    read csv-data and put it in an array
    313 Posts 3 Posters 590.1k Views 4 Watching
      @Perlchamp
      			    var bodyTR = document.createElement("tr");
      			   // bodyTR.className = "tr-body";
      			    bodyTR.id = "birthday-tr-body";
      			    tBody.appendChild(bodyTR);
      			    var bodyTDimage = document.createElement("td");
      			   // bodyTDimage.className = "td-image";
      			    bodyTDimage.id = "birthday-td-image";
      			   // bodyTDimage.innerHTML = birthday;
      			    bodyTR.appendChild(bodyTDimage);
      			    bodyTDimage.appendChild(document.createTextNode(birthday));
      			    var bodyTD = document.createElement("td");
      			   // bodyTD.className = "td-body";
      			    bodyTD.id = "birthday-td-body";
      			   // bodyTD.innerTEXT = person.name ;
      				bodyTD.appendChild(document.createTextNode(person.name));
      			    bodyTR.appendChild(bodyTD);
      				var ageTD = document.createElement("td");
      			    ageTD.id = "birthday-td-age";
      			    //ageTD.innerTEXT = person.age ;
      			    ageTD.appendChild(document.createTextNode(person.age));
      			    bodyTR.appendChild(ageTD);
      and set the class for the text element
      • PerlchampP
        Perlchamp
        you were too fast !!
        to your information:
        table needs a header (thead, tr, th) and a footer (tfoot, tr, td), and, of
        course a boda (tbody, tr, td), my cose, where a put html-tags in the table and text without variable works fine.
        but later, if i should dissapointed, i will try this.
          sdetweil @Perlchamp
          @Perlchamp >where a put html-tags in the table
          its exactly the same as writing the html
          they don’t NEED a thead/tfoot, these are optional
          you could create a big text string of the html < table>… < /table>
          and then assign that text string to the wrapper div innerHTML.
          same result…
            @sdetweil when I had a big pile of html objects to create I wrote a little routine to hide the 4 lines per object
            createEl(type, id, class, parent){
               var el = document.createElement(type)
               el.id=id
               if(class)
                 el.classname=class
               parent.addChild(el)
               return el
            then to use
                var table= this.createEl('table', "birthday-tbody", null , wrapper)
                        etc
                        etc
            • PerlchampP
              Perlchamp
              in the moment you’re too fast for me …
              this code is from the test-module:
                  getDom: function() {
              	if ((moment() > this.midnight) || (!this.loaded)) {
              	    var month = moment().month();
              	    var year = moment().year();
              	    var monthName = moment().format("MMMM");
              	    var monthLength = moment().daysInMonth();
              	    // tabelle erstellen
              	    var wrapper = document.createElement("table");
              	    wrapper.className = 'table';
              	    wrapper.id = 'birthday-table';
              	    // tabellenkopf erstellen
              	    var tHeader = document.createElement("thead");
              	    tHeader.className = "thead";
              	    tHeader.id = "birthday-thead";
              	    var headerTR = document.createElement("tr");
              	    headerTR.className = "tr-head";
              	    headerTR.id = "birthday-tr-head";
              	    var headerTH = document.createElement("th");
              	    headerTH.colSpan = "2";
              	    headerTH.scope = "col";
              	    headerTH.className = "th-head";
              	    headerTH.id = "birthday-th-head";
              	    headerTH.innerHTML = this.translate(this.config.title);
              	    headerTR.appendChild(headerTH);
              	    tHeader.appendChild(headerTR);
              	    wrapper.appendChild(tHeader);
              	    // Create TFOOT section -- currently used for debugging only
              	    var tFooter = document.createElement('tfoot');
              	    tFooter.className = "tfoot";
              	    tFooter.id = "birthday-tfoot";
              	    var footerTR = document.createElement("tr");
              	    footerTR.className = "tr-foot";
              	    footerTR.id = "birthday-tr-foot";
              	    var footerTD = document.createElement("td");
              	    footerTD.colSpan ="2";
              	    footerTD.className = "td-foot";
              	    footerTD.id = "birthday-td-foot";
              	    if (this.config.debugging) {
              		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
              	    else {
              		footerTD.innerHTML = "";
              	    footerTR.appendChild(footerTD);
              	    tFooter.appendChild(footerTR);
              	    wrapper.appendChild(tFooter);
              	    // Create TBODY section with day names
              	    var eintraege = 3;
              	    for (var i=1; i<=eintraege; i++) {
              		var tBody = document.createElement("tBody");
              		tBody.className = "tbody";
              		tBody.id = "birthday-tbody";
              		bodyTDimage.innerHTML = "23";
              		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;<span class=\"age-span\">46</span></br>Frank Dubiel&nbsp;&nbsp;<span class=\"age-span\">54</span></br>Jürgen Gruse&nbsp;&nbsp;<span class=\"age-span\">52</span>";
              		var bodyAgeSpan = document.createElement("span");
              		bodyAgeSpan.className = "age-span";
              		bodyAgeSpan.id = "birthday-age-span";
              		bodyAgeSpan.innerHTML = "&nbsp;&nbsp;46";
              		bodyTD.appendChild(bodyAgeSpan);
              		wrapper.appendChild(tBody);
              	    this.loaded = true;
              	    return wrapper;
              and looks like :
                sdetweil @Perlchamp
                @Perlchamp ok, so you WANT a title, header and footer…
                still no different than an actual table in all html
                by using document.creatElement and appendChild() there are no close tags to create
                a td is a closed thing you add text to a td…
                with my little helper routine, you write exactly what you would have written in html
                and can indent/outdent to match for readability
                  @Perlchamp maybe a nunjuks template , but its the same work to create the template the generate the content
                  the template has to have all the same stuff you are doing, including the loop part
                  • PerlchampP
                    Perlchamp
                      sdetweil @Perlchamp
                      @Perlchamp said in read csv-data and put it in an array:
                      sorry sam, but my code is displayed wrong ! what in hell …
                      the tbody section:
                      any < must have a space after it to display on the forum… no way to escape them yet…
                      no real work from site admin on problem
                      • PerlchampP
                        Perlchamp
                            // Override dom generator.
                        	    else {
                        	    var eintraege = 3;
                        	    for (var i=1; i< =eintraege; i++) {
                        		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;< span class=\"age-span\"> 46 < /span > < /br > Frank Dubiel&nbsp;&nbsp; < span class=\"age-span\" > 54 < /span > < /br >Jürgen Gruse&nbsp;&nbsp; < span class=\"age-span\" > 52 < /span > ";
                        	    this.loaded = true;
                        	    return wrapper;
                        this code looks like the image i did send before
                        • PerlchampP
                          Perlchamp
                          @sdetweil said in read csv-data and put it in an array:
                          i will shurely take this, if my current html should work. now it’s too much “risk” for me, to change it.
                            sdetweil @Perlchamp
                            @Perlchamp yep… and you could use divs(as row) and spans(as column) for the table, instead of table/tr/td
                            https://html-cleaner.com/features/replace-html-table-tags-with-divs/
                              sdetweil @Perlchamp
                              @Perlchamp cool thing about the routine, if u decide to use div/span under instead is to fix the routine,
                              no mainline code has to change
                              • PerlchampP
                                Perlchamp
                                i don’t think so. therefor i’m a little bit toooooooo retro ;-)
                                  sdetweil @Perlchamp
                                  @Perlchamp each to their own!..
                                  • PerlchampP
                                    Perlchamp
                                    if i do this :
                                    //bodyTDimage.className = "td-image";
                                    it looks like:
                                    and i ask me, WHY css is not working only for this cell !!
                                      sdetweil @Perlchamp
                                      @Perlchamp td has a class, you are overriding it…
                                      you want that class on the text in the td, not the td itself…
                                      table, th, tr, all have classes… you can ADD a class instead of SET a class
                                      += adds to
                                      • PerlchampP
                                        Perlchamp
                                        but the other cell (name plus age) works, WHY ?
                                          sdetweil @Perlchamp
                                          @Perlchamp not a css class wizard
                                          • PerlchampP
                                            Perlchamp
                                            no i don’t override the general td-class, cause i use:
                                            .modulname .classname
                                            font: 16px;
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
