    read csv-data and put it in an array
    313 Posts 3 Posters 546.5k Views 4 Watching
    • PerlchampP Offline
      Perlchamp
        sdetweil @Perlchamp
        @Perlchamp said in read csv-data and put it in an array:
        sorry sam, but my code is displayed wrong ! what in hell …
        the tbody section:
        any < must have a space after it to display on the forum… no way to escape them yet…
        no real work from site admin on problem
          Perlchamp
              // Override dom generator.
              getDom: function() {
          	if ((moment() > this.midnight) || (!this.loaded)) {
          	    var month = moment().month();
          	    var year = moment().year();
          	    var monthName = moment().format("MMMM");
          	    var monthLength = moment().daysInMonth();
          	    // tabelle erstellen
          	    var wrapper = document.createElement("table");
          	    wrapper.className = 'table';
          	    wrapper.id = 'birthday-table';
          	    // tabellenkopf erstellen
          	    var tHeader = document.createElement("thead");
          	    tHeader.className = "thead";
          	    tHeader.id = "birthday-thead";
          	    var headerTR = document.createElement("tr");
          	    headerTR.className = "tr-head";
          	    headerTR.id = "birthday-tr-head";
          	    var headerTH = document.createElement("th");
          	    headerTH.colSpan = "2";
          	    headerTH.scope = "col";
          	    headerTH.className = "th-head";
          	    headerTH.id = "birthday-th-head";
          	    headerTH.innerHTML = this.translate(this.config.title);
          	    headerTR.appendChild(headerTH);
          	    tHeader.appendChild(headerTR);
          	    wrapper.appendChild(tHeader);
          	    // Create TFOOT section -- currently used for debugging only
          	    var tFooter = document.createElement('tfoot');
          	    tFooter.className = "tfoot";
          	    tFooter.id = "birthday-tfoot";
          	    var footerTR = document.createElement("tr");
          	    footerTR.className = "tr-foot";
          	    footerTR.id = "birthday-tr-foot";
          	    var footerTD = document.createElement("td");
          	    footerTD.colSpan ="2";
          	    footerTD.className = "td-foot";
          	    footerTD.id = "birthday-td-foot";
          	    if (this.config.debugging) {
          		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
          	    else {
          		footerTD.innerHTML = "";
          	    footerTR.appendChild(footerTD);
          	    tFooter.appendChild(footerTR);
          	    wrapper.appendChild(tFooter);
          	    // Create TBODY section with day names
          	    var eintraege = 3;
          	    for (var i=1; i< =eintraege; i++) {
          		var tBody = document.createElement("tBody");
          		tBody.className = "tbody";
          		tBody.id = "birthday-tbody";
          		var bodyTR = document.createElement("tr");
          		bodyTR.className = "tr-body";
          		bodyTR.id = "birthday-tr-body";
          		var bodyTDimage = document.createElement("td");
          		bodyTDimage.className = "td-image";
          		bodyTDimage.id = "birthday-td-image";
          		bodyTDimage.innerHTML = "23";
          		var bodyTD = document.createElement("td");
          		bodyTD.className = "td-body";
          		bodyTD.id = "birthday-td-body";
          		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;< span class=\"age-span\"> 46 < /span > < /br > Frank Dubiel&nbsp;&nbsp; < span class=\"age-span\" > 54 < /span > < /br >Jürgen Gruse&nbsp;&nbsp; < span class=\"age-span\" > 52 < /span > ";
          		var bodyAgeSpan = document.createElement("span");
          		bodyAgeSpan.className = "age-span";
          		bodyAgeSpan.id = "birthday-age-span";
          		bodyAgeSpan.innerHTML = "&nbsp;&nbsp;46";
          		bodyTD.appendChild(bodyAgeSpan);
          		bodyTR.appendChild(bodyTDimage);
          		bodyTR.appendChild(bodyTD);
          		tBody.appendChild(bodyTR);
          		wrapper.appendChild(tBody);
          	    this.loaded = true;
          	    return wrapper;
          this code looks like the image i did send before
            Perlchamp
            @sdetweil said in read csv-data and put it in an array:
            when I had a big pile of html objects to create I wrote a little routine to hide the 4 lines per object
            i will shurely take this, if my current html should work. now it’s too much “risk” for me, to change it.
              sdetweil @Perlchamp
              @Perlchamp yep… and you could use divs(as row) and spans(as column) for the table, instead of table/tr/td
              https://html-cleaner.com/features/replace-html-table-tags-with-divs/
                sdetweil @Perlchamp
                @Perlchamp cool thing about the routine, if u decide to use div/span under instead is to fix the routine,
                no mainline code has to change
                  Perlchamp
                  i don’t think so. therefor i’m a little bit toooooooo retro ;-)
                    sdetweil @Perlchamp
                    @Perlchamp each to their own!..
                      Perlchamp
                      if i do this :
                      //bodyTDimage.className = "td-image";
                      it looks like:
                      and i ask me, WHY css is not working only for this cell !!
                        sdetweil @Perlchamp
                        @Perlchamp td has a class, you are overriding it…
                        you want that class on the text in the td, not the td itself…
                        table, th, tr, all have classes… you can ADD a class instead of SET a class
                        += adds to
                          Perlchamp
                          but the other cell (name plus age) works, WHY ?
                            sdetweil @Perlchamp
                            @Perlchamp not a css class wizard
                              Perlchamp
                              no i don’t override the general td-class, cause i use:
                              .modulname .classname
                              font: 16px;
                                sdetweil @Perlchamp
                                @Perlchamp but you SET the ONLY classname to be yours… classame=
                                wipes out what was there
                                you do not append yours to the list of classNames already assigned className +=
                                  Perlchamp
                                  ok, i will try
                                    Perlchamp
                                    doesn’t work either
                                      sdetweil @Perlchamp
                                      @Perlchamp bummer
                                        Perlchamp
                                        where i have to place it ?
                                        sam, take my going code and see by yourself. here is the css:
                                        .birthdaylist .app {
                                            width: 200px;
                                            padding: 0px;
                                        .birthdaylist .table {
                                          padding: 0px;
                                          margin: 0px;
                                          border: 1px solid white;
                                          width: 200px;
                                        .birthdaylist .thead {
                                        .birthdaylist .tr-head {
                                        .birthdaylist header {
                                          letter-spacing: 0.1em;
                                          text-transform: uppercase;
                                          font-size: 20px;
                                          font-family: "Roboto Condensed", Arial, Helvetica, sans-serif;
                                          font-weight: 400;
                                          border-bottom: 1px solid #444444;
                                          line-height: 20px;
                                          padding-bottom: 5px;
                                          color: #ffffff;
                                          font-variant: small-caps;
                                        .birthdaylist .tfoot {
                                          height: 10px;
                                          padding: 0px;
                                          margin: 0px;
                                        .birthdaylist .tr-foot {
                                          height: 10px;
                                          padding: 0px;
                                          margin: 0px;
                                        .birthdaylist .td-foot {
                                          line-height: 16px;
                                          font-size: 16px;
                                          padding: 0px;
                                          margin: 0px;
                                          border: 1px solid #444444;
                                        .birthdaylist .tbody {
                                        .birthdaylist .tr-body {
                                        .birthdaylist .td-image {
                                          width: 27px;
                                          background-repeat: no-repeat;
                                          background-position: top left;
                                          background-image: url("/modules/birthdaylist/images/kalenderblatt.png");
                                          font-size: 20px;
                                          color: #000000;
                                          font-weight: 400;
                                          line-height: 26px;
                                          vertical-align: top;
                                          text-align: center;
                                          margin: 0px;
                                          padding: 10px 0px 0px 0px;
                                          border: 1px solid orange;
                                          height: 28px;
                                        .birthdaylist .td-body {
                                          font-size: 18px;
                                          color: #888888;
                                          line-height: 22px;
                                          padding: 0px 0px 8px 8px;
                                          margin: 0px;
                                          height: 28px;
                                          width: 160px;
                                        .birthdaylist span {
                                          color: orange;
                                          font-weight: bold;
                                          sdetweil @Perlchamp
                                          its just another routine like getDom()
                                          I put it right in front of getDom
                                            Perlchamp
                                            and the parent-element itselfs get a 0 (null) as parent ?
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 12 / 16
