    MMM-MyCommute not showing up today.
    15 Posts 2 Posters 3.4k Views 2 Watching
    • G Offline
      gwiz
      Hi everyone,
      I’ve been working on my MagicMirror for a while now, and installed MMM-MyCommute a while back along with MMM-GoogleMapsTraffic at about the same time. Today I booted up my Magic Mirror to find that the MyCommute module did not show up, and there was an update notification at the top. I updated MyCommute, applied the new changes to the config, and still, nothing showed up when I ran Magic Mirror again. I tried running it with the exact example config shown in the readme with my API key from google, and still nothing. It was running fine before today. Does anyone have any ideas?
      Note - MMM-GoogleMapsTraffic is still working well, and when I ran npm start dev I found that there was a potential error with using the same API keys for both modules (which I thought was weird since It’s been running fine this whole time), so I made a brand new API key, but still nothing.
      Thanks so much for the help!
        sdetweil @gwiz
        @gwiz said in MMM-MyCommute not showing up today.:
        there was a bug in this module, I provided a fix for the developer, but they have not incorporated it yet
        it caused interference with other modules
        u can try my version
        rename the modules/MMM-GoogleMapsTraffic folder out of the way
        cd ~/magicMirror/modules
        git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic
        then restart your mirror
        • G Offline
          gwiz
          That worked perfectly! Thanks so much!
          • G Offline
            gwiz
            Hi @sdetweil,
            I’m having the same exact problem again, do you think it could be interfering with MMM-GoogleMapsTraffic again? I have no updates to install, and MMM-MyCommute keeps shutting off.
              sdetweil @gwiz
              @gwiz i have no idea… if you open the developers window (ctrl-shift-i or F12 on the keyboard),
              and select the console tab, and put commu in the filter field, do you see any errors?
              • G Offline
                gwiz
                It says suspended but I’m not sure why, how can I check the reason?
                  sdetweil @gwiz
                  @gwiz do you use pages, or some activity monitor? pir, or somesuch
                  sadly there is no notification for the call to suspend on WHO, but now that you found that line,
                  you can re-enable other messages (remove filter) and then find the suspend again (search works)
                  and find if some module said something just before
                  • G Offline
                    gwiz
                    Here is what it shows me:
                    Not sure if what you asked, but I do use VNC Viewer to connect and edit the mirror without taking the frame off. Could that have something to do with it?
                    Thanks for your help
                      sdetweil @gwiz
                      shouldn’t have anything to do with it… I edit thru an ssh connection all the time. never touch the mirror itself
                      looking at the code it hides itself if its outside the configured times or there are no destinations…
                      there are 4 different ones, which are u using?
                      git remote -v in the module folder will tell you
                      • G Offline
                        gwiz
                        Sorry I’m not sure what you mean, I ran the command and this is what it gave me:
