    read csv-data and put it in an array
    313 Posts 3 Posters 530.2k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp Log.log only
      did u see my chat message about fixing a bug in the MMM-Logging module
      • PerlchampP Offline
        Perlchamp
        i will have a look on it, though MERCI !
          sdetweil @Perlchamp
          @Perlchamp one other thing, u need to start a timer for when the month changes, when the timer expires, send a CONFIG message to the node_helper and it will send the latest birthdays list and everything will recalculate
            Perlchamp
            hi sam, yes i thought about. in the moment this is the actually file, though there is code annotate and at the wrong place, … just so you don’t wonder … :
            /* global Module */
            /* Magic Mirror
             * Module: birthdaylist
             * Author: perlchamp@gmx.net
             * Lizenz: MIT
            Module.register("birthdaylist", {
                // Default module config.
                defaults: {
            	debugging: false,
            	initialLoadDelay: 0,		// How many seconds to wait on a fresh start up.
            					// This is to prevent collision with all other modules also
            					// loading all at the same time. This only happens once,
            					// when the mirror first starts up.
            	dimmEntries: true,   		// true: dims entries and the associated
            					//       symbol when the date has expired.
            					// false: delete entries and the associated
            	language: "de",			// needed for dateformatting
            	updateDelay: 5		        // How many seconds after midnight before a refresh
            				        // This is to prevent collision with other modules refreshing
            				        // at the same time.
                active_birthdays: {
                init: function() {
            	Log.log(this.name + " is in init!");
                // Override start method
                start: function() {
            	Log.log("Starting module: " + this.name);
            	// set locale here, default: de
            	moment.locale(config.language);
            	// Calculate next midnight and add updateDelay
            	var now = moment();
            	this.midnight = moment([now.year(), now.month(), now.date() + 1]).add(this.config.updateDelay, "seconds");
            	this.loaded = false;
            	this.scheduleUpdate(this.config.initialLoadDelay * 1000);
                loaded: function(callback) {
            	Log.log(this.name + " is loaded!");
            	callback();
                // return list of other functional scripts to use, if any (like require in node_helper)
                getScripts: function () {
            	return ["moment.js"];
                // return list of stylesheet files to use if any
                getStyles: function() {
            	return [this.data.path + "/css/bdl.css"];
                // you can configure the heading of the list in config.js
                getHeader: function() {
            	return this.data.header;
                // messages received from other modules and the system (NOT from your node helper)
                // payload is a notification dependent data structure
            	// once everybody is loaded up
            	if(notification === "ALL_MODULES_STARTED") {
            	    // send our config to our node_helper
            	    this.sendSocketNotification("CONFIG",this.config);
            	if (sender) {
            	    Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
            	else {
            	    Log.log(this.name + " received a system notification: " + notification);
                // messages received from from your node helper (NOT other modules or the system)
                // payload is a notification dependent data structure, up to you to design between module and node_helper
            	if(notification === "JSONDATA") {
            	    var self = this;
            	    Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
            	    var now = moment();
            	    var day_month = moment().format("DD");
            	    for(var birthday of payload) {
            		// get 1st 5 chars of birthdate, thru month
            		// we will use this as the key in the hash
            		var birth_date = birthday.birth.substring(0,5);
            		// get the birthday as a moment in this year, for comparing
            		var birth_date_moment = moment(birth_date + now.year(),"DD.MMYYYY");
            		// you can add days to a moment object and then compare
            		//     if the birthdate is before that date (and after now)
            		//     so within the next xx days
            		// if the date is the same or later, don't use time of day
            		if(birth_date_moment.month() == now.month() ) {
            		    // birthday is in this month
            		    // check the hash if we've seen anything for today yet
            		    // if we haven't see this date yet
            		    if(this.active_birthdays[birth_date] == undefined) {
            			// create the holder for its info (array of
            			//	names) in the hash
            			this.active_birthdays[birth_date] = [];
            		    // save the persons name on the list
            		    self.active_birthdays[birth_date].push({'name':birthday.name,
            			'age': now.diff(moment(birthday.birth,'DD.MM.YYYY'), 'years') })
            	    // tell MM to call and get our content
            	    self.updateDom();
                // system notification your module is being hidden
                // typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
                suspend: function() {
                // system notification your module is being unhidden/shown
                // typically you would resume doing UI updates (getDom/updateDom) if the module is shown
                resume: function() {
                // this is the major worker of the module, it provides the
                // 	   displayable content for this module
                getDom: function() {
            	var self = this;
            	Log.log(JSON.stringify(this.active_birthdays))
            	if ((moment() > this.midnight) || (!this.loaded)) {
            	    var month = moment().month();
            	    var year = moment().year();
            //	    var monthName = moment().format("MMMM");
            //	    var monthLength = moment().daysInMonth();
            	    // tabelle erstellen
            	    var wrapper = document.createElement("table");
            	    wrapper.className = 'table';
            	    wrapper.id = 'birthday-table';
            	    // tabellenkopf erstellen
            	    var tHeader = document.createElement("thead");
            	    tHeader.className = "thead";
            	    tHeader.id = "birthday-thead";
            	    var headerTR = document.createElement("tr");
            	    headerTR.className = "tr-head";
            	    headerTR.id = "birthday-tr-head";
            	    var headerTH = document.createElement("th");
            	    headerTH.colSpan = "2";
            	    headerTH.scope = "col";
            	    headerTH.className = "th-head";
            	    headerTH.id = "birthday-th-head";
            	    headerTH.innerHTML = this.translate(this.config.title);
            	    headerTR.appendChild(headerTH);
            	    tHeader.appendChild(headerTR);
            	    wrapper.appendChild(tHeader);
            	    // Create TFOOT section -- currently used for debugging only
            	    var tFooter = document.createElement('tfoot');
            	    tFooter.className = "tfoot";
            	    tFooter.id = "birthday-tfoot";
            	    var footerTR = document.createElement("tr");
            	    footerTR.className = "tr-foot";
            	    footerTR.id = "birthday-tr-foot";
            	    var footerTD = document.createElement("td");
            	    footerTD.colSpan ="2";
            	    footerTD.className = "td-foot";
            	    footerTD.id = "birthday-td-foot";
            	    if (this.config.debugging) {
            		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
            	    else {
            		footerTD.innerHTML = "";
            	    footerTR.appendChild(footerTD);
            	    tFooter.appendChild(footerTR);
            	    wrapper.appendChild(tFooter);
            	for(var birthday of Object.keys(this.active_birthdays)) {
            	    for(var person of this.active_birthdays[birthday]) {
            		var m=document.createElement('div');
            		// create tour table row here
            		m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
            		wrapper.appendChild(m);
            	// pass the created content back to MM to add to DOM.
            	this.loaded = true;
            	return wrapper;
            	    // Create TBODY section with day names
            	    var eintraege = 3;
            	    for (var i=1; i<=eintraege; i++) {
            		var tBody = document.createElement("tBody");
            		tBody.className = "tbody";
            		tBody.id = "birthday-tbody";
            		var bodyTR = document.createElement("tr");
            		bodyTR.className = "tr-body";
            		bodyTR.id = "birthday-tr-body";
            		var bodyTDimage = document.createElement("td");
            		bodyTDimage.className = "td-image";
            		bodyTDimage.id = "birthday-td-image";
            		bodyTDimage.innerHTML = "23";
            		var bodyTD = document.createElement("td");
            		bodyTD.className = "td-body";
            		bodyTD.id = "birthday-td-body";
            		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;<span class=\"age-span\">46</span></br>Frank Dubiel&nbsp;&nbsp;<span class=\"age-span\">54</span></br>Jürgen Gruse&nbsp;&nbsp;<span class=\"age-span\">52</span>";
            //		var bodyAgeSpan = document.createElement("span");
            //		bodyAgeSpan.className = "age-span";
            //		bodyAgeSpan.id = "birthday-age-span";
            //		bodyAgeSpan.innerHTML = "&nbsp;&nbsp;46";
            //		bodyTD.appendChild(bodyAgeSpan);
            		bodyTR.appendChild(bodyTDimage);
            		bodyTR.appendChild(bodyTD);
            		tBody.appendChild(bodyTR);
            		wrapper.appendChild(tBody);
                scheduleUpdate: function(delay) {
            	    Log.log("= = = = = = = = = = = = = = = = = = = = = = = = = = = = = =");
            	    Log.log("Birthdaylist IS IN DEBUG MODE!");
            	    Log.log("Remove 'debugging' option from config/config.js to disable.");
            	    Log.log("Current moment(): " + moment() + " (" + moment().format("hh:mm:ss a") + ")");
            	    Log.log("scheduleUpdate() delay set at: " + delay);
            	if (typeof delay !== "undefined" && delay >= 0) {
            	    nextReload = delay;
            	if (delay > 0) {
            	    // Calculate the time DIFFERENCE to that next reload!
            	    nextReload = moment.duration(nextReload.diff(moment(), "milliseconds"));
            		var hours = Math.floor(nextReload.asHours());
            		var  mins = Math.floor(nextReload.asMinutes()) - hours * 60;
            		var  secs = Math.floor(nextReload.asSeconds()) - ((hours * 3600 ) + (mins * 60));
            		Log.log("  nextReload should happen at: " + delay + " (" + moment(delay).format("hh:mm:ss a") + ")");
            		Log.log("                  which is in: " + mins + " minutes and " + secs + " seconds.");
            		Log.log("              midnight set at: " + this.midnight + " (" + moment(this.midnight).format("hh:mm:ss a") + ")");
            	var self = this;
            	setTimeout(function() {
            	    self.reloadDom();
            	}, nextReload);
                reloadDom: function() {
            	    Log.log("          Calling reloadDom()!");
            	var now = moment();
            	if (now > this.midnight) {
            	    this.updateDom(this.config.fadeSpeed * 1000);
            	var nextRefresh = moment([now.year(), now.month(), now.date(), now.hour() + 1]);
            	this.scheduleUpdate(nextRefresh);
            and thanks agaibn for your time …
              sdetweil @Perlchamp
              @Perlchamp awesome…
                Perlchamp
                i although thought about to include a template, but first i want to figure out the html-stuff and the if … than -statements (people the same day, date passed, and so on …), but you see i’m on fire right now …
                  sdetweil @Perlchamp
                  @Perlchamp cool… i did the age correction
                    Perlchamp
                    cool too :-) , so you still burn, too :-))
                      Perlchamp
                      hi sam, i know that the code of table is working (in testmodule). but can’t get objects in there. did look in dev-widow, but looks fine. in the terminal-window i see that objects have been handed over (node to module.js). this is the code for the body of the table:
                      	    // create TBODY section with day names
                      		    //var m = document.createElement('div');
                      		    // create looped row section
                      		    bodyTDimage.innerHTML = birthday;
                      		    bodyTD.innerHTML = person.name + "<span class=\"age-span\">" + person.age + "</span>";
                      		    //m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
                      		    //wrapper.appendChild(m);
                      what did i make wrong ?
                        Perlchamp
                        @Perlchamp said in read csv-data and put it in an array:
                        bodyTD.innerHTML = person.name + “” + person.age + “”;
                        should be:
                        bodyTD.innerHTML = person.name + span class = … + person.age + /span;
                        can’t send html tags here ? how i have to escape them here ?
                          sdetweil @Perlchamp
                          @Perlchamp cannot escape tags here, long time complaint
                            Perlchamp
                            did it !
                            this.loaded = true; was wrong placed …
                              Perlchamp
                              but this does not work yet:
                              		    if (birthday.charAt(0) === "0") {
                              			birthday = birthday.replace("0","");
                              			birthday = birthday.substring(0,1);
                              		    bodyTDimage.innerHTML = birthday.substring(0,2);
                              the value will not displayed, but i will find a way. my code yet is far away from a smart code :-))
                                Perlchamp
                                this is the status at the moment :
                                  sdetweil @Perlchamp
                                  @Perlchamp cool… do you want ages aligned?
                                    Perlchamp
                                    yes, of course, sir …
                                      sdetweil @Perlchamp
                                      @Perlchamp need to specify width of td
                                      By default, a browser will adjust table columns to fit the contents of the table. However, if you want to control the width of each column, you can do so by adjusting the width of each or of a single row.
                                      if you had th, then you could see the length of the names as they go by, and then adjust the th width before sending the content to MM…
                                        Perlchamp
                                        width:27px; is placed in css
                                        but this:
                                        //bodyTDimage.id = "birthday-td-image";
                                        works. i really have to write html-text in the module-file ?
                                          sdetweil @Perlchamp
                                          @Perlchamp eh? commenting out a line?
                                          have a th is the same as what you have document.createElement(“th”)
                                            Perlchamp
                                            wrong line, moment:
                                            //bodyTDimage.className = "td-image";
                                            this works, but unformatted, of course
                                            i don’t like things like:
                                            innerHTLM = tags, tags, tags …
                                            • 10
                                            • 11
                                            • 12
                                            • 15
                                            • 16
                                            • 10 / 16
