    		    bodyTDimage.innerHTML = birthday;
                                    		    bodyTD.innerHTML = person.name + "<span class=\"age-span\">" + person.age + "</span>";
                                    		    //m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
                                    		    //wrapper.appendChild(m);
                                    what did i make wrong ?
                                    • PerlchampP
                                      Perlchamp
                                      @Perlchamp said in read csv-data and put it in an array:
                                      bodyTD.innerHTML = person.name + “” + person.age + “”;
                                      should be:
                                      bodyTD.innerHTML = person.name + span class = … + person.age + /span;
                                      can’t send html tags here ? how i have to escape them here ?
                                        sdetweil @Perlchamp
                                        @Perlchamp cannot escape tags here, long time complaint
                                        • PerlchampP
                                          Perlchamp
                                          did it !
                                          this.loaded = true; was wrong placed …
                                          • PerlchampP
                                            Perlchamp
                                            but this does not work yet:
                                            		    if (birthday.charAt(0) === "0") {
                                            			birthday = birthday.replace("0","");
                                            			birthday = birthday.substring(0,1);
                                            		    bodyTDimage.innerHTML = birthday.substring(0,2);
                                            the value will not displayed, but i will find a way. my code yet is far away from a smart code :-))
                                            • 10
                                            • 11
                                            • 12
                                            • 15
                                            • 16
                                            • 10 / 16
