    read csv-data and put it in an array
    313 Posts 3 Posters 579.0k Views 4 Watching
    • PerlchampP
      Perlchamp
      i don’t think so. therefor i’m a little bit toooooooo retro ;-)
        sdetweil @Perlchamp
        @Perlchamp each to their own!..
        • PerlchampP
          Perlchamp
          if i do this :
          //bodyTDimage.className = "td-image";
          it looks like:
          and i ask me, WHY css is not working only for this cell !!
            sdetweil @Perlchamp
            @Perlchamp td has a class, you are overriding it…
            you want that class on the text in the td, not the td itself…
            table, th, tr, all have classes… you can ADD a class instead of SET a class
            += adds to
            • PerlchampP
              Perlchamp
              but the other cell (name plus age) works, WHY ?
                sdetweil @Perlchamp
                @Perlchamp not a css class wizard
                • PerlchampP
                  Perlchamp
                  no i don’t override the general td-class, cause i use:
                  .modulname .classname
                  font: 16px;
                    sdetweil @Perlchamp
                    @Perlchamp but you SET the ONLY classname to be yours… classame=
                    wipes out what was there
                    you do not append yours to the list of classNames already assigned className +=
                    • PerlchampP
                      Perlchamp
                      ok, i will try
                      • PerlchampP
                        Perlchamp
                        doesn’t work either
                          sdetweil @Perlchamp
                          @Perlchamp bummer
                          • PerlchampP
                            Perlchamp
                            when I had a big pile of html objects to create I wrote a little routine to hide the 4 lines per object
                            where i have to place it ?
                            sam, take my going code and see by yourself. here is the css:
                            .birthdaylist .app {
                                width: 200px;
                                padding: 0px;
                            .birthdaylist .table {
                              padding: 0px;
                              margin: 0px;
                              border: 1px solid white;
                              width: 200px;
                            .birthdaylist .thead {
                            .birthdaylist .tr-head {
                            .birthdaylist header {
                              letter-spacing: 0.1em;
                              text-transform: uppercase;
                              font-size: 20px;
                              font-family: "Roboto Condensed", Arial, Helvetica, sans-serif;
                              font-weight: 400;
                              border-bottom: 1px solid #444444;
                              line-height: 20px;
                              padding-bottom: 5px;
                              color: #ffffff;
                              font-variant: small-caps;
                            .birthdaylist .tfoot {
                              height: 10px;
                              padding: 0px;
                              margin: 0px;
                            .birthdaylist .tr-foot {
                              height: 10px;
                              padding: 0px;
                              margin: 0px;
                            .birthdaylist .td-foot {
                              line-height: 16px;
                              font-size: 16px;
                              padding: 0px;
                              margin: 0px;
                              border: 1px solid #444444;
                            .birthdaylist .tbody {
                            .birthdaylist .tr-body {
                            .birthdaylist .td-image {
                              width: 27px;
                              background-repeat: no-repeat;
                              background-position: top left;
                              background-image: url("/modules/birthdaylist/images/kalenderblatt.png");
                              font-size: 20px;
                              color: #000000;
                              font-weight: 400;
                              line-height: 26px;
                              vertical-align: top;
                              text-align: center;
                              margin: 0px;
                              padding: 10px 0px 0px 0px;
                              border: 1px solid orange;
                              height: 28px;
                            .birthdaylist .td-body {
                              font-size: 18px;
                              color: #888888;
                              line-height: 22px;
                              padding: 0px 0px 8px 8px;
                              margin: 0px;
                              height: 28px;
                              width: 160px;
                            .birthdaylist span {
                              color: orange;
                              font-weight: bold;
                              sdetweil @Perlchamp
                              @Perlchamp said in read csv-data and put it in an array:
                              its just another routine like getDom()
                              I put it right in front of getDom
                              • PerlchampP
                                Perlchamp
                                and the parent-element itselfs get a 0 (null) as parent ?
                                  sdetweil @Perlchamp
                                  @Perlchamp i usually don’t use it for wrapper, but yes… the routine would have to check and not set if parent null, same for id
                                  • PerlchampP
                                    Perlchamp
                                    doesn’t work (black screen) yet, BUT:
                                    1. the classes set in “” ?
                                    2. no use of appendchild ?
                                    3. the wrapper set in “” ?
                                    i did :
                                    1. no
                                    2. correct
                                    3. no
                                    question:
                                    get i problems with this.create… because of “var self = this” ?
                                    • PerlchampP
                                      Perlchamp
                                      my code (only table):
                                      	    // create table
                                      	    var wrapper = this.createEl('table', "birthday-table", table , 0)
                                      	    //var wrapper = document.createElement("table");
                                      	    //wrapper.className = 'table';
                                      	    //wrapper.id = 'birthday-table';
                                      	    // create header
                                      	    var tHeader = this.createEl('thead', "birthday-thead", thead , wrapper)
                                      	    //var tHeader = document.createElement("thead");
                                      	    //tHeader.className = "thead";
                                      	    //tHeader.id = "birthday-thead";
                                      	    var headerTR = this.createEl('tr', "birthday-tr-head", tr-head , tHeader)
                                      	    //var headerTR = document.createElement("tr");
                                      	    //headerTR.className = "tr-head";
                                      	    //headerTR.id = "birthday-tr-head";
                                      	    var headerTH = document.createElement("th");
                                      	    //var headerTH = this.createEl('th', "birthday-th-head", th-head , headerTR)
                                      	    headerTH.colSpan = "2";
                                      	    headerTH.scope = "col";
                                      	    headerTH.innerHTML = " ";
                                      	    //headerTH.className = "th-head";
                                      	    //headerTH.id = "birthday-th-head";
                                      	    //headerTR.appendChild(headerTH);
                                      	    //tHeader.appendChild(headerTR);
                                      	    //wrapper.appendChild(tHeader);
                                      	    // Create TFOOT section -- currently used for debugging only
                                      	    var tFooter = this.createEl('tfoot', "birthday-tfood", tfoot , wrapper)
                                      	    //var tFooter = document.createElement('tfoot');
                                      	    //tFooter.className = "tfoot";
                                      	    //tFooter.id = "birthday-tfoot";
                                      	    //var footerTR = document.createElement("tr");
                                      	    var footerTR = this.createEl('tr', "birthday-tf-foot", tr-foot , tFooter)
                                      	    //footerTR.className = "tr-foot";
                                      	    //footerTR.id = "birthday-tr-foot";
                                      	    //var footerTD = document.createElement("td");
                                      	    var footerTD = this.createEl('td', "birthday-td-foot", td-foot , footerTR)
                                      	    footerTD.colSpan ="2";
                                      	    //footerTD.className = "td-foot";
                                      	    //footerTD.id = "birthday-td-foot";
                                      	    if (this.config.debugging) {
                                      		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode! < br / > Please see console log.";
                                      	    else {
                                      		footerTD.innerHTML = "&nbsp;";
                                      	    //footerTR.appendChild(footerTD);
                                      	    //tFooter.appendChild(footerTR);
                                      	    //wrapper.appendChild(tFooter);
                                      	    // create TBODY section with day names
                                      	    var tBody = this.createEl('tBody', "birthday-tbody", tbody , wrapper)
                                      	    //var tBody = document.createElement("tBody");
                                      	    //tBody.className = "tbody";
                                      	    //tBody.id = "birthday-tbody";
                                      	    for(var birthday of Object.keys(this.active_birthdays)) {
                                      		for(var person of this.active_birthdays[birthday]) {
                                      		    //var m = document.createElement('div');
                                      		    // create looped row section
                                      		    var bodyTR = this.createEl('tr', "birthday-tr-body", tr-body , tBody)
                                      		    //var bodyTR = document.createElement("tr");
                                      		    //bodyTR.className = "tr-body";
                                      		    //bodyTR.id = "birthday-tr-body";
                                      		    var bodyTDimage = this.createEl('td', "birthday-td-image", td-image , bodyTR)
                                      		    //var bodyTDimage = document.createElement("td");
                                      		    //bodyTDimage.id = "birthday-td-image";
                                      		    if (birthday.charAt(0) === "0") {
                                      			birthday = birthday.replace("0","");
                                      			birthday = birthday.substring(0,1);
                                      		    bodyTDimage.innerHTML = birthday.substring(0,2);
                                      		    var bodyTD = this.createEl('td', "birthday-td-body", td-body , bodyTDimage)
                                      		    //var bodyTD = document.createElement("td");
                                      		    //bodyTD.className = "td-body";
                                      		    //bodyTD.id = "birthday-td-body";
                                      		    bodyTD.innerHTML = person.name + "&nbsp;&nbsp;&nbsp; < span class=\"age-span\" > " + person.age + " < /span > ";
                                      		    //m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
                                      		    //wrapper.appendChild(m);
                                      		    //bodyTR.appendChild(bodyTDimage);
                                      		    //bodyTR.appendChild(bodyTD);
                                      		    //tBody.appendChild(bodyTR);
                                      		    //wrapper.appendChild(tBody);
                                        sdetweil @Perlchamp
                                        @Perlchamp all except parent in quotes
                                        tables parent is wrapper, wrappers parent is null/0
                                        • PerlchampP
                                          Perlchamp
                                          wrapper in quotes , too ?
                                            @sdetweil if there is no data, then you still need to return something (empty div)
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 12 / 16
