    read csv-data and put it in an array
    313 Posts 3 Posters 590.5k Views 4 Watching
    • PerlchampP
      Perlchamp
      general question:
      is there something like “print”? (for debugging) or have i use innerText or innerHTML or Log.log ? … to display something on screen ?
        sdetweil @Perlchamp
        @Perlchamp Log.log only
        did u see my chat message about fixing a bug in the MMM-Logging module
        • PerlchampP
          Perlchamp
          i will have a look on it, though MERCI !
            sdetweil @Perlchamp
            @Perlchamp one other thing, u need to start a timer for when the month changes, when the timer expires, send a CONFIG message to the node_helper and it will send the latest birthdays list and everything will recalculate
            • PerlchampP
              Perlchamp
              hi sam, yes i thought about. in the moment this is the actually file, though there is code annotate and at the wrong place, … just so you don’t wonder … :
              /* global Module */
              /* Magic Mirror
               * Module: birthdaylist
               * Author: perlchamp@gmx.net
               * Lizenz: MIT
              Module.register("birthdaylist", {
                  // Default module config.
                  defaults: {
              	debugging: false,
              	initialLoadDelay: 0,		// How many seconds to wait on a fresh start up.
              					// This is to prevent collision with all other modules also
              					// loading all at the same time. This only happens once,
              					// when the mirror first starts up.
              	dimmEntries: true,   		// true: dims entries and the associated
              					//       symbol when the date has expired.
              					// false: delete entries and the associated
              	language: "de",			// needed for dateformatting
              	updateDelay: 5		        // How many seconds after midnight before a refresh
              				        // This is to prevent collision with other modules refreshing
              				        // at the same time.
                  active_birthdays: {
                  init: function() {
              	Log.log(this.name + " is in init!");
                  // Override start method
                  start: function() {
              	Log.log("Starting module: " + this.name);
              	// set locale here, default: de
              	moment.locale(config.language);
              	// Calculate next midnight and add updateDelay
              	var now = moment();
              	this.midnight = moment([now.year(), now.month(), now.date() + 1]).add(this.config.updateDelay, "seconds");
              	this.loaded = false;
              	this.scheduleUpdate(this.config.initialLoadDelay * 1000);
                  loaded: function(callback) {
              	Log.log(this.name + " is loaded!");
              	callback();
                  // return list of other functional scripts to use, if any (like require in node_helper)
                  getScripts: function () {
              	return ["moment.js"];
                  // return list of stylesheet files to use if any
                  getStyles: function() {
              	return [this.data.path + "/css/bdl.css"];
                  // you can configure the heading of the list in config.js
                  getHeader: function() {
              	return this.data.header;
                  // messages received from other modules and the system (NOT from your node helper)
                  // payload is a notification dependent data structure
              	// once everybody is loaded up
              	if(notification === "ALL_MODULES_STARTED") {
              	    // send our config to our node_helper
              	    this.sendSocketNotification("CONFIG",this.config);
              	if (sender) {
              	    Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
              	else {
              	    Log.log(this.name + " received a system notification: " + notification);
                  // messages received from from your node helper (NOT other modules or the system)
                  // payload is a notification dependent data structure, up to you to design between module and node_helper
              	if(notification === "JSONDATA") {
              	    var self = this;
              	    Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
              	    var now = moment();
              	    var day_month = moment().format("DD");
              	    for(var birthday of payload) {
              		// get 1st 5 chars of birthdate, thru month
              		// we will use this as the key in the hash
              		var birth_date = birthday.birth.substring(0,5);
              		// get the birthday as a moment in this year, for comparing
              		var birth_date_moment = moment(birth_date + now.year(),"DD.MMYYYY");
              		// you can add days to a moment object and then compare
              		//     if the birthdate is before that date (and after now)
              		//     so within the next xx days
              		// if the date is the same or later, don't use time of day
              		if(birth_date_moment.month() == now.month() ) {
              		    // birthday is in this month
              		    // check the hash if we've seen anything for today yet
              		    // if we haven't see this date yet
              		    if(this.active_birthdays[birth_date] == undefined) {
              			// create the holder for its info (array of
              			//	names) in the hash
              			this.active_birthdays[birth_date] = [];
              		    // save the persons name on the list
              		    self.active_birthdays[birth_date].push({'name':birthday.name,
              			'age': now.diff(moment(birthday.birth,'DD.MM.YYYY'), 'years') })
              	    // tell MM to call and get our content
              	    self.updateDom();
                  // system notification your module is being hidden
                  // typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
                  suspend: function() {
                  // system notification your module is being unhidden/shown
                  // typically you would resume doing UI updates (getDom/updateDom) if the module is shown
                  resume: function() {
                  // this is the major worker of the module, it provides the
                  // 	   displayable content for this module
                  getDom: function() {
              	var self = this;
              	Log.log(JSON.stringify(this.active_birthdays))
              	if ((moment() > this.midnight) || (!this.loaded)) {
              	    var month = moment().month();
              	    var year = moment().year();
              //	    var monthName = moment().format("MMMM");
              //	    var monthLength = moment().daysInMonth();
              	    // tabelle erstellen
              	    var wrapper = document.createElement("table");
              	    wrapper.className = 'table';
              	    wrapper.id = 'birthday-table';
              	    // tabellenkopf erstellen
              	    var tHeader = document.createElement("thead");
              	    tHeader.className = "thead";
              	    tHeader.id = "birthday-thead";
              	    var headerTR = document.createElement("tr");
              	    headerTR.className = "tr-head";
              	    headerTR.id = "birthday-tr-head";
              	    var headerTH = document.createElement("th");
              	    headerTH.colSpan = "2";
              	    headerTH.scope = "col";
              	    headerTH.className = "th-head";
              	    headerTH.id = "birthday-th-head";
              	    headerTH.innerHTML = this.translate(this.config.title);
              	    headerTR.appendChild(headerTH);
              	    tHeader.appendChild(headerTR);
              	    wrapper.appendChild(tHeader);
              	    // Create TFOOT section -- currently used for debugging only
              	    var tFooter = document.createElement('tfoot');
              	    tFooter.className = "tfoot";
              	    tFooter.id = "birthday-tfoot";
              	    var footerTR = document.createElement("tr");
              	    footerTR.className = "tr-foot";
              	    footerTR.id = "birthday-tr-foot";
              	    var footerTD = document.createElement("td");
              	    footerTD.colSpan ="2";
              	    footerTD.className = "td-foot";
              	    footerTD.id = "birthday-td-foot";
              	    if (this.config.debugging) {
              		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
              	    else {
              		footerTD.innerHTML = "";
              	    footerTR.appendChild(footerTD);
              	    tFooter.appendChild(footerTR);
              	    wrapper.appendChild(tFooter);
              	for(var birthday of Object.keys(this.active_birthdays)) {
              	    for(var person of this.active_birthdays[birthday]) {
              		var m=document.createElement('div');
              		// create tour table row here
              		m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
              		wrapper.appendChild(m);
              	// pass the created content back to MM to add to DOM.
              	this.loaded = true;
              	return wrapper;
              	    // Create TBODY section with day names
              	    var eintraege = 3;
              	    for (var i=1; i<=eintraege; i++) {
              		var tBody = document.createElement("tBody");
              		tBody.className = "tbody";
              		tBody.id = "birthday-tbody";
              		var bodyTR = document.createElement("tr");
              		bodyTR.className = "tr-body";
              		bodyTR.id = "birthday-tr-body";
              		var bodyTDimage = document.createElement("td");
              		bodyTDimage.className = "td-image";
              		bodyTDimage.id = "birthday-td-image";
              		bodyTDimage.innerHTML = "23";
              		var bodyTD = document.createElement("td");
              		bodyTD.className = "td-body";
              		bodyTD.id = "birthday-td-body";
              		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;<span class=\"age-span\">46</span></br>Frank Dubiel&nbsp;&nbsp;<span class=\"age-span\">54</span></br>Jürgen Gruse&nbsp;&nbsp;<span class=\"age-span\">52</span>";
              //		var bodyAgeSpan = document.createElement("span");
              //		bodyAgeSpan.className = "age-span";
              //		bodyAgeSpan.id = "birthday-age-span";
              //		bodyAgeSpan.innerHTML = "&nbsp;&nbsp;46";
              //		bodyTD.appendChild(bodyAgeSpan);
              		bodyTR.appendChild(bodyTDimage);
              		bodyTR.appendChild(bodyTD);
              		tBody.appendChild(bodyTR);
              		wrapper.appendChild(tBody);
                  scheduleUpdate: function(delay) {
              	    Log.log("= = = = = = = = = = = = = = = = = = = = = = = = = = = = = =");
              	    Log.log("Birthdaylist IS IN DEBUG MODE!");
              	    Log.log("Remove 'debugging' option from config/config.js to disable.");
              	    Log.log("Current moment(): " + moment() + " (" + moment().format("hh:mm:ss a") + ")");
              	    Log.log("scheduleUpdate() delay set at: " + delay);
              	if (typeof delay !== "undefined" && delay >= 0) {
              	    nextReload = delay;
              	if (delay > 0) {
              	    // Calculate the time DIFFERENCE to that next reload!
              	    nextReload = moment.duration(nextReload.diff(moment(), "milliseconds"));
              		var hours = Math.floor(nextReload.asHours());
              		var  mins = Math.floor(nextReload.asMinutes()) - hours * 60;
              		var  secs = Math.floor(nextReload.asSeconds()) - ((hours * 3600 ) + (mins * 60));
              		Log.log("  nextReload should happen at: " + delay + " (" + moment(delay).format("hh:mm:ss a") + ")");
              		Log.log("                  which is in: " + mins + " minutes and " + secs + " seconds.");
              		Log.log("              midnight set at: " + this.midnight + " (" + moment(this.midnight).format("hh:mm:ss a") + ")");
              	var self = this;
              	setTimeout(function() {
              	    self.reloadDom();
              	}, nextReload);
                  reloadDom: function() {
              	    Log.log("          Calling reloadDom()!");
              	var now = moment();
              	if (now > this.midnight) {
              	    this.updateDom(this.config.fadeSpeed * 1000);
              	var nextRefresh = moment([now.year(), now.month(), now.date(), now.hour() + 1]);
              	this.scheduleUpdate(nextRefresh);
              and thanks agaibn for your time …
                sdetweil @Perlchamp
                @Perlchamp awesome…
                • PerlchampP
                  Perlchamp
                  i although thought about to include a template, but first i want to figure out the html-stuff and the if … than -statements (people the same day, date passed, and so on …), but you see i’m on fire right now …
                    sdetweil @Perlchamp
                    @Perlchamp cool… i did the age correction
                    • PerlchampP
                      Perlchamp
                      cool too :-) , so you still burn, too :-))
                      • PerlchampP
                        Perlchamp
                        hi sam, i know that the code of table is working (in testmodule). but can’t get objects in there. did look in dev-widow, but looks fine. in the terminal-window i see that objects have been handed over (node to module.js). this is the code for the body of the table:
                        	    // create TBODY section with day names
                        		    //var m = document.createElement('div');
                        		    // create looped row section
                        		    bodyTDimage.innerHTML = birthday;
                        		    bodyTD.innerHTML = person.name + "<span class=\"age-span\">" + person.age + "</span>";
                        		    //m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
                        		    //wrapper.appendChild(m);
                        what did i make wrong ?
                        • PerlchampP
                          Perlchamp
                          @Perlchamp said in read csv-data and put it in an array:
                          bodyTD.innerHTML = person.name + “” + person.age + “”;
                          should be:
                          bodyTD.innerHTML = person.name + span class = … + person.age + /span;
                          can’t send html tags here ? how i have to escape them here ?
                            sdetweil @Perlchamp
                            @Perlchamp cannot escape tags here, long time complaint
                            • PerlchampP
                              Perlchamp
                              did it !
                              this.loaded = true; was wrong placed …
                              • PerlchampP
                                Perlchamp
                                but this does not work yet:
                                		    if (birthday.charAt(0) === "0") {
                                			birthday = birthday.replace("0","");
                                			birthday = birthday.substring(0,1);
                                		    bodyTDimage.innerHTML = birthday.substring(0,2);
                                the value will not displayed, but i will find a way. my code yet is far away from a smart code :-))
                                • PerlchampP
                                  Perlchamp
                                  this is the status at the moment :
                                    sdetweil @Perlchamp
                                    @Perlchamp cool… do you want ages aligned?
                                    • PerlchampP
                                      Perlchamp
                                      yes, of course, sir …
                                        sdetweil @Perlchamp
                                        @Perlchamp need to specify width of td
                                        By default, a browser will adjust table columns to fit the contents of the table. However, if you want to control the width of each column, you can do so by adjusting the width of each or of a single row.
                                        if you had th, then you could see the length of the names as they go by, and then adjust the th width before sending the content to MM…
                                        • PerlchampP
                                          Perlchamp
                                          width:27px; is placed in css
                                          but this:
                                          //bodyTDimage.id = "birthday-td-image";
                                          works. i really have to write html-text in the module-file ?
                                            sdetweil @Perlchamp
                                            @Perlchamp eh? commenting out a line?
                                            have a th is the same as what you have document.createElement(“th”)
                                            • 10
                                            • 11
                                            • 12
                                            • 15
                                            • 16
                                            • 10 / 16
