    read csv-data and put it in an array
    313 Posts 3 Posters 535.7k Views 4 Watching
    • PerlchampP Offline
      Perlchamp
      if i do this :
      //bodyTDimage.className = "td-image";
      it looks like:
      and i ask me, WHY css is not working only for this cell !!
        sdetweil @Perlchamp
        @Perlchamp td has a class, you are overriding it…
        you want that class on the text in the td, not the td itself…
        table, th, tr, all have classes… you can ADD a class instead of SET a class
        += adds to
          Perlchamp
          but the other cell (name plus age) works, WHY ?
            sdetweil @Perlchamp
            @Perlchamp not a css class wizard
              Perlchamp
              no i don’t override the general td-class, cause i use:
              .modulname .classname
              font: 16px;
                sdetweil @Perlchamp
                @Perlchamp but you SET the ONLY classname to be yours… classame=
                wipes out what was there
                you do not append yours to the list of classNames already assigned className +=
                  Perlchamp
                  ok, i will try
                    Perlchamp
                    doesn’t work either
                      sdetweil @Perlchamp
                      @Perlchamp bummer
                        Perlchamp
                        when I had a big pile of html objects to create I wrote a little routine to hide the 4 lines per object
                        where i have to place it ?
                        sam, take my going code and see by yourself. here is the css:
                        .birthdaylist .app {
                            width: 200px;
                            padding: 0px;
                        .birthdaylist .table {
                          padding: 0px;
                          margin: 0px;
                          border: 1px solid white;
                          width: 200px;
                        .birthdaylist .thead {
                        .birthdaylist .tr-head {
                        .birthdaylist header {
                          letter-spacing: 0.1em;
                          text-transform: uppercase;
                          font-size: 20px;
                          font-family: "Roboto Condensed", Arial, Helvetica, sans-serif;
                          font-weight: 400;
                          border-bottom: 1px solid #444444;
                          line-height: 20px;
                          padding-bottom: 5px;
                          color: #ffffff;
                          font-variant: small-caps;
                        .birthdaylist .tfoot {
                          height: 10px;
                          padding: 0px;
                          margin: 0px;
                        .birthdaylist .tr-foot {
                          height: 10px;
                          padding: 0px;
                          margin: 0px;
                        .birthdaylist .td-foot {
                          line-height: 16px;
                          font-size: 16px;
                          padding: 0px;
                          margin: 0px;
                          border: 1px solid #444444;
                        .birthdaylist .tbody {
                        .birthdaylist .tr-body {
                        .birthdaylist .td-image {
                          width: 27px;
                          background-repeat: no-repeat;
                          background-position: top left;
                          background-image: url("/modules/birthdaylist/images/kalenderblatt.png");
                          font-size: 20px;
                          color: #000000;
                          font-weight: 400;
                          line-height: 26px;
                          vertical-align: top;
                          text-align: center;
                          margin: 0px;
                          padding: 10px 0px 0px 0px;
                          border: 1px solid orange;
                          height: 28px;
                        .birthdaylist .td-body {
                          font-size: 18px;
                          color: #888888;
                          line-height: 22px;
                          padding: 0px 0px 8px 8px;
                          margin: 0px;
                          height: 28px;
                          width: 160px;
                        .birthdaylist span {
                          color: orange;
                          font-weight: bold;
                          sdetweil @Perlchamp
                          @Perlchamp said in read csv-data and put it in an array:
                          its just another routine like getDom()
                          I put it right in front of getDom
                            Perlchamp
                            and the parent-element itselfs get a 0 (null) as parent ?
                              sdetweil @Perlchamp
                              @Perlchamp i usually don’t use it for wrapper, but yes… the routine would have to check and not set if parent null, same for id
                                Perlchamp
                                doesn’t work (black screen) yet, BUT:
                                1. the classes set in “” ?
                                2. no use of appendchild ?
                                3. the wrapper set in “” ?
                                i did :
                                1. no
                                2. correct
                                3. no
                                question:
                                get i problems with this.create… because of “var self = this” ?
                                  Perlchamp
                                  my code (only table):
                                  	    // create table
                                  	    var wrapper = this.createEl('table', "birthday-table", table , 0)
                                  	    //var wrapper = document.createElement("table");
                                  	    //wrapper.className = 'table';
                                  	    //wrapper.id = 'birthday-table';
                                  	    // create header
                                  	    var tHeader = this.createEl('thead', "birthday-thead", thead , wrapper)
                                  	    //var tHeader = document.createElement("thead");
                                  	    //tHeader.className = "thead";
                                  	    //tHeader.id = "birthday-thead";
                                  	    var headerTR = this.createEl('tr', "birthday-tr-head", tr-head , tHeader)
                                  	    //var headerTR = document.createElement("tr");
                                  	    //headerTR.className = "tr-head";
                                  	    //headerTR.id = "birthday-tr-head";
                                  	    var headerTH = document.createElement("th");
                                  	    //var headerTH = this.createEl('th', "birthday-th-head", th-head , headerTR)
                                  	    headerTH.colSpan = "2";
                                  	    headerTH.scope = "col";
                                  	    headerTH.innerHTML = " ";
                                  	    //headerTH.className = "th-head";
                                  	    //headerTH.id = "birthday-th-head";
                                  	    //headerTR.appendChild(headerTH);
                                  	    //tHeader.appendChild(headerTR);
                                  	    //wrapper.appendChild(tHeader);
                                  	    // Create TFOOT section -- currently used for debugging only
                                  	    var tFooter = this.createEl('tfoot', "birthday-tfood", tfoot , wrapper)
                                  	    //var tFooter = document.createElement('tfoot');
                                  	    //tFooter.className = "tfoot";
                                  	    //tFooter.id = "birthday-tfoot";
                                  	    //var footerTR = document.createElement("tr");
                                  	    var footerTR = this.createEl('tr', "birthday-tf-foot", tr-foot , tFooter)
                                  	    //footerTR.className = "tr-foot";
                                  	    //footerTR.id = "birthday-tr-foot";
                                  	    //var footerTD = document.createElement("td");
                                  	    var footerTD = this.createEl('td', "birthday-td-foot", td-foot , footerTR)
                                  	    footerTD.colSpan ="2";
                                  	    //footerTD.className = "td-foot";
                                  	    //footerTD.id = "birthday-td-foot";
                                  	    if (this.config.debugging) {
                                  		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode! < br / > Please see console log.";
                                  	    else {
                                  		footerTD.innerHTML = "&nbsp;";
                                  	    //footerTR.appendChild(footerTD);
                                  	    //tFooter.appendChild(footerTR);
                                  	    //wrapper.appendChild(tFooter);
                                  	    // create TBODY section with day names
                                  	    var tBody = this.createEl('tBody', "birthday-tbody", tbody , wrapper)
                                  	    //var tBody = document.createElement("tBody");
                                  	    //tBody.className = "tbody";
                                  	    //tBody.id = "birthday-tbody";
                                  	    for(var birthday of Object.keys(this.active_birthdays)) {
                                  		for(var person of this.active_birthdays[birthday]) {
                                  		    //var m = document.createElement('div');
                                  		    // create looped row section
                                  		    var bodyTR = this.createEl('tr', "birthday-tr-body", tr-body , tBody)
                                  		    //var bodyTR = document.createElement("tr");
                                  		    //bodyTR.className = "tr-body";
                                  		    //bodyTR.id = "birthday-tr-body";
                                  		    var bodyTDimage = this.createEl('td', "birthday-td-image", td-image , bodyTR)
                                  		    //var bodyTDimage = document.createElement("td");
                                  		    //bodyTDimage.id = "birthday-td-image";
                                  		    if (birthday.charAt(0) === "0") {
                                  			birthday = birthday.replace("0","");
                                  			birthday = birthday.substring(0,1);
                                  		    bodyTDimage.innerHTML = birthday.substring(0,2);
                                  		    var bodyTD = this.createEl('td', "birthday-td-body", td-body , bodyTDimage)
                                  		    //var bodyTD = document.createElement("td");
                                  		    //bodyTD.className = "td-body";
                                  		    //bodyTD.id = "birthday-td-body";
                                  		    bodyTD.innerHTML = person.name + "&nbsp;&nbsp;&nbsp; < span class=\"age-span\" > " + person.age + " < /span > ";
                                  		    //m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
                                  		    //wrapper.appendChild(m);
                                  		    //bodyTR.appendChild(bodyTDimage);
                                  		    //bodyTR.appendChild(bodyTD);
                                  		    //tBody.appendChild(bodyTR);
                                  		    //wrapper.appendChild(tBody);
                                    sdetweil @Perlchamp
                                    @Perlchamp all except parent in quotes
                                    tables parent is wrapper, wrappers parent is null/0
                                      Perlchamp
                                      wrapper in quotes , too ?
                                        @sdetweil if there is no data, then you still need to return something (empty div)
                                          sdetweil @Perlchamp
                                          @Perlchamp wrapper is a div type, no id,class or parent
                                            Perlchamp
                                            my code now does not work:
                                                        // create table
                                            	    // create header
                                            	    var tHeader = this.createEl('thead', "birthday-thead", thead , "")
                                            	    var headerTR = this.createEl('tr', "birthday-tr-head", tr-head , "tHeader")
                                            	    var headerTH = this.createEl('th', "birthday-th-head", th-head , "headerTR")
                                            	    headerTH.innerHTML = "&nbsp;";
                                            	    var tFooter = this.createEl('tfoot', "birthday-tfood", tfoot , "")
                                            	    var footerTR = this.createEl('tr', "birthday-tf-foot", tr-foot , "tFooter")
                                            	    var footerTD = this.createEl('td', "birthday-td-foot", td-foot , "footerTR")
                                            	    else {
                                            	    var tBody = this.createEl('tBody', "birthday-tbody", tbody , "")
                                            		    var bodyTR = this.createEl('tr', "birthday-tr-body", tr-body , "tBody")
                                            		    var bodyTDimage = this.createEl('td', "birthday-td-image", td-image , "bodyTR")
                                            		    var bodyTD = this.createEl('td', "birthday-td-body", td-body , "bodyTDimage")
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 12 / 16
