    read csv-data and put it in an array
    313 Posts 3 Posters 590.4k Views 4 Watching
    • PerlchampP
      Perlchamp
      getDom:
          getDom: function() {
      	var self = this;
      	// tell MM to call and get our content
      	Log.log(JSON.stringify(this.active_birthdays))
      	if ((moment() > this.midnight) || (!this.loaded)) {
      	    var month = moment().month();
      	    var year = moment().year();
      	    var monthName = moment().format("MMMM");
      	    var monthLength = moment().daysInMonth();
      	    // create table
      	    var wrapper = document.createElement("table");
      	    wrapper.className = 'table';
      	    wrapper.id = 'birthday-table';
      	    // create header
      	    var tHeader = document.createElement("thead");
      	    tHeader.className = "thead";
      	    tHeader.id = "birthday-thead";
      	    var headerTR = document.createElement("tr");
      	    headerTR.className = "tr-head";
      	    headerTR.id = "birthday-tr-head";
      	    var headerTH = document.createElement("th");
      	    headerTH.colSpan = "2";
      	    headerTH.scope = "col";
      	    headerTH.className = "th-head";
      	    headerTH.id = "birthday-th-head";
      	    headerTH.innerHTML = " ";
      	    headerTR.appendChild(headerTH);
      	    tHeader.appendChild(headerTR);
      	    wrapper.appendChild(tHeader);
      	    // Create TFOOT section -- currently used for debugging only
      	    var tFooter = document.createElement('tfoot');
      	    tFooter.className = "tfoot";
      	    tFooter.id = "birthday-tfoot";
      	    var footerTR = document.createElement("tr");
      	    footerTR.className = "tr-foot";
      	    footerTR.id = "birthday-tr-foot";
      	    var footerTD = document.createElement("td");
      	    footerTD.colSpan ="2";
      	    footerTD.className = "td-foot";
      	    footerTD.id = "birthday-td-foot";
      	    if (this.config.debugging) {
      		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
      	    else {
      		footerTD.innerHTML = "&nbsp;";
      	    footerTR.appendChild(footerTD);
      	    tFooter.appendChild(footerTR);
      	    wrapper.appendChild(tFooter);
      	    // create TBODY section with day names
      	    var tBody = document.createElement("tBody");
      	    tBody.className = "tbody";
      	    tBody.id = "birthday-tbody";
      	    for(var birthday of Object.keys(this.active_birthdays)) {
      		for(var person of this.active_birthdays[birthday]) {
      		    //var m = document.createElement('div');
      		    // create looped row section
      		    var bodyTR = document.createElement("tr");
      		    bodyTR.className = "tr-body";
      		    bodyTR.id = "birthday-tr-body";
      		    var bodyTDimage = document.createElement("td");
      		    //bodyTDimage.className = "td-image";
      		    bodyTDimage.id = "birthday-td-image";
      		    if (birthday.charAt(0) === "0") {
      			birthday = birthday.replace("0","");
      			birthday = birthday.substring(0,1);
      		    bodyTDimage.innerText = birthday.substring(0,2);
      		    var bodyTD = document.createElement("td");
      		    bodyTD.className = "td-body";
      		    bodyTD.id = "birthday-td-body";
      		    bodyTD.innerHTML = person.name + "&nbsp;&nbsp;&nbsp;<span class=\"age-span\">" + person.age + "</span>";
      		    //m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
      		    //wrapper.appendChild(m);
      		    bodyTR.appendChild(bodyTDimage);
      		    bodyTR.appendChild(bodyTD);
      		    tBody.appendChild(bodyTR);
      		    wrapper.appendChild(tBody);
      	    // pass the created content back to MM to add to DOM.
      	    return wrapper;
      	this.loaded = true;
      //		var bodyAgeSpan = document.createElement("span");
      //		bodyAgeSpan.className = "age-span";
      //		bodyAgeSpan.id = "birthday-age-span";
      //		bodyAgeSpan.innerHTML = "&nbsp;&nbsp;46";
      //		bodyTD.appendChild(bodyAgeSpan);
        sdetweil @Perlchamp
        @Perlchamp fiddling with it here… technically you are supposed to have a text element as a child of the td
        < table>
           < tr>
              < td> value < /td>
        var n = document.createTextNode(value);
          @Perlchamp
          			   // bodyTR.className = "tr-body";
          			   // bodyTDimage.className = "td-image";
          			   // bodyTDimage.innerHTML = birthday;
          			    bodyTDimage.appendChild(document.createTextNode(birthday));
          			   // bodyTD.className = "td-body";
          			   // bodyTD.innerTEXT = person.name ;
          				bodyTD.appendChild(document.createTextNode(person.name));
          				var ageTD = document.createElement("td");
          			    ageTD.id = "birthday-td-age";
          			    //ageTD.innerTEXT = person.age ;
          			    ageTD.appendChild(document.createTextNode(person.age));
          			    bodyTR.appendChild(ageTD);
          and set the class for the text element
          • PerlchampP
            Perlchamp
            you were too fast !!
            to your information:
            table needs a header (thead, tr, th) and a footer (tfoot, tr, td), and, of
            course a boda (tbody, tr, td), my cose, where a put html-tags in the table and text without variable works fine.
            but later, if i should dissapointed, i will try this.
              sdetweil @Perlchamp
              @Perlchamp >where a put html-tags in the table
              its exactly the same as writing the html
              they don’t NEED a thead/tfoot, these are optional
              you could create a big text string of the html < table>… < /table>
              and then assign that text string to the wrapper div innerHTML.
              same result…
                @sdetweil when I had a big pile of html objects to create I wrote a little routine to hide the 4 lines per object
                createEl(type, id, class, parent){
                   var el = document.createElement(type)
                   el.id=id
                   if(class)
                     el.classname=class
                   parent.addChild(el)
                   return el
                then to use
                    var table= this.createEl('table', "birthday-tbody", null , wrapper)
                            etc
                            etc
                • PerlchampP
                  Perlchamp
                  in the moment you’re too fast for me …
                  this code is from the test-module:
                  	    // tabelle erstellen
                  	    // tabellenkopf erstellen
                  	    headerTH.innerHTML = this.translate(this.config.title);
                  	    else {
                  		footerTD.innerHTML = "";
                  	    // Create TBODY section with day names
                  	    var eintraege = 3;
                  	    for (var i=1; i<=eintraege; i++) {
                  		bodyTDimage.innerHTML = "23";
                  		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;<span class=\"age-span\">46</span></br>Frank Dubiel&nbsp;&nbsp;<span class=\"age-span\">54</span></br>Jürgen Gruse&nbsp;&nbsp;<span class=\"age-span\">52</span>";
                  	    this.loaded = true;
                  	    return wrapper;
                  and looks like :
                    sdetweil @Perlchamp
                    @Perlchamp ok, so you WANT a title, header and footer…
                    still no different than an actual table in all html
                    by using document.creatElement and appendChild() there are no close tags to create
                    a td is a closed thing you add text to a td…
                    with my little helper routine, you write exactly what you would have written in html
                    and can indent/outdent to match for readability
                      @Perlchamp maybe a nunjuks template , but its the same work to create the template the generate the content
                      the template has to have all the same stuff you are doing, including the loop part
                      • PerlchampP
                        Perlchamp
                          sdetweil @Perlchamp
                          @Perlchamp said in read csv-data and put it in an array:
                          sorry sam, but my code is displayed wrong ! what in hell …
                          the tbody section:
                          any < must have a space after it to display on the forum… no way to escape them yet…
                          no real work from site admin on problem
                          • PerlchampP
                            Perlchamp
                                // Override dom generator.
                            	    else {
                            	    var eintraege = 3;
                            	    for (var i=1; i< =eintraege; i++) {
                            		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;< span class=\"age-span\"> 46 < /span > < /br > Frank Dubiel&nbsp;&nbsp; < span class=\"age-span\" > 54 < /span > < /br >Jürgen Gruse&nbsp;&nbsp; < span class=\"age-span\" > 52 < /span > ";
                            	    this.loaded = true;
                            	    return wrapper;
                            this code looks like the image i did send before
                            • PerlchampP
                              Perlchamp
                              @sdetweil said in read csv-data and put it in an array:
                              i will shurely take this, if my current html should work. now it’s too much “risk” for me, to change it.
                                sdetweil @Perlchamp
                                @Perlchamp yep… and you could use divs(as row) and spans(as column) for the table, instead of table/tr/td
                                https://html-cleaner.com/features/replace-html-table-tags-with-divs/
                                  sdetweil @Perlchamp
                                  @Perlchamp cool thing about the routine, if u decide to use div/span under instead is to fix the routine,
                                  no mainline code has to change
                                  • PerlchampP
                                    Perlchamp
                                    i don’t think so. therefor i’m a little bit toooooooo retro ;-)
                                      sdetweil @Perlchamp
                                      @Perlchamp each to their own!..
                                      • PerlchampP
                                        Perlchamp
                                        if i do this :
                                        it looks like:
                                        and i ask me, WHY css is not working only for this cell !!
                                          sdetweil @Perlchamp
                                          @Perlchamp td has a class, you are overriding it…
                                          you want that class on the text in the td, not the td itself…
                                          table, th, tr, all have classes… you can ADD a class instead of SET a class
                                          += adds to
                                          • PerlchampP
                                            Perlchamp
                                            but the other cell (name plus age) works, WHY ?
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
