    read csv-data and put it in an array
    313 Posts 3 Posters 590.2k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp eh? where is that?
      • PerlchampP
        Perlchamp
        getDom:
            getDom: function() {
        	var self = this;
        	// tell MM to call and get our content
        	Log.log(JSON.stringify(this.active_birthdays))
        	if ((moment() > this.midnight) || (!this.loaded)) {
        	    var month = moment().month();
        	    var year = moment().year();
        	    var monthName = moment().format("MMMM");
        	    var monthLength = moment().daysInMonth();
        	    // create table
        	    var wrapper = document.createElement("table");
        	    wrapper.className = 'table';
        	    wrapper.id = 'birthday-table';
        	    // create header
        	    var tHeader = document.createElement("thead");
        	    tHeader.className = "thead";
        	    tHeader.id = "birthday-thead";
        	    var headerTR = document.createElement("tr");
        	    headerTR.className = "tr-head";
        	    headerTR.id = "birthday-tr-head";
        	    var headerTH = document.createElement("th");
        	    headerTH.colSpan = "2";
        	    headerTH.scope = "col";
        	    headerTH.className = "th-head";
        	    headerTH.id = "birthday-th-head";
        	    headerTH.innerHTML = " ";
        	    headerTR.appendChild(headerTH);
        	    tHeader.appendChild(headerTR);
        	    wrapper.appendChild(tHeader);
        	    // Create TFOOT section -- currently used for debugging only
        	    var tFooter = document.createElement('tfoot');
        	    tFooter.className = "tfoot";
        	    tFooter.id = "birthday-tfoot";
        	    var footerTR = document.createElement("tr");
        	    footerTR.className = "tr-foot";
        	    footerTR.id = "birthday-tr-foot";
        	    var footerTD = document.createElement("td");
        	    footerTD.colSpan ="2";
        	    footerTD.className = "td-foot";
        	    footerTD.id = "birthday-td-foot";
        	    if (this.config.debugging) {
        		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
        	    else {
        		footerTD.innerHTML = "&nbsp;";
        	    footerTR.appendChild(footerTD);
        	    tFooter.appendChild(footerTR);
        	    wrapper.appendChild(tFooter);
        	    // create TBODY section with day names
        	    var tBody = document.createElement("tBody");
        	    tBody.className = "tbody";
        	    tBody.id = "birthday-tbody";
        	    for(var birthday of Object.keys(this.active_birthdays)) {
        		for(var person of this.active_birthdays[birthday]) {
        		    //var m = document.createElement('div');
        		    // create looped row section
        		    var bodyTR = document.createElement("tr");
        		    bodyTR.className = "tr-body";
        		    bodyTR.id = "birthday-tr-body";
        		    var bodyTDimage = document.createElement("td");
        		    //bodyTDimage.className = "td-image";
        		    bodyTDimage.id = "birthday-td-image";
        		    if (birthday.charAt(0) === "0") {
        			birthday = birthday.replace("0","");
        			birthday = birthday.substring(0,1);
        		    bodyTDimage.innerText = birthday.substring(0,2);
        		    var bodyTD = document.createElement("td");
        		    bodyTD.className = "td-body";
        		    bodyTD.id = "birthday-td-body";
        		    bodyTD.innerHTML = person.name + "&nbsp;&nbsp;&nbsp;<span class=\"age-span\">" + person.age + "</span>";
        		    //m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
        		    //wrapper.appendChild(m);
        		    bodyTR.appendChild(bodyTDimage);
        		    bodyTR.appendChild(bodyTD);
        		    tBody.appendChild(bodyTR);
        		    wrapper.appendChild(tBody);
        	    // pass the created content back to MM to add to DOM.
        	    return wrapper;
        	this.loaded = true;
        //		var bodyAgeSpan = document.createElement("span");
        //		bodyAgeSpan.className = "age-span";
        //		bodyAgeSpan.id = "birthday-age-span";
        //		bodyAgeSpan.innerHTML = "&nbsp;&nbsp;46";
        //		bodyTD.appendChild(bodyAgeSpan);
          sdetweil @Perlchamp
          @Perlchamp fiddling with it here… technically you are supposed to have a text element as a child of the td
          < table>
             < tr>
                < td> value < /td>
          var n = document.createTextNode(value);
            @Perlchamp
            			   // bodyTR.className = "tr-body";
            			   // bodyTDimage.className = "td-image";
            			   // bodyTDimage.innerHTML = birthday;
            			    bodyTDimage.appendChild(document.createTextNode(birthday));
            			   // bodyTD.className = "td-body";
            			   // bodyTD.innerTEXT = person.name ;
            				bodyTD.appendChild(document.createTextNode(person.name));
            				var ageTD = document.createElement("td");
            			    ageTD.id = "birthday-td-age";
            			    //ageTD.innerTEXT = person.age ;
            			    ageTD.appendChild(document.createTextNode(person.age));
            			    bodyTR.appendChild(ageTD);
            and set the class for the text element
            • PerlchampP
              Perlchamp
              you were too fast !!
              to your information:
              table needs a header (thead, tr, th) and a footer (tfoot, tr, td), and, of
              course a boda (tbody, tr, td), my cose, where a put html-tags in the table and text without variable works fine.
              but later, if i should dissapointed, i will try this.
                sdetweil @Perlchamp
                @Perlchamp >where a put html-tags in the table
                its exactly the same as writing the html
                they don’t NEED a thead/tfoot, these are optional
                you could create a big text string of the html < table>… < /table>
                and then assign that text string to the wrapper div innerHTML.
                same result…
                  @sdetweil when I had a big pile of html objects to create I wrote a little routine to hide the 4 lines per object
                  createEl(type, id, class, parent){
                     var el = document.createElement(type)
                     el.id=id
                     if(class)
                       el.classname=class
                     parent.addChild(el)
                     return el
                  then to use
                      var table= this.createEl('table', "birthday-tbody", null , wrapper)
                              etc
                              etc
                  • PerlchampP
                    Perlchamp
                    in the moment you’re too fast for me …
                    this code is from the test-module:
                    	    // tabelle erstellen
                    	    // tabellenkopf erstellen
                    	    headerTH.innerHTML = this.translate(this.config.title);
                    	    else {
                    		footerTD.innerHTML = "";
                    	    // Create TBODY section with day names
                    	    var eintraege = 3;
                    	    for (var i=1; i<=eintraege; i++) {
                    		bodyTDimage.innerHTML = "23";
                    		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;<span class=\"age-span\">46</span></br>Frank Dubiel&nbsp;&nbsp;<span class=\"age-span\">54</span></br>Jürgen Gruse&nbsp;&nbsp;<span class=\"age-span\">52</span>";
                    	    this.loaded = true;
                    	    return wrapper;
                    and looks like :
                      sdetweil @Perlchamp
                      @Perlchamp ok, so you WANT a title, header and footer…
                      still no different than an actual table in all html
                      by using document.creatElement and appendChild() there are no close tags to create
                      a td is a closed thing you add text to a td…
                      with my little helper routine, you write exactly what you would have written in html
                      and can indent/outdent to match for readability
                        @Perlchamp maybe a nunjuks template , but its the same work to create the template the generate the content
                        the template has to have all the same stuff you are doing, including the loop part
                        • PerlchampP
                          Perlchamp
                            sdetweil @Perlchamp
                            @Perlchamp said in read csv-data and put it in an array:
                            sorry sam, but my code is displayed wrong ! what in hell …
                            the tbody section:
                            any < must have a space after it to display on the forum… no way to escape them yet…
                            no real work from site admin on problem
                            • PerlchampP
                              Perlchamp
                                  // Override dom generator.
                              	    else {
                              	    var eintraege = 3;
                              	    for (var i=1; i< =eintraege; i++) {
                              		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;< span class=\"age-span\"> 46 < /span > < /br > Frank Dubiel&nbsp;&nbsp; < span class=\"age-span\" > 54 < /span > < /br >Jürgen Gruse&nbsp;&nbsp; < span class=\"age-span\" > 52 < /span > ";
                              	    this.loaded = true;
                              	    return wrapper;
                              this code looks like the image i did send before
                              • PerlchampP
                                Perlchamp
                                @sdetweil said in read csv-data and put it in an array:
                                i will shurely take this, if my current html should work. now it’s too much “risk” for me, to change it.
                                  sdetweil @Perlchamp
                                  @Perlchamp yep… and you could use divs(as row) and spans(as column) for the table, instead of table/tr/td
                                  https://html-cleaner.com/features/replace-html-table-tags-with-divs/
                                    sdetweil @Perlchamp
                                    @Perlchamp cool thing about the routine, if u decide to use div/span under instead is to fix the routine,
                                    no mainline code has to change
                                    • PerlchampP
                                      Perlchamp
                                      i don’t think so. therefor i’m a little bit toooooooo retro ;-)
                                        sdetweil @Perlchamp
                                        @Perlchamp each to their own!..
                                        • PerlchampP
                                          Perlchamp
                                          if i do this :
                                          it looks like:
                                          and i ask me, WHY css is not working only for this cell !!
                                            sdetweil @Perlchamp
                                            @Perlchamp td has a class, you are overriding it…
                                            you want that class on the text in the td, not the td itself…
                                            table, th, tr, all have classes… you can ADD a class instead of SET a class
                                            += adds to
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
