    read csv-data and put it in an array
    313 Posts 3 Posters 546.7k Views 4 Watching
    • PerlchampP Offline
      Perlchamp
      did it !
      this.loaded = true; was wrong placed …
        Perlchamp
        but this does not work yet:
        		    var bodyTDimage = document.createElement("td");
        		    bodyTDimage.className = "td-image";
        		    bodyTDimage.id = "birthday-td-image";
        		    if (birthday.charAt(0) === "0") {
        			birthday = birthday.replace("0","");
        			birthday = birthday.substring(0,1);
        		    bodyTDimage.innerHTML = birthday.substring(0,2);
        the value will not displayed, but i will find a way. my code yet is far away from a smart code :-))
          Perlchamp
          this is the status at the moment :
            sdetweil @Perlchamp
            @Perlchamp cool… do you want ages aligned?
              Perlchamp
              yes, of course, sir …
                sdetweil @Perlchamp
                @Perlchamp need to specify width of td
                By default, a browser will adjust table columns to fit the contents of the table. However, if you want to control the width of each column, you can do so by adjusting the width of each or of a single row.
                if you had th, then you could see the length of the names as they go by, and then adjust the th width before sending the content to MM…
                  Perlchamp
                  width:27px; is placed in css
                  but this:
                  //bodyTDimage.id = "birthday-td-image";
                  works. i really have to write html-text in the module-file ?
                    sdetweil @Perlchamp
                    @Perlchamp eh? commenting out a line?
                    have a th is the same as what you have document.createElement(“th”)
                      Perlchamp
                      wrong line, moment:
                      //bodyTDimage.className = "td-image";
                      this works, but unformatted, of course
                      i don’t like things like:
                      innerHTLM = tags, tags, tags …
                        sdetweil @Perlchamp
                        @Perlchamp eh? where is that?
                          Perlchamp
                          getDom:
                              getDom: function() {
                          	var self = this;
                          	// tell MM to call and get our content
                          	Log.log(JSON.stringify(this.active_birthdays))
                          	if ((moment() > this.midnight) || (!this.loaded)) {
                          	    var month = moment().month();
                          	    var year = moment().year();
                          	    var monthName = moment().format("MMMM");
                          	    var monthLength = moment().daysInMonth();
                          	    // create table
                          	    var wrapper = document.createElement("table");
                          	    wrapper.className = 'table';
                          	    wrapper.id = 'birthday-table';
                          	    // create header
                          	    var tHeader = document.createElement("thead");
                          	    tHeader.className = "thead";
                          	    tHeader.id = "birthday-thead";
                          	    var headerTR = document.createElement("tr");
                          	    headerTR.className = "tr-head";
                          	    headerTR.id = "birthday-tr-head";
                          	    var headerTH = document.createElement("th");
                          	    headerTH.colSpan = "2";
                          	    headerTH.scope = "col";
                          	    headerTH.className = "th-head";
                          	    headerTH.id = "birthday-th-head";
                          	    headerTH.innerHTML = " ";
                          	    headerTR.appendChild(headerTH);
                          	    tHeader.appendChild(headerTR);
                          	    wrapper.appendChild(tHeader);
                          	    // Create TFOOT section -- currently used for debugging only
                          	    var tFooter = document.createElement('tfoot');
                          	    tFooter.className = "tfoot";
                          	    tFooter.id = "birthday-tfoot";
                          	    var footerTR = document.createElement("tr");
                          	    footerTR.className = "tr-foot";
                          	    footerTR.id = "birthday-tr-foot";
                          	    var footerTD = document.createElement("td");
                          	    footerTD.colSpan ="2";
                          	    footerTD.className = "td-foot";
                          	    footerTD.id = "birthday-td-foot";
                          	    if (this.config.debugging) {
                          		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
                          	    else {
                          		footerTD.innerHTML = "&nbsp;";
                          	    footerTR.appendChild(footerTD);
                          	    tFooter.appendChild(footerTR);
                          	    wrapper.appendChild(tFooter);
                          	    // create TBODY section with day names
                          	    var tBody = document.createElement("tBody");
                          	    tBody.className = "tbody";
                          	    tBody.id = "birthday-tbody";
                          	    for(var birthday of Object.keys(this.active_birthdays)) {
                          		for(var person of this.active_birthdays[birthday]) {
                          		    //var m = document.createElement('div');
                          		    // create looped row section
                          		    var bodyTR = document.createElement("tr");
                          		    bodyTR.className = "tr-body";
                          		    bodyTR.id = "birthday-tr-body";
                          		    bodyTDimage.innerText = birthday.substring(0,2);
                          		    var bodyTD = document.createElement("td");
                          		    bodyTD.className = "td-body";
                          		    bodyTD.id = "birthday-td-body";
                          		    bodyTD.innerHTML = person.name + "&nbsp;&nbsp;&nbsp;<span class=\"age-span\">" + person.age + "</span>";
                          		    //m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
                          		    //wrapper.appendChild(m);
                          		    bodyTR.appendChild(bodyTDimage);
                          		    bodyTR.appendChild(bodyTD);
                          		    tBody.appendChild(bodyTR);
                          		    wrapper.appendChild(tBody);
                          	    // pass the created content back to MM to add to DOM.
                          	    return wrapper;
                          	this.loaded = true;
                          //		var bodyAgeSpan = document.createElement("span");
                          //		bodyAgeSpan.className = "age-span";
                          //		bodyAgeSpan.id = "birthday-age-span";
                          //		bodyAgeSpan.innerHTML = "&nbsp;&nbsp;46";
                          //		bodyTD.appendChild(bodyAgeSpan);
                            sdetweil @Perlchamp
                            @Perlchamp fiddling with it here… technically you are supposed to have a text element as a child of the td
                            < table>
                               < tr>
                                  < td> value < /td>
                            var n = document.createTextNode(value);
                              @Perlchamp
                              			   // bodyTR.className = "tr-body";
                              			   // bodyTDimage.className = "td-image";
                              			   // bodyTDimage.innerHTML = birthday;
                              			    bodyTDimage.appendChild(document.createTextNode(birthday));
                              			   // bodyTD.className = "td-body";
                              			   // bodyTD.innerTEXT = person.name ;
                              				bodyTD.appendChild(document.createTextNode(person.name));
                              				var ageTD = document.createElement("td");
                              			    ageTD.id = "birthday-td-age";
                              			    //ageTD.innerTEXT = person.age ;
                              			    ageTD.appendChild(document.createTextNode(person.age));
                              			    bodyTR.appendChild(ageTD);
                              and set the class for the text element
                                Perlchamp
                                you were too fast !!
                                to your information:
                                table needs a header (thead, tr, th) and a footer (tfoot, tr, td), and, of
                                course a boda (tbody, tr, td), my cose, where a put html-tags in the table and text without variable works fine.
                                but later, if i should dissapointed, i will try this.
                                  sdetweil @Perlchamp
                                  @Perlchamp >where a put html-tags in the table
                                  its exactly the same as writing the html
                                  they don’t NEED a thead/tfoot, these are optional
                                  you could create a big text string of the html < table>… < /table>
                                  and then assign that text string to the wrapper div innerHTML.
                                  same result…
                                    @sdetweil when I had a big pile of html objects to create I wrote a little routine to hide the 4 lines per object
                                    createEl(type, id, class, parent){
                                       var el = document.createElement(type)
                                       el.id=id
                                       if(class)
                                         el.classname=class
                                       parent.addChild(el)
                                       return el
                                    then to use
                                        var table= this.createEl('table', "birthday-tbody", null , wrapper)
                                                etc
                                                etc
                                      Perlchamp
                                      in the moment you’re too fast for me …
                                      this code is from the test-module:
                                      	    // tabelle erstellen
                                      	    // tabellenkopf erstellen
                                      	    headerTH.innerHTML = this.translate(this.config.title);
                                      	    else {
                                      		footerTD.innerHTML = "";
                                      	    // Create TBODY section with day names
                                      	    var eintraege = 3;
                                      	    for (var i=1; i<=eintraege; i++) {
                                      		bodyTDimage.innerHTML = "23";
                                      		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;<span class=\"age-span\">46</span></br>Frank Dubiel&nbsp;&nbsp;<span class=\"age-span\">54</span></br>Jürgen Gruse&nbsp;&nbsp;<span class=\"age-span\">52</span>";
                                      	    this.loaded = true;
                                      	    return wrapper;
                                      and looks like :
                                        sdetweil @Perlchamp
                                        @Perlchamp ok, so you WANT a title, header and footer…
                                        still no different than an actual table in all html
                                        by using document.creatElement and appendChild() there are no close tags to create
                                        a td is a closed thing you add text to a td…
                                        with my little helper routine, you write exactly what you would have written in html
                                        and can indent/outdent to match for readability
                                          @Perlchamp maybe a nunjuks template , but its the same work to create the template the generate the content
                                          the template has to have all the same stuff you are doing, including the loop part
                                            Perlchamp
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
