    MMM-Modulebar - A module that adds touch buttons for showing/hiding other modules.
    16 Posts 6 Posters 14.0k Views 7 Watching
    • chaseb1357C Offline
      chaseb1357
      Is it possible to make the module bar itself toggle-able? It covers a large amount of screen real-estate; I was just wondering if its possible, how I could do that.
      SnilleS 1 Reply Last reply Reply Quote 0
      • SnilleS Offline
        Snille Module Developer @chaseb1357
        @chaseb1357 Well, you could “hide” it with a button, but the problem is to get it back again. :)
        chaseb1357C 1 Reply Last reply Reply Quote 0
          chaseb1357 @Snille
          @Snille Haha, I tried that yes. only to realize my mistake.
          • SnilleS Offline
            @chaseb1357 Personally I’m using the “Hide all” module for removing everything. :)
              chaseb1357 @Snille
              @Snille I have that module installed also, I was just wanting a quick way to hide certain modules like for example email. For whenever I don’t want any friends snooping, while i still get to show off the mirror. :)
              • SnilleS Offline
                @chaseb1357 Hmm… I have not tried it… But what if you have two instances of the modulebar one with only one button hiding the “other” module bar. :)
                  chaseb1357 @Snille
                  @Snille That was a brilliant idea! I got it to work just as I wanted.0_1500311515278_Capture.PNG
                  The Modules button is a separate module bar that I set up to toggle the one that I will fill with all my modules. I achieved this by going to my modules folder and duplicating the “MMM-Modulebar” folder and renaming it “MMM-ModulebarHide”. I then renamed everything referencing “MMM-Modulebar” to “MMM-ModulebarHide” for consistency.
                  My config file is set up like this:
                          		module: "MMM-ModulebarHide",
                         			position: "bottom_right",
                  			//header: "Modules",
                          		classes: "default everyone",
                          			buttons: {
                     				 	"1": {
                  	  					module: "MMM-Modulebar",
                        						text: "Modules",
                         			position: "bottom_bar", // This can be any of the regions.
                  			header: "Modules", // Optional
                          		classes: "default everyone", // Optional
                          			buttons: {
                     				 	"1": {
                  	  					module: "clock",
                        						text: "Clock",
                     					"2": {
                  						module: "currentweather",
                        						text: "Current Weather",
                        					"3": {
                        						text: "Calender",
                        					"4": {
                        						module: "weatherforecast",
                        						text: "Weather Forecast",
                        					"5": {
                        						module: "newsfeed",
                        						text: "News Feed",
                        					"6": {
                        						module: "MMM-SystemStats",
                        						text: "System Stats",
                  I can now toggle the module bar! Thanks so much!
                  SnilleS 1 Reply Last reply Reply Quote 1
                  • SnilleS Offline
                    @chaseb1357 Hehe! Great! :) Nicely done!
                    • G Offline
                      gaudouy
                      Hello, is it possible to use one button for display multiple module ?
                      Example :
                      Button 1 : Clock and weather
                      Button 2 : Mail and calendar
                      Button 3 : Clock and Camera
                      Thanks for advance
                      • SnilleS Offline
                        Snille Module Developer @gaudouy
                        @gaudouy Hi, no, it can only show and hide one/ or multiple instances of the same type of module on one button, but not two different types of modules on one button.
