    read csv-data and put it in an array
    313 Posts 3 Posters 552.7k Views 4 Watching
      @Perlchamp maybe a nunjuks template , but its the same work to create the template the generate the content
      the template has to have all the same stuff you are doing, including the loop part
      • PerlchampP Offline
        Perlchamp
          sdetweil @Perlchamp
          @Perlchamp said in read csv-data and put it in an array:
          sorry sam, but my code is displayed wrong ! what in hell …
          the tbody section:
          any < must have a space after it to display on the forum… no way to escape them yet…
          no real work from site admin on problem
            Perlchamp
                // Override dom generator.
                getDom: function() {
            	if ((moment() > this.midnight) || (!this.loaded)) {
            	    var month = moment().month();
            	    var year = moment().year();
            	    var monthName = moment().format("MMMM");
            	    var monthLength = moment().daysInMonth();
            	    // tabelle erstellen
            	    var wrapper = document.createElement("table");
            	    wrapper.className = 'table';
            	    wrapper.id = 'birthday-table';
            	    // tabellenkopf erstellen
            	    var tHeader = document.createElement("thead");
            	    tHeader.className = "thead";
            	    tHeader.id = "birthday-thead";
            	    var headerTR = document.createElement("tr");
            	    headerTR.className = "tr-head";
            	    headerTR.id = "birthday-tr-head";
            	    var headerTH = document.createElement("th");
            	    headerTH.colSpan = "2";
            	    headerTH.scope = "col";
            	    headerTH.className = "th-head";
            	    headerTH.id = "birthday-th-head";
            	    headerTH.innerHTML = this.translate(this.config.title);
            	    headerTR.appendChild(headerTH);
            	    tHeader.appendChild(headerTR);
            	    wrapper.appendChild(tHeader);
            	    // Create TFOOT section -- currently used for debugging only
            	    var tFooter = document.createElement('tfoot');
            	    tFooter.className = "tfoot";
            	    tFooter.id = "birthday-tfoot";
            	    var footerTR = document.createElement("tr");
            	    footerTR.className = "tr-foot";
            	    footerTR.id = "birthday-tr-foot";
            	    var footerTD = document.createElement("td");
            	    footerTD.colSpan ="2";
            	    footerTD.className = "td-foot";
            	    footerTD.id = "birthday-td-foot";
            	    if (this.config.debugging) {
            		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
            	    else {
            		footerTD.innerHTML = "";
            	    footerTR.appendChild(footerTD);
            	    tFooter.appendChild(footerTR);
            	    wrapper.appendChild(tFooter);
            	    // Create TBODY section with day names
            	    var eintraege = 3;
            	    for (var i=1; i< =eintraege; i++) {
            		var tBody = document.createElement("tBody");
            		tBody.className = "tbody";
            		tBody.id = "birthday-tbody";
            		var bodyTR = document.createElement("tr");
            		bodyTR.className = "tr-body";
            		bodyTR.id = "birthday-tr-body";
            		var bodyTDimage = document.createElement("td");
            		bodyTDimage.className = "td-image";
            		bodyTDimage.id = "birthday-td-image";
            		bodyTDimage.innerHTML = "23";
            		var bodyTD = document.createElement("td");
            		bodyTD.className = "td-body";
            		bodyTD.id = "birthday-td-body";
            		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;< span class=\"age-span\"> 46 < /span > < /br > Frank Dubiel&nbsp;&nbsp; < span class=\"age-span\" > 54 < /span > < /br >Jürgen Gruse&nbsp;&nbsp; < span class=\"age-span\" > 52 < /span > ";
            		var bodyAgeSpan = document.createElement("span");
            		bodyAgeSpan.className = "age-span";
            		bodyAgeSpan.id = "birthday-age-span";
            		bodyAgeSpan.innerHTML = "&nbsp;&nbsp;46";
            		bodyTD.appendChild(bodyAgeSpan);
            		bodyTR.appendChild(bodyTDimage);
            		bodyTR.appendChild(bodyTD);
            		tBody.appendChild(bodyTR);
            		wrapper.appendChild(tBody);
            	    this.loaded = true;
            	    return wrapper;
            this code looks like the image i did send before
              Perlchamp
              @sdetweil said in read csv-data and put it in an array:
              when I had a big pile of html objects to create I wrote a little routine to hide the 4 lines per object
              i will shurely take this, if my current html should work. now it’s too much “risk” for me, to change it.
                sdetweil @Perlchamp
                @Perlchamp yep… and you could use divs(as row) and spans(as column) for the table, instead of table/tr/td
                https://html-cleaner.com/features/replace-html-table-tags-with-divs/
                  sdetweil @Perlchamp
                  @Perlchamp cool thing about the routine, if u decide to use div/span under instead is to fix the routine,
                  no mainline code has to change
                    Perlchamp
                    i don’t think so. therefor i’m a little bit toooooooo retro ;-)
                      sdetweil @Perlchamp
                      @Perlchamp each to their own!..
                        Perlchamp
                        if i do this :
                        //bodyTDimage.className = "td-image";
                        it looks like:
                        and i ask me, WHY css is not working only for this cell !!
                          sdetweil @Perlchamp
                          @Perlchamp td has a class, you are overriding it…
                          you want that class on the text in the td, not the td itself…
                          table, th, tr, all have classes… you can ADD a class instead of SET a class
                          += adds to
                            Perlchamp
                            but the other cell (name plus age) works, WHY ?
                              sdetweil @Perlchamp
                              @Perlchamp not a css class wizard
                                Perlchamp
                                no i don’t override the general td-class, cause i use:
                                .modulname .classname
                                font: 16px;
                                  sdetweil @Perlchamp
                                  @Perlchamp but you SET the ONLY classname to be yours… classame=
                                  wipes out what was there
                                  you do not append yours to the list of classNames already assigned className +=
                                    Perlchamp
                                    ok, i will try
                                      Perlchamp
                                      doesn’t work either
                                        sdetweil @Perlchamp
                                        @Perlchamp bummer
                                          Perlchamp
                                          where i have to place it ?
                                          sam, take my going code and see by yourself. here is the css:
                                          .birthdaylist .app {
                                              width: 200px;
                                              padding: 0px;
                                          .birthdaylist .table {
                                            padding: 0px;
                                            margin: 0px;
                                            border: 1px solid white;
                                            width: 200px;
                                          .birthdaylist .thead {
                                          .birthdaylist .tr-head {
                                          .birthdaylist header {
                                            letter-spacing: 0.1em;
                                            text-transform: uppercase;
                                            font-size: 20px;
                                            font-family: "Roboto Condensed", Arial, Helvetica, sans-serif;
                                            font-weight: 400;
                                            border-bottom: 1px solid #444444;
                                            line-height: 20px;
                                            padding-bottom: 5px;
                                            color: #ffffff;
                                            font-variant: small-caps;
                                          .birthdaylist .tfoot {
                                            height: 10px;
                                            padding: 0px;
                                            margin: 0px;
                                          .birthdaylist .tr-foot {
                                            height: 10px;
                                            padding: 0px;
                                            margin: 0px;
                                          .birthdaylist .td-foot {
                                            line-height: 16px;
                                            font-size: 16px;
                                            padding: 0px;
                                            margin: 0px;
                                            border: 1px solid #444444;
                                          .birthdaylist .tbody {
                                          .birthdaylist .tr-body {
                                          .birthdaylist .td-image {
                                            width: 27px;
                                            background-repeat: no-repeat;
                                            background-position: top left;
                                            background-image: url("/modules/birthdaylist/images/kalenderblatt.png");
                                            font-size: 20px;
                                            color: #000000;
                                            font-weight: 400;
                                            line-height: 26px;
                                            vertical-align: top;
                                            text-align: center;
                                            margin: 0px;
                                            padding: 10px 0px 0px 0px;
                                            border: 1px solid orange;
                                            height: 28px;
                                          .birthdaylist .td-body {
                                            font-size: 18px;
                                            color: #888888;
                                            line-height: 22px;
                                            padding: 0px 0px 8px 8px;
                                            margin: 0px;
                                            height: 28px;
                                            width: 160px;
                                          .birthdaylist span {
                                            color: orange;
                                            font-weight: bold;
                                            sdetweil @Perlchamp
                                            its just another routine like getDom()
                                            I put it right in front of getDom
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 12 / 16
