    read csv-data and put it in an array
    313 Posts 3 Posters 590.1k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp cool… i did the age correction
      • PerlchampP
        Perlchamp
        cool too :-) , so you still burn, too :-))
        • PerlchampP
          Perlchamp
          hi sam, i know that the code of table is working (in testmodule). but can’t get objects in there. did look in dev-widow, but looks fine. in the terminal-window i see that objects have been handed over (node to module.js). this is the code for the body of the table:
          	    // create TBODY section with day names
          	    var tBody = document.createElement("tBody");
          	    tBody.className = "tbody";
          	    tBody.id = "birthday-tbody";
          	    for(var birthday of Object.keys(this.active_birthdays)) {
          		for(var person of this.active_birthdays[birthday]) {
          		    //var m = document.createElement('div');
          		    // create looped row section
          		    var bodyTR = document.createElement("tr");
          		    bodyTR.className = "tr-body";
          		    bodyTR.id = "birthday-tr-body";
          		    var bodyTDimage = document.createElement("td");
          		    bodyTDimage.className = "td-image";
          		    bodyTDimage.id = "birthday-td-image";
          		    bodyTDimage.innerHTML = birthday;
          		    var bodyTD = document.createElement("td");
          		    bodyTD.className = "td-body";
          		    bodyTD.id = "birthday-td-body";
          		    bodyTD.innerHTML = person.name + "<span class=\"age-span\">" + person.age + "</span>";
          		    //m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
          		    //wrapper.appendChild(m);
          		    bodyTR.appendChild(bodyTDimage);
          		    bodyTR.appendChild(bodyTD);
          		    tBody.appendChild(bodyTR);
          		    wrapper.appendChild(tBody);
          what did i make wrong ?
          • PerlchampP
            Perlchamp
            @Perlchamp said in read csv-data and put it in an array:
            bodyTD.innerHTML = person.name + “” + person.age + “”;
            should be:
            bodyTD.innerHTML = person.name + span class = … + person.age + /span;
            can’t send html tags here ? how i have to escape them here ?
              sdetweil @Perlchamp
              @Perlchamp cannot escape tags here, long time complaint
              • PerlchampP
                Perlchamp
                did it !
                this.loaded = true; was wrong placed …
                • PerlchampP
                  Perlchamp
                  but this does not work yet:
                  		    if (birthday.charAt(0) === "0") {
                  			birthday = birthday.replace("0","");
                  			birthday = birthday.substring(0,1);
                  		    bodyTDimage.innerHTML = birthday.substring(0,2);
                  the value will not displayed, but i will find a way. my code yet is far away from a smart code :-))
                  • PerlchampP
                    Perlchamp
                    this is the status at the moment :
                      sdetweil @Perlchamp
                      @Perlchamp cool… do you want ages aligned?
                      • PerlchampP
                        Perlchamp
                        yes, of course, sir …
                          sdetweil @Perlchamp
                          @Perlchamp need to specify width of td
                          By default, a browser will adjust table columns to fit the contents of the table. However, if you want to control the width of each column, you can do so by adjusting the width of each or of a single row.
                          if you had th, then you could see the length of the names as they go by, and then adjust the th width before sending the content to MM…
                          • PerlchampP
                            Perlchamp
                            width:27px; is placed in css
                            but this:
                            //bodyTDimage.id = "birthday-td-image";
                            works. i really have to write html-text in the module-file ?
                              sdetweil @Perlchamp
                              @Perlchamp eh? commenting out a line?
                              have a th is the same as what you have document.createElement(“th”)
                              • PerlchampP
                                Perlchamp
                                wrong line, moment:
                                //bodyTDimage.className = "td-image";
                                this works, but unformatted, of course
                                i don’t like things like:
                                innerHTLM = tags, tags, tags …
                                  sdetweil @Perlchamp
                                  @Perlchamp eh? where is that?
                                  • PerlchampP
                                    Perlchamp
                                    getDom:
                                        getDom: function() {
                                    	var self = this;
                                    	// tell MM to call and get our content
                                    	Log.log(JSON.stringify(this.active_birthdays))
                                    	if ((moment() > this.midnight) || (!this.loaded)) {
                                    	    var month = moment().month();
                                    	    var year = moment().year();
                                    	    var monthName = moment().format("MMMM");
                                    	    var monthLength = moment().daysInMonth();
                                    	    // create table
                                    	    var wrapper = document.createElement("table");
                                    	    wrapper.className = 'table';
                                    	    wrapper.id = 'birthday-table';
                                    	    // create header
                                    	    var tHeader = document.createElement("thead");
                                    	    tHeader.className = "thead";
                                    	    tHeader.id = "birthday-thead";
                                    	    var headerTR = document.createElement("tr");
                                    	    headerTR.className = "tr-head";
                                    	    headerTR.id = "birthday-tr-head";
                                    	    var headerTH = document.createElement("th");
                                    	    headerTH.colSpan = "2";
                                    	    headerTH.scope = "col";
                                    	    headerTH.className = "th-head";
                                    	    headerTH.id = "birthday-th-head";
                                    	    headerTH.innerHTML = "&nbsp;";
                                    	    headerTR.appendChild(headerTH);
                                    	    tHeader.appendChild(headerTR);
                                    	    wrapper.appendChild(tHeader);
                                    	    // Create TFOOT section -- currently used for debugging only
                                    	    var tFooter = document.createElement('tfoot');
                                    	    tFooter.className = "tfoot";
                                    	    tFooter.id = "birthday-tfoot";
                                    	    var footerTR = document.createElement("tr");
                                    	    footerTR.className = "tr-foot";
                                    	    footerTR.id = "birthday-tr-foot";
                                    	    var footerTD = document.createElement("td");
                                    	    footerTD.colSpan ="2";
                                    	    footerTD.className = "td-foot";
                                    	    footerTD.id = "birthday-td-foot";
                                    	    if (this.config.debugging) {
                                    		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
                                    	    else {
                                    		footerTD.innerHTML = "&nbsp;";
                                    	    footerTR.appendChild(footerTD);
                                    	    tFooter.appendChild(footerTR);
                                    	    wrapper.appendChild(tFooter);
                                    		    bodyTDimage.innerText = birthday.substring(0,2);
                                    		    bodyTD.innerHTML = person.name + "&nbsp;&nbsp;&nbsp;<span class=\"age-span\">" + person.age + "</span>";
                                    	    // pass the created content back to MM to add to DOM.
                                    	    return wrapper;
                                    	this.loaded = true;
                                    //		var bodyAgeSpan = document.createElement("span");
                                    //		bodyAgeSpan.className = "age-span";
                                    //		bodyAgeSpan.id = "birthday-age-span";
                                    //		bodyAgeSpan.innerHTML = "&nbsp;&nbsp;46";
                                    //		bodyTD.appendChild(bodyAgeSpan);
                                      sdetweil @Perlchamp
                                      @Perlchamp fiddling with it here… technically you are supposed to have a text element as a child of the td
                                      < table>
                                         < tr>
                                            < td> value < /td>
                                      var n = document.createTextNode(value);
                                        @Perlchamp
                                        			   // bodyTR.className = "tr-body";
                                        			   // bodyTDimage.className = "td-image";
                                        			   // bodyTDimage.innerHTML = birthday;
                                        			    bodyTDimage.appendChild(document.createTextNode(birthday));
                                        			   // bodyTD.className = "td-body";
                                        			   // bodyTD.innerTEXT = person.name ;
                                        				bodyTD.appendChild(document.createTextNode(person.name));
                                        				var ageTD = document.createElement("td");
                                        			    ageTD.id = "birthday-td-age";
                                        			    //ageTD.innerTEXT = person.age ;
                                        			    ageTD.appendChild(document.createTextNode(person.age));
                                        			    bodyTR.appendChild(ageTD);
                                        and set the class for the text element
                                        • PerlchampP
                                          Perlchamp
                                          you were too fast !!
                                          to your information:
                                          table needs a header (thead, tr, th) and a footer (tfoot, tr, td), and, of
                                          course a boda (tbody, tr, td), my cose, where a put html-tags in the table and text without variable works fine.
                                          but later, if i should dissapointed, i will try this.
                                            sdetweil @Perlchamp
                                            @Perlchamp >where a put html-tags in the table
                                            its exactly the same as writing the html
                                            they don’t NEED a thead/tfoot, these are optional
                                            you could create a big text string of the html < table>… < /table>
                                            and then assign that text string to the wrapper div innerHTML.
                                            same result…
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
